[PATCH v5 2/4] bsps: New GPIO API & peripherals API framework
Duc Doan
dtbpkmte at gmail.com
Sun Jul 24 12:01:09 UTC 2022
bsps/include/bsp/gpio2.h | 528 ++++++++++++++++++++++++
bsps/include/bsp/periph_api.h | 142 +++++++
bsps/shared/dev/gpio/gpio.c | 212 ++++++++++
bsps/shared/dev/periph_api/periph_api.c | 101 +++++
spec/build/bsps/obj.yml | 4 +-
5 files changed, 986 insertions(+), 1 deletion(-)
create mode 100644 bsps/include/bsp/gpio2.h
create mode 100644 bsps/include/bsp/periph_api.h
create mode 100644 bsps/shared/dev/gpio/gpio.c
create mode 100644 bsps/shared/dev/periph_api/periph_api.c
diff --git a/bsps/include/bsp/gpio2.h b/bsps/include/bsp/gpio2.h
new file mode 100644
index 0000000000..9cb1c720ab
--- /dev/null
+++ b/bsps/include/bsp/gpio2.h
@@ -0,0 +1,528 @@
+ * Copyright (C) 2022 Duc Doan (dtbpkmte at gmail.com)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifndef LIBBSP_BSP_GPIO2_H
+#define LIBBSP_BSP_GPIO2_H
+#include <bsp.h>
+#include <rtems.h>
+ * Configure the maximum number of GPIO controllers used in
+ * a application.
+ * The macro CONFIGURE_GPIO_MAXIMUM_CONTROLLERS can be
+ * defined in application code. If it is not defined,
+ * it will default to BSP_GPIO_NUM_CONTROLLERS. If BSP's
+ * number of controllers is not defined, it will default
+ * to 1.
+#ifndef CONFIGURE_GPIO_MAXIMUM_CONTROLLERS
+#ifndef BSP_GPIO_NUM_CONTROLLERS
+#define CONFIGURE_GPIO_MAXIMUM_CONTROLLERS 1
+#else
+#define CONFIGURE_GPIO_MAXIMUM_CONTROLLERS BSP_GPIO_NUM_CONTROLLERS
+#endif /* BSP_GPIO_NUM_CONTROLLERS */
+#endif /* CONFIGURE_GPIO_MAXIMUM_CONTROLLERS */
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+ * @brief Macro to initialize rtems_gpio.
+ * @param gpioh pointer to GPIO handlers
+#define RTEMS_GPIO_BUILD_BASE(_gpio_handlers) \
+ (rtems_gpio) { .virtual_pin = 0, \
+ .gpio_handlers = ( _gpio_handlers ), \
+ .api = NULL \
+ * @name GPIO data structures
+ * @brief GPIO bit set and reset enumeration.
+typedef enum {
+ RTEMS_GPIO_PIN_RESET = 0,
+ RTEMS_GPIO_PIN_SET = 1
+} rtems_gpio_pin_state;
+ * @brief GPIO pin modes.
+typedef enum {
+ RTEMS_GPIO_PINMODE_OUTPUT = 0,
+ RTEMS_GPIO_PINMODE_OUTPUT_PP = 0,
+ RTEMS_GPIO_PINMODE_OUTPUT_OD = 1,
+ RTEMS_GPIO_PINMODE_INPUT = 2,
+ RTEMS_GPIO_PINMODE_ANALOG = 3,
+ RTEMS_GPIO_PINMODE_BSP_SPECIFIC = 4
+} rtems_gpio_pin_mode;
+ * @brief GPIO pull resistor configuration. Defines pull-up or
+ * pull-down activation.
+typedef enum {
+ RTEMS_GPIO_NOPULL,
+ RTEMS_GPIO_PULLUP,
+ RTEMS_GPIO_PULLDOWN
+} rtems_gpio_pull;
+ * @brief Interrupt modes enumeration.
+typedef enum {
+ RTEMS_GPIO_INT_TRIG_NONE = 0,
+ RTEMS_GPIO_INT_TRIG_FALLING,
+ RTEMS_GPIO_INT_TRIG_RISING,
+ RTEMS_GPIO_INT_TRIG_BOTH_EDGES,
+ RTEMS_GPIO_INT_TRIG_LOW,
+ RTEMS_GPIO_INT_TRIG_HIGH
+} rtems_gpio_interrupt_trig;
+typedef struct rtems_gpio_handlers rtems_gpio_handlers;
+typedef struct rtems_gpio rtems_gpio;
+ * @brief Typedef of the function pointer of an ISR.
+typedef void (*rtems_gpio_isr)(void *);
+#include <bsp/periph_api.h>
+ * @brief Structure containing pointers to handlers of a
+ * BSP/driver. Each BSP/driver must define its own
+ * handlers and create an object of this structure
+ * with pointers to those handlers.
+struct rtems_gpio_handlers {
+ * @brief This member is the pointer to a handler for setting
+ * pin mode.
+ * Pin modes are from rtems_gpio_pin_mode enumeration.
+ rtems_status_code (*set_pin_mode)(rtems_gpio *, rtems_gpio_pin_mode);
+ * pull resistor mode.
+ * Pull resistor modes are from rtems_gpio_pull enumeration.
+ rtems_status_code (*set_pull)(rtems_gpio *, rtems_gpio_pull);
+ * @brief This member is the pointer to a handler for configuring
+ * interrupt of a pin.
+ * This handler should register ISR and its argument, interrupt
+ * trigger mode, and pull resister mode for the pin.
+ * @note Enabling interrupt should be done in enable_interrupt()
+ * handler.
+ rtems_status_code (*configure_interrupt)(rtems_gpio *, rtems_gpio_isr, void *, rtems_gpio_interrupt_trig, rtems_gpio_pull);
+ * @brief This member is the pointer to a handler for removing
+ * interrupt settings of a pin.
+ * Interrupt settings can be ISR address, pin configuration, etc.
+ rtems_status_code (*remove_interrupt)(rtems_gpio *);
+ * @brief This member is the pointer to a handler for enabling
+ * interrupt functionality of a pin.
+ rtems_status_code (*enable_interrupt)(rtems_gpio *);
+ * @brief This member is the pointer to a handler for disabling
+ rtems_status_code (*disable_interrupt)(rtems_gpio *);
+ * @brief This member is the pointer to a handler for reading
+ * the digital value of a pin.
+ * The returned value should be in rtems_gpio_pin_state enum.
+ rtems_status_code (*read)(rtems_gpio *, rtems_gpio_pin_state *);
+ * @brief This member is the pointer to a handler for writing
+ * a digital value to a pin.
+ rtems_status_code (*write)(rtems_gpio *, rtems_gpio_pin_state);
+ * @brief This member is the pointer to a handler for toggling
+ * a pin.
+ * It should change pin state from SET to RESET or vice versa.
+ rtems_status_code (*toggle)(rtems_gpio *);
+ * @brief Structure representing a GPIO object.
+ * BSP/drivers need to define their own GPIO structures with
+ * rtems_gpio being the first member.
+struct rtems_gpio {
+ * @brief This member is a virtual pin number, counting from
+ * 0 (zero).
+ uint32_t virtual_pin;
+ * @brief This member is a pointer to a structure containing
+ * pointers to handlers of a GPIO controller.
+ const rtems_gpio_handlers *gpio_handlers;
+ * @brief This member is a pointer to a peripheral API.
+ rtems_periph_api *api;
+ * @name GPIO System operations
+ * Functions in this group should not be called by user
+ * applications. They are used by BSP/drivers only.
+ * @brief Perform initialization for GPIO system and
+ * Peripheral API system.
+ * This function is called automatically using
+ * SYSINIT.
+extern void rtems_gpio_start(
+ void
+ * @brief Registers a GPIO controller with GPIO manager.
+ * This function registers the pointer to BSP/driver-specific
+ * get_gpio() and destroy_gpio() functions. Those two functions
+ * are for creating and destroying GPIO objects. It also takes
+ * the number of pins of each BSP/driver for mapping into a
+ * flat pin numbering system (virtual pin number).
+ * This function also help register peripherals API get()
+ * and remove() functions.
+ * @param get_gpio The pointer to BSP/driver-specific get_gpio()
+ * @param destroy_gpio The pointer to BSP/driver-specific
+ * destroy_gpio()
+ * @param get_api The pointer to BSP/driver-specific get_api()
+ * @param remove_api The pointer to BSP/driver-specific remove_api()
+ * @param pin_count The number of GPIO pins in the controller
+ * @retval RTEMS_SUCCESSFUL Controller registered successfully
+ * @retval RTEMS_TOO_MANY if the maximum number of controllers are
+ * already registered
+extern rtems_status_code rtems_gpio_register(
+ rtems_status_code (*get_gpio)(uint32_t, rtems_gpio **),
+ rtems_status_code (*destroy_gpio)(rtems_gpio *),
+ rtems_periph_api *(*get_api)(rtems_gpio *, rtems_periph_api_type),
+ rtems_status_code (*remove_api)(rtems_gpio *),
+ uint32_t pin_count
+ * @name GPIO BSP functions
+ * BSP and drivers need to implement these.
+ * @brief Wrapper to perform all BSP controllers registering
+ * with the GPIO manager.
+ * This function must be implemented by BSP. It should call
+ * rtems_gpio_register() to register each integrated GPIO
+ * controller.
+extern rtems_status_code bsp_gpio_register_controllers(
+ void
+ * @name GPIO Application operations
+ * @brief Get the GPIO object containing information
+ * about the specified pin.
+ * This function maps the virtual pin to intermediate pin,
+ * and pass to the BSP/driver-specific function to get a
+ * GPIO object.
+ * @note Warning: this function may use malloc(). When you
+ * are done with the GPIO object, call rtems_gpio_destroy()
+ * to avoid memory leak.
+ * @param virt_pin The virtual pin number.
+ * @param[out] out The pointer to the pointer to the output
+ * GPIO object.
+ * @retval RTEMS_UNSTISFIED if the virtual pin number
+ * is invalid (i.e. out of range)
+extern rtems_status_code rtems_gpio_get(
+ uint32_t virt_pin,
+ rtems_gpio **out
+ * @brief Destroy a GPIO object
+ * This function should be called on an GPIO object which is
+ * no longer used to avoid memory leak. Internally it can
+ * use free().
+ * @param[in] base The pointer to the GPIO object.
+ * @retval RTEMS_UNSATISFIED
+extern rtems_status_code rtems_gpio_destroy(
+ rtems_gpio *base
+ * @brief Sets the pin mode of a pin.
+ * This function calls the registered BSP/driver-specific handler.
+ * It can be used to set the pin mode for a pin.
+ * @param[in] base The GPIO object to be configured.
+ * @param mode The pin mode from the enumeration rtems_gpio_pin_mode
+ * @retval RTEMS_SUCCESSFUL GPIO configured successfully.
+ * @retval RTEMS_UNSATISFIED Could not set the pin mode.
+ * @retval @see BSP/driver-specific function for other return codes.
+extern rtems_status_code rtems_gpio_set_pin_mode(
+ rtems_gpio *base,
+ rtems_gpio_pin_mode mode
+ * @brief Sets the pin's pull resistor configuration.
+ * It can be used to set the pull resistor mode for a pin.
+ * @param mode The pull mode from the enumeration rtems_gpio_pull
+ * @retval RTEMS_UNSATISFIED Could not set the pull resistor mode.
+extern rtems_status_code rtems_gpio_set_pull(
+ rtems_gpio *base,
+ rtems_gpio_pull pull
+ * @brief Configure interrupt on a GPIO pin.
+ * It can be used to set up a pin for interrupt mode.
+ * @note This only configures the interrupt but not enable it. Use
+ * rtems_gpio_enable_interrupt() to actually enable interrupt.
+ * @param isr The pointer to the ISR to be attached to this pin.
+ * @param[in] arg The pointer to the argument of the ISR.
+ * @param trig The trigger mode
+ * @param pull The pull resistor mode
+ * @retval RTEMS_SUCCESSFUL Interrupt configured successfully.
+ * @retval RTEMS_UNSATISFIED Could not configure interrupt.
+extern rtems_status_code rtems_gpio_configure_interrupt(
+ rtems_gpio *base,
+ rtems_gpio_isr isr,
+ void *arg,
+ rtems_gpio_interrupt_trig trig,
+ * @brief Remove interrupt settings for a pin.
+ * It can be used to remove interrupt configuration of a pin like
+ * ISR, ISR argument, pin mode, etc.
+ * @note This only removes the interrupt but not disable it. Use
+ * rtems_gpio_disable_interrupt() to actually disable
+ * interrupt.
+ * @retval RTEMS_SUCCESSFUL Interrupt removed successfully.
+ * @retval RTEMS_UNSATISFIED Could not remove interrupt.
+extern rtems_status_code rtems_gpio_remove_interrupt(
+ rtems_gpio *base
+ * @brief Enable interrupt on a GPIO pin.
+ * @note This function only enables the interrupt (e.g. the vector)
+ * but not configure the pin. Use
+ * rtems_gpio_configure_interrupt() for pin configuration.
+ * @retval RTEMS_SUCCESSFUL Interrupt enabled successfully.
+ * @retval RTEMS_UNSATISFIED Could not enable interrupt.
+extern rtems_status_code rtems_gpio_enable_interrupt(
+ rtems_gpio *base
+ * @brief Disable interrupt on a GPIO pin.
+ * @note This function only disables the interrupt (e.g. the vector)
+ * but not remove the pin's configurations. Use
+ * rtems_gpio_remove_interrupt() for the latter purpose.
+ * @retval RTEMS_SUCCESSFUL Interrupt disabled successfully.
+ * @retval RTEMS_UNSATISFIED Could not disable interrupt.
+extern rtems_status_code rtems_gpio_disable_interrupt(
+ rtems_gpio *base
+ * @brief Writes a digital value to a pin.
+ * @param[in] base The GPIO object that has information about the
+ * pin.
+ * @param value The state to be written to the pin.
+ * @retval RTEMS_SUCCESSFUL Pin successfully written.
+extern rtems_status_code rtems_gpio_write(
+ rtems_gpio *base,
+ rtems_gpio_pin_state value
+ * @brief Reads the digital value of a pin.
+ * pin.
+ * @param[out] value The state of the pin.
+ * @retval RTEMS_SUCCESSFUL Pin succesfully read.
+extern rtems_status_code rtems_gpio_read(
+ rtems_gpio *base,
+ rtems_gpio_pin_state *value
+ * @brief Toggles the state of a GPIO pin.
+ * pin.
+ * @retval RTEMS_SUCCESSFUL Pin successfully toggled.
+extern rtems_status_code rtems_gpio_toggle(
+ rtems_gpio *base
+#ifdef __cplusplus
+#endif /* LIBBSP_BSP_GPIO2_H */
diff --git a/bsps/include/bsp/periph_api.h b/bsps/include/bsp/periph_api.h
index 0000000000..fb02b701dc
--- /dev/null
+++ b/bsps/include/bsp/periph_api.h
@@ -0,0 +1,142 @@
+ * are met:
+#ifndef LIBBSP_BSP_PERIPH_API_H
+#define LIBBSP_BSP_PERIPH_API_H
+#include <bsp.h>
+#include <rtems.h>
+#ifdef __cplusplus
+extern "C" {
+ * @brief Enumeration of supported peripheral APIs.
+typedef enum {
+ RTEMS_PERIPH_API_TYPE_ADC
+} rtems_periph_api_type;
+ * @brief The base structure of peripheral APIs.
+ * All peripheral APIs must have this struct as
+ * their first member.
+ * @see rtems_adc_api for example implementation.
+typedef struct rtems_periph_api rtems_periph_api;
+#include <bsp/gpio2.h>
+ * rtems_periph_api structure definition.
+struct rtems_periph_api {
+ * @brief This member tells the type of this
+ * API.
+ rtems_periph_api_type api_type;
+ * BSP/driver-specific function that
+ * performs initialization for the
+ * API.
+ void (*init)(rtems_gpio *pin);
+ * @brief Register a handler to get API pointer.
+ * @param[in] get_api pointer to a handler to
+ * get an API with specified type.
+ * @param index the index of the GPIO controller.
+void rtems_periph_api_register_api(
+ uint32_t index
+ * @brief Performs initialization for peripheral
+ * API system.
+ * This function registers some variables that
+ * the peripheral API utilize from GPIO API.
+ * @param get_ctrl_index Pointer to a helper
+ * that returns a GPIO controller index
+ * of a pin.
+ * @param num_ctrl Pointer to a variable that
+ * tells the number of registered GPIO
+ * controllers.
+void rtems_periph_api_start(
+ uint32_t (*get_ctrl_index)(uint32_t),
+ uint32_t *num_ctrl
+ * @brief Assign an API to a GPIO object and
+ * initialize it.
+ * @note This function may use malloc().
+ * @note This function calls the handler init().
+ * @param pin The rtems_gpio object representing
+ * a pin.
+ * @param type The peripheral API type.
+ * @retval RTEMS_SUCCESSFUL if an API is set
+ * correctly.
+ * @retval RTEMS_UNSATISFIED if the API type is
+ * invalid for this pin.
+ * @retval RTEMS_NO_MEMORY if memory cannot be
+ * allocated for API object.
+rtems_status_code rtems_periph_api_set_api(
+ rtems_gpio *pin,
+ rtems_periph_api_type type
+ * @brief Remove the API assigned to a pin by
+ * setting the pointer to NULL.
+rtems_status_code rtems_periph_api_remove_api(
+ rtems_gpio *pin
+#ifdef __cplusplus
+#endif /* LIBBSP_BSP_PERIPH_API_H */
diff --git a/bsps/shared/dev/gpio/gpio.c b/bsps/shared/dev/gpio/gpio.c
index 0000000000..295b9c3738
--- /dev/null
+++ b/bsps/shared/dev/gpio/gpio.c
@@ -0,0 +1,212 @@
+ * are met:
+#include <rtems/sysinit.h>
+ * @brief An array to store all registered GPIO controllers.
+static rtems_status_code (*get_gpio_table[CONFIGURE_GPIO_MAXIMUM_CONTROLLERS])(uint32_t, rtems_gpio **);
+static rtems_status_code (*destroy_gpio_table[CONFIGURE_GPIO_MAXIMUM_CONTROLLERS])(rtems_gpio *);
+ * @brief An array to store the boundaries of pin index of
+ * GPIO controllers.
+ * Example with 2 16-pin controllers and 1 32-pin controller,
+ * the pin_map will be:
+ * { 0, 16, 32, 64}
+ * Value 0 is always at index 0 for convenience of calculation.
+ * The length of this array is always 1+(number of controllers).
+static uint32_t pin_map[CONFIGURE_GPIO_MAXIMUM_CONTROLLERS+1] = {0};
+ * @brief The number of controllers registered.
+static uint32_t num_ctrl = 0;
+static uint32_t get_ctrl_index(
+ uint32_t i;
+ // TODO: binary search
+ for (i = 1; i <= num_ctrl; ++i) {
+ if (virtual_pin < pin_map[i]) {
+ break;
+ return i-1;
+rtems_status_code rtems_gpio_register(
+// rtems_interrupt_level level;
+ if (num_ctrl == CONFIGURE_GPIO_MAXIMUM_CONTROLLERS)
+ return RTEMS_TOO_MANY;
+// rtems_interrupt_disable(level);
+ get_gpio_table[num_ctrl] = get_gpio;
+ destroy_gpio_table[num_ctrl] = destroy_gpio;
+ rtems_periph_api_register_api(get_api, remove_api, num_ctrl);
+ pin_map[num_ctrl+1] = pin_map[num_ctrl] + pin_count;
+ ++num_ctrl;
+// rtems_interrupt_enable(level);
+ return RTEMS_SUCCESSFUL;
+rtems_status_code rtems_gpio_get(
+ rtems_gpio **out
+ uint32_t i = get_ctrl_index(virt_pin);
+ if (i >= num_ctrl)
+ return RTEMS_UNSATISFIED;
+ uint32_t pin = virt_pin - pin_map[i];
+ rtems_status_code sc = (*get_gpio_table[i])(pin, out);
+ if (sc == RTEMS_SUCCESSFUL) {
+ (*out)->virtual_pin = virt_pin;
+ return sc;
+rtems_status_code rtems_gpio_destroy(
+ rtems_gpio *base
+ uint32_t i = get_ctrl_index(base->virtual_pin);
+ return (*destroy_gpio_table[i])(base);
+void rtems_gpio_start(
+ void
+ rtems_periph_api_start(get_ctrl_index, &num_ctrl);
+ bsp_gpio_register_controllers();
+RTEMS_SYSINIT_ITEM(
+ rtems_gpio_start,
+ RTEMS_SYSINIT_DEVICE_DRIVERS,
+ RTEMS_SYSINIT_ORDER_LAST_BUT_1
+rtems_status_code rtems_gpio_set_pin_mode(
+ rtems_gpio *base,
+ return base->gpio_handlers->set_pin_mode(base, mode);
+rtems_status_code rtems_gpio_set_pull(
+ rtems_gpio *base,
+ return base->gpio_handlers->set_pull(base, pull);
+rtems_status_code rtems_gpio_configure_interrupt(
+ rtems_gpio *base,
+ void *arg,
+ return base->gpio_handlers->configure_interrupt(base, isr, arg, trig, pull);
+rtems_status_code rtems_gpio_remove_interrupt(
+ rtems_gpio *base
+ return base->gpio_handlers->remove_interrupt(base);
+rtems_status_code rtems_gpio_enable_interrupt(
+ rtems_gpio *base
+ return base->gpio_handlers->enable_interrupt(base);
+rtems_status_code rtems_gpio_disable_interrupt(
+ rtems_gpio *base
+ return base->gpio_handlers->disable_interrupt(base);
+rtems_status_code rtems_gpio_write(
+ rtems_gpio *base,
+ return base->gpio_handlers->write(base, value);
+rtems_status_code rtems_gpio_read(
+ rtems_gpio *base,
+ return base->gpio_handlers->read(base, value);
+rtems_status_code rtems_gpio_toggle(
+ rtems_gpio *base
+ return base->gpio_handlers->toggle(base);
diff --git a/bsps/shared/dev/periph_api/periph_api.c b/bsps/shared/dev/periph_api/periph_api.c
index 0000000000..4bc6b02939
--- /dev/null
+++ b/bsps/shared/dev/periph_api/periph_api.c
@@ -0,0 +1,101 @@
+ * are met:
+ * @brief An array to store handlers to get peripheral
+ * API of each registered GPIO controller.
+static rtems_periph_api *(*get_api_table[CONFIGURE_GPIO_MAXIMUM_CONTROLLERS])(rtems_gpio *, rtems_periph_api_type);
+ * @brief An array to store handlers to remove peripheral
+static rtems_status_code (*remove_api_table[CONFIGURE_GPIO_MAXIMUM_CONTROLLERS])(rtems_gpio *);
+ * Mirrors to GPIO private variables/
+static uint32_t (*get_ctrl_index_ptr)(uint32_t);
+static uint32_t *num_ctrl_ptr;
+ get_ctrl_index_ptr = get_ctrl_index;
+ num_ctrl_ptr = num_ctrl;
+ uint32_t index
+ get_api_table[index] = get_api;
+ remove_api_table[index] = remove_api;
+ rtems_gpio *pin,
+ // Prevent memory-leak by removing the old API
+ // first.
+ if (pin->api != NULL)
+ rtems_periph_api_remove_api(pin);
+ uint32_t i = (*get_ctrl_index_ptr)(pin->virtual_pin);
+ if (i >= *num_ctrl_ptr)
+ pin->api = (*get_api_table[i])(pin, type);
+ if (pin->api == NULL)
+ // Initialize the API object
+ pin->api->init(pin);
+ rtems_gpio *pin
+ return (*remove_api_table[i])(pin);
diff --git a/spec/build/bsps/obj.yml b/spec/build/bsps/obj.yml
index ce05c11c0e..80736c197d 100644
--- a/spec/build/bsps/obj.yml
+++ b/spec/build/bsps/obj.yml
@@ -16,7 +16,7 @@ install:
- bsps/include/bsp/default-initial-extension.h
- bsps/include/bsp/fatal.h
- bsps/include/bsp/fdt.h
- - bsps/include/bsp/gpio.h
+ - bsps/include/bsp/periph_api.h
- bsps/include/bsp/gpio2.h
- bsps/include/bsp/irq-default.h
- bsps/include/bsp/irq-generic.h
@@ -71,6 +71,8 @@ links:
- role: build-dependency
uid: objnosmp
source:
+- bsps/shared/dev/gpio/gpio.c
+- bsps/shared/dev/periph_api/periph_api.c
- bsps/shared/dev/display/disp_hcms29xx.c
- bsps/shared/dev/display/font_hcms29xx.c
- bsps/shared/dev/i2c/i2c-2b-eeprom.c
2.36.1
