[PATCH v5 1/4] bsps/stm32f4 Include STM32F4 HAL
oss at c-mauderer.de
Sun Jul 31 18:01:48 UTC 2022
Hello Duc,
Am 31.07.22 um 17:07 schrieb Duc Doan:
> Hello Christian,
> On Sat, 2022-07-30 at 16:32 +0200, oss at c-mauderer.de wrote:
>> Hello Duc,
>> general note for the patch: Please write in the commit message where
>> you
>> got the sources from. That can be a link to a github repo including a
>> commit ID or a link to the zip file from ST (including a date,
>> version
>> or similar information). If you moved some stuff around compared to
>> the
>> original structure: Please describe about what you did. For example
>> in
>> the imxrt I just added the cp commands that I used:
>> https://git.rtems.org/rtems/commit/bsps/arm/imxrt?id=48f6a6c302a3e1a3f8915e2503d0fe618d1af285
>> Not the best solution but at least someone else can find out roughly
>> what I did.
> Ah yes, I will do that. I thought I only needed to put the description
> in the email before.
>> Am 24.07.22 um 14:01 schrieb Duc Doan:
>>> This patch is too large so I cannot send via email. Please find it
>>> here:
>>> https://github.com/dtbpkmte/GSoC-2022-RTEMS/commit/6f1fbc7dd7a5e0877d8bff11e1b21558928dbc16
>>> .gitignore | 1 +
>> You added a "patches" directory to the gitignore. That looks like a
>> change that is specific to your method of working. These kind of
>> changes
>> should normall not be pushed.
>> If you want to ignore stuff specific to your work environment, I
>> recommend to use a global .gitignore file. Git has a
>> "core.excludesfile"
>> config for that.
> Thanks for the suggestion, I will fix that.
>>> bsps/arm/include/cmsis_compiler.h | 266 +
>>> bsps/arm/include/cmsis_gcc.h | 3460 +--
>>> bsps/arm/include/cmsis_version.h | 39 +
>>> bsps/arm/include/core_cm4.h | 524 +-
>>> bsps/arm/include/core_cm7.h | 5186 ++--
>>> bsps/arm/include/mpu_armv7.h | 270 +
>> Are the cmsis files from the same source or directly from ARM?
> They are from the same source (STM HAL v1.27.1).
>> The cmsis_gcc.h has a lot of changes compared to the earlier version
>> that has been present in RTEMS. A lot of the changes seem to be
>> whitespace changes. Can these be avoided somehow (for example by
>> using
>> dos2unix before overwriting the file)?
> From what I've just read about dos2unix, it converts line breaks from
> CRLF to LF (please correct me if I'm wrong). How will this command
> resolve the whitespace changes?
I haven't looked at the exact type of whitespace changes. I had the
impression that the difference is most likely only the line ending. It
didn't look like tab / space issue. Is it a tab / space issue?
>> In the discord chat there was one suggestion from Ho Kaido to move
>> the
>> files one level down and make them BSP specific. I'm not sure whether
>> I'm for or against that idea. Advantage is that it makes BSPs
>> independant from each other. Disadvantage is that it duplicates code.
>> I think I would try to avoid moving them down due to the code
>> duplication but it raises the question: Which BSPs use the files too
>> and
>> did you try whether they still compile after the upgrade?
> Until now I only know of STM32H7 BSP that is using the CMSIS files. I
> tried compiling it before and Karel also confirmed that the BSP
> compiles.
Just as an example: core_cm4/7.h is included at least in stm32f4,
stm32h7, atsam and imxrt. So we have to make sure that these three are
compile-clean. Please use grep to find out where the headers are
included and check whether I maybe missed a BSP.
>>> .../stm32f4/hal/Legacy/stm32f4xx_hal_can.c | 1679 ++
>>> .../stm32f4/hal/Legacy/stm32f4xx_hal_eth.c | 2307 ++
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal.c | 615 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_adc.c | 2110 ++
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_adc_ex.c | 1112 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_can.c | 2462 ++
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_cec.c | 996 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_cortex.c | 502 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_crc.c | 328 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_cryp.c | 7132 ++++++
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_cryp_ex.c | 680 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_dac.c | 1341 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_dac_ex.c | 495 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_dcmi.c | 1161 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_dcmi_ex.c | 182 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_dfsdm.c | 4423 ++++
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_dma.c | 1305 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_dma2d.c | 2126 ++
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_dma_ex.c | 313 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_dsi.c | 2760 +++
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_eth.c | 3220 +++
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_exti.c | 547 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_flash.c | 775 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_flash_ex.c | 1347 +
>>> .../stm32f4/hal/stm32f4xx_hal_flash_ramfunc.c | 172 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_fmpi2c.c | 6864 ++++++
>>> .../arm/stm32f4/hal/stm32f4xx_hal_fmpi2c_ex.c | 258 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_fmpsmbus.c | 2749 +++
>>> .../stm32f4/hal/stm32f4xx_hal_fmpsmbus_ex.c | 145 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_gpio.c | 533 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_hash.c | 3514 +++
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_hash_ex.c | 1040 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_hcd.c | 1728 ++
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_i2c.c | 7524 ++++++
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_i2c_ex.c | 182 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_i2s.c | 2094 ++
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_i2s_ex.c | 1135 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_irda.c | 2687 ++
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_iwdg.c | 262 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_lptim.c | 2484 ++
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_ltdc.c | 2215 ++
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_ltdc_ex.c | 151 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_mmc.c | 3201 +++
>>> .../stm32f4/hal/stm32f4xx_hal_msp_template.c | 100 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_nand.c | 2405 ++
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_nor.c | 1543 ++
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_pccard.c | 946 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_pcd.c | 2387 ++
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_pcd_ex.c | 341 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_pwr.c | 571 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_pwr_ex.c | 600 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_qspi.c | 2915 +++
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_rcc.c | 1122 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_rcc_ex.c | 3784 +++
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_rng.c | 867 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_rtc.c | 1896 ++
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_rtc_ex.c | 1878 ++
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_sai.c | 2554 ++
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_sai_ex.c | 310 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_sd.c | 3277 +++
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_sdram.c | 1308 +
>>> .../arm/stm32f4/hal/stm32f4xx_hal_smartcard.c | 2364 ++
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_smbus.c | 2784 +++
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_spdifrx.c | 1627 ++
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_spi.c | 3915 +++
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_sram.c | 1110 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_tim.c | 7621 ++++++
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_tim_ex.c | 2428 ++
>>> ...tm32f4xx_hal_timebase_rtc_alarm_template.c | 318 +
>>> ...m32f4xx_hal_timebase_rtc_wakeup_template.c | 293 +
>>> .../hal/stm32f4xx_hal_timebase_tim_template.c | 177 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_uart.c | 3751 +++
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_usart.c | 2838 +++
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_wwdg.c | 420 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_ll_adc.c | 922 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_ll_crc.c | 103 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_ll_dac.c | 280 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_ll_dma.c | 423 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_ll_dma2d.c | 594 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_ll_exti.c | 212 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_ll_fmc.c | 1498 ++
>>> bsps/arm/stm32f4/hal/stm32f4xx_ll_fmpi2c.c | 217 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_ll_fsmc.c | 1062 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_ll_gpio.c | 303 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_ll_i2c.c | 251 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_ll_lptim.c | 301 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_ll_pwr.c | 81 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_ll_rcc.c | 1660 ++
>>> bsps/arm/stm32f4/hal/stm32f4xx_ll_rng.c | 111 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_ll_rtc.c | 838 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_ll_sdmmc.c | 1578 ++
>>> bsps/arm/stm32f4/hal/stm32f4xx_ll_spi.c | 624 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_ll_tim.c | 1189 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_ll_usart.c | 500 +
>>> bsps/arm/stm32f4/hal/stm32f4xx_ll_usb.c | 2224 ++
>>> bsps/arm/stm32f4/hal/stm32f4xx_ll_utils.c | 749 +
>>> bsps/arm/stm32f4/hal/system_stm32f4xx.c | 747 +
>>> .../stm32f4/include/Legacy/stm32_hal_legacy.h | 4014 +++
>>> .../include/Legacy/stm32f4xx_hal_can_legacy.h | 765 +
>>> .../include/Legacy/stm32f4xx_hal_eth_legacy.h | 2209 ++
>>> bsps/arm/stm32f4/include/bsp.h | 4 +
>>> bsps/arm/stm32f4/include/bsp/io.h | 4 +
>>> bsps/arm/stm32f4/include/stm32f401xc.h | 8641 +++++++
>>> bsps/arm/stm32f4/include/stm32f401xe.h | 8641 +++++++
>>> bsps/arm/stm32f4/include/stm32f405xx.h | 14310 +++++++++++
>>> bsps/arm/stm32f4/include/stm32f407xx.h | 15607
>>> bsps/arm/stm32f4/include/stm32f410cx.h | 7357 ++++++
>>> bsps/arm/stm32f4/include/stm32f410rx.h | 7361 ++++++
>>> bsps/arm/stm32f4/include/stm32f410tx.h | 7306 ++++++
>>> bsps/arm/stm32f4/include/stm32f411xe.h | 8680 +++++++
>>> bsps/arm/stm32f4/include/stm32f412cx.h | 13507 ++++++++++
>>> bsps/arm/stm32f4/include/stm32f412rx.h | 14500 +++++++++++
>>> bsps/arm/stm32f4/include/stm32f412vx.h | 14512 +++++++++++
>>> bsps/arm/stm32f4/include/stm32f412zx.h | 14537 +++++++++++
>>> bsps/arm/stm32f4/include/stm32f413xx.h | 15462
>>> bsps/arm/stm32f4/include/stm32f415xx.h | 14595 +++++++++++
>>> bsps/arm/stm32f4/include/stm32f417xx.h | 15887
>>> bsps/arm/stm32f4/include/stm32f423xx.h | 15615
>>> bsps/arm/stm32f4/include/stm32f427xx.h | 16827
>>> bsps/arm/stm32f4/include/stm32f429xx.h | 17185
>>> bsps/arm/stm32f4/include/stm32f437xx.h | 17129
>>> bsps/arm/stm32f4/include/stm32f439xx.h | 17479
>>> bsps/arm/stm32f4/include/stm32f446xx.h | 15981
>>> bsps/arm/stm32f4/include/stm32f469xx.h | 20278
>>> bsps/arm/stm32f4/include/stm32f479xx.h | 20575
>>> bsps/arm/stm32f4/include/stm32f4xx.h | 305 +
>>> bsps/arm/stm32f4/include/stm32f4xx_hal.h | 297 +
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_adc.h | 898 +
>>> .../stm32f4/include/stm32f4xx_hal_adc_ex.h | 407 +
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_can.h | 844 +
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_cec.h | 792 +
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_conf.h | 506 +
>>> .../stm32f4/include/stm32f4xx_hal_cortex.h | 407 +
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_crc.h | 181 +
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_cryp.h | 683 +
>>> .../stm32f4/include/stm32f4xx_hal_cryp_ex.h | 142 +
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_dac.h | 480 +
>>> .../stm32f4/include/stm32f4xx_hal_dac_ex.h | 205 +
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_dcmi.h | 563 +
>>> .../stm32f4/include/stm32f4xx_hal_dcmi_ex.h | 208 +
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_def.h | 210 +
>>> .../arm/stm32f4/include/stm32f4xx_hal_dfsdm.h | 1141 +
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_dma.h | 802 +
>>> .../arm/stm32f4/include/stm32f4xx_hal_dma2d.h | 638 +
>>> .../stm32f4/include/stm32f4xx_hal_dma_ex.h | 102 +
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_dsi.h | 1377 ++
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_eth.h | 2144 ++
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_exti.h | 366 +
>>> .../arm/stm32f4/include/stm32f4xx_hal_flash.h | 425 +
>>> .../stm32f4/include/stm32f4xx_hal_flash_ex.h | 1063 +
>>> .../include/stm32f4xx_hal_flash_ramfunc.h | 76 +
>>> .../stm32f4/include/stm32f4xx_hal_fmpi2c.h | 837 +
>>> .../stm32f4/include/stm32f4xx_hal_fmpi2c_ex.h | 150 +
>>> .../stm32f4/include/stm32f4xx_hal_fmpsmbus.h | 790 +
>>> .../include/stm32f4xx_hal_fmpsmbus_ex.h | 136 +
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_gpio.h | 325 +
>>> .../stm32f4/include/stm32f4xx_hal_gpio_ex.h | 1590 ++
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_hash.h | 634 +
>>> .../stm32f4/include/stm32f4xx_hal_hash_ex.h | 175 +
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_hcd.h | 316 +
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_i2c.h | 741 +
>>> .../stm32f4/include/stm32f4xx_hal_i2c_ex.h | 115 +
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_i2s.h | 618 +
>>> .../stm32f4/include/stm32f4xx_hal_i2s_ex.h | 183 +
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_irda.h | 682 +
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_iwdg.h | 220 +
>>> .../arm/stm32f4/include/stm32f4xx_hal_lptim.h | 857 +
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_ltdc.h | 719 +
>>> .../stm32f4/include/stm32f4xx_hal_ltdc_ex.h | 83 +
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_mmc.h | 747 +
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_nand.h | 388 +
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_nor.h | 330 +
>>> .../stm32f4/include/stm32f4xx_hal_pccard.h | 285 +
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_pcd.h | 459 +
>>> .../stm32f4/include/stm32f4xx_hal_pcd_ex.h | 88 +
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_pwr.h | 427 +
>>> .../stm32f4/include/stm32f4xx_hal_pwr_ex.h | 340 +
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_qspi.h | 750 +
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_rcc.h | 1459 ++
>>> .../stm32f4/include/stm32f4xx_hal_rcc_ex.h | 7111 ++++++
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_rng.h | 361 +
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_rtc.h | 915 +
>>> .../stm32f4/include/stm32f4xx_hal_rtc_ex.h | 1079 +
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_sai.h | 895 +
>>> .../stm32f4/include/stm32f4xx_hal_sai_ex.h | 114 +
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_sd.h | 758 +
>>> .../arm/stm32f4/include/stm32f4xx_hal_sdram.h | 238 +
>>> .../stm32f4/include/stm32f4xx_hal_smartcard.h | 755 +
>>> .../arm/stm32f4/include/stm32f4xx_hal_smbus.h | 731 +
>>> .../stm32f4/include/stm32f4xx_hal_spdifrx.h | 604 +
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_spi.h | 729 +
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_sram.h | 236 +
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_tim.h | 2146 ++
>>> .../stm32f4/include/stm32f4xx_hal_tim_ex.h | 354 +
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_uart.h | 884 +
>>> .../arm/stm32f4/include/stm32f4xx_hal_usart.h | 648 +
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_wwdg.h | 298 +
>>> bsps/arm/stm32f4/include/stm32f4xx_ll_adc.h | 4779 ++++
>>> bsps/arm/stm32f4/include/stm32f4xx_ll_bus.h | 2105 ++
>>> .../arm/stm32f4/include/stm32f4xx_ll_cortex.h | 637 +
>>> bsps/arm/stm32f4/include/stm32f4xx_ll_crc.h | 201 +
>>> bsps/arm/stm32f4/include/stm32f4xx_ll_dac.h | 1455 ++
>>> bsps/arm/stm32f4/include/stm32f4xx_ll_dma.h | 2868 +++
>>> bsps/arm/stm32f4/include/stm32f4xx_ll_dma2d.h | 1901 ++
>>> bsps/arm/stm32f4/include/stm32f4xx_ll_exti.h | 954 +
>>> bsps/arm/stm32f4/include/stm32f4xx_ll_fmc.h | 1416 ++
>>> .../arm/stm32f4/include/stm32f4xx_ll_fmpi2c.h | 2234 ++
>>> bsps/arm/stm32f4/include/stm32f4xx_ll_fsmc.h | 1086 +
>>> bsps/arm/stm32f4/include/stm32f4xx_ll_gpio.h | 981 +
>>> bsps/arm/stm32f4/include/stm32f4xx_ll_i2c.h | 1890 ++
>>> bsps/arm/stm32f4/include/stm32f4xx_ll_iwdg.h | 302 +
>>> bsps/arm/stm32f4/include/stm32f4xx_ll_lptim.h | 1378 ++
>>> bsps/arm/stm32f4/include/stm32f4xx_ll_pwr.h | 985 +
>>> bsps/arm/stm32f4/include/stm32f4xx_ll_rcc.h | 7096 ++++++
>>> bsps/arm/stm32f4/include/stm32f4xx_ll_rng.h | 335 +
>>> bsps/arm/stm32f4/include/stm32f4xx_ll_rtc.h | 3663 +++
>>> bsps/arm/stm32f4/include/stm32f4xx_ll_sdmmc.h | 1141 +
>>> bsps/arm/stm32f4/include/stm32f4xx_ll_spi.h | 2027 ++
>>> .../arm/stm32f4/include/stm32f4xx_ll_system.h | 1711 ++
>>> bsps/arm/stm32f4/include/stm32f4xx_ll_tim.h | 4093 +++
>>> bsps/arm/stm32f4/include/stm32f4xx_ll_usart.h | 2521 ++
>>> bsps/arm/stm32f4/include/stm32f4xx_ll_usb.h | 536 +
>>> bsps/arm/stm32f4/include/stm32f4xx_ll_utils.h | 307 +
>>> bsps/arm/stm32f4/include/stm32f4xx_ll_wwdg.h | 316 +
>>> bsps/arm/stm32f4/include/system_stm32f4xx.h | 104 +
>> You most likely noted the long discussion on Discord between Andrei
>> of
>> the North and me regarding how the hal could be made more
>> application-friendly. @Andrei: Do you think the headers should be
>> moved
>> into a subdirectory to make them simpler to avoid in the application?
>>> bsps/arm/stm32f4/start/bspstart.c | 202 +-
>>> bsps/arm/stm32f4/start/bspstart_old.c | 297 +
>>> spec/build/bsps/arm/grp.yml | 5 +-
>>> spec/build/bsps/arm/stm32f4/grp.yml | 12 +-
>>> spec/build/bsps/arm/stm32f4/obj.yml | 220 +
>>> spec/build/bsps/arm/stm32f4/optenhal.yml | 16 +
>>> spec/build/bsps/arm/stm32f4/opthse.yml | 17 +
>>> spec/build/bsps/arm/stm32f4/optusehse.yml | 16 +
>>> spec/build/bsps/arm/stm32f4/optvariant.yml | 24 +
>>> spec/build/bsps/obj.yml | 1 +
>> Did the HAL files compile completely without change? If yes, it is OK
>> if
>> you add them to the yml file right here. Otherwise I would suggest to
>> make two to three smaller steps:
>> - Add the unchanged files. Don't add them to the build yet so that
>> the
>> commit would still compile without problems.
>> - Add necessary changes.
>> - Add the files to the build.
>> That makes it simpler to find out what you might had to change to
>> make
>> the files compile and port the changes to a newer version.
> The HAL files compile completely without changes. However, in one file
> (stm32f4xx.h), I included bspopts.h. I can split it into 2 commits.
Would be great if you could split that.
Best regards
Christian
> Best,
> Duc
>> Best regards
>> Christian
>>> 242 files changed, 586809 insertions(+), 4072 deletions(-)
>>> create mode 100644 bsps/arm/include/cmsis_compiler.h
>>> create mode 100644 bsps/arm/include/cmsis_version.h
>>> create mode 100644 bsps/arm/include/mpu_armv7.h
>>> create mode 100644
>>> bsps/arm/stm32f4/hal/Legacy/stm32f4xx_hal_can.c
>>> create mode 100644
>>> bsps/arm/stm32f4/hal/Legacy/stm32f4xx_hal_eth.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_adc.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_adc_ex.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_can.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_cec.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_cortex.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_crc.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_cryp.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_cryp_ex.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dac.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dac_ex.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dcmi.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dcmi_ex.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dfsdm.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dma.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dma2d.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dma_ex.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dsi.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_eth.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_exti.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_flash.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_flash_ex.c
>>> create mode 100644
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_flash_ramfunc.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_fmpi2c.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_fmpi2c_ex.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_fmpsmbus.c
>>> create mode 100644
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_fmpsmbus_ex.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_gpio.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_hash.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_hash_ex.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_hcd.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_i2c.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_i2c_ex.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_i2s.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_i2s_ex.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_irda.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_iwdg.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_lptim.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_ltdc.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_ltdc_ex.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_mmc.c
>>> create mode 100644
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_msp_template.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_nand.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_nor.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_pccard.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_pcd.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_pcd_ex.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_pwr.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_pwr_ex.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_qspi.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_rcc.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_rcc_ex.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_rng.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_rtc.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_rtc_ex.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_sai.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_sai_ex.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_sd.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_sdram.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_smartcard.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_smbus.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_spdifrx.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_spi.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_sram.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_tim.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_tim_ex.c
>>> create mode 100644
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_timebase_rtc_alarm_template.c
>>> create mode 100644
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_timebase_rtc_wakeup_template.c
>>> create mode 100644
>>> bsps/arm/stm32f4/hal/stm32f4xx_hal_timebase_tim_template.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_uart.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_usart.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_wwdg.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_adc.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_crc.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_dac.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_dma.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_dma2d.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_exti.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_fmc.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_fmpi2c.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_fsmc.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_gpio.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_i2c.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_lptim.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_pwr.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_rcc.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_rng.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_rtc.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_sdmmc.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_spi.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_tim.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_usart.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_usb.c
>>> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_utils.c
>>> create mode 100644 bsps/arm/stm32f4/hal/system_stm32f4xx.c
>>> create mode 100644
>>> bsps/arm/stm32f4/include/Legacy/stm32_hal_legacy.h
>>> create mode 100644
>>> bsps/arm/stm32f4/include/Legacy/stm32f4xx_hal_can_legacy.h
>>> create mode 100644
>>> bsps/arm/stm32f4/include/Legacy/stm32f4xx_hal_eth_legacy.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f401xc.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f401xe.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f405xx.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f407xx.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f410cx.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f410rx.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f410tx.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f411xe.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f412cx.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f412rx.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f412vx.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f412zx.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f413xx.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f415xx.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f417xx.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f423xx.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f427xx.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f429xx.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f437xx.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f439xx.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f446xx.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f469xx.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f479xx.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_adc.h
>>> create mode 100644
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_adc_ex.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_can.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_cec.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_conf.h
>>> create mode 100644
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_cortex.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_crc.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_cryp.h
>>> create mode 100644
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_cryp_ex.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_dac.h
>>> create mode 100644
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_dac_ex.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_dcmi.h
>>> create mode 100644
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_dcmi_ex.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_def.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_dfsdm.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_dma.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_dma2d.h
>>> create mode 100644
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_dma_ex.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_dsi.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_eth.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_exti.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_flash.h
>>> create mode 100644
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_flash_ex.h
>>> create mode 100644
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_flash_ramfunc.h
>>> create mode 100644
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_fmpi2c.h
>>> create mode 100644
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_fmpi2c_ex.h
>>> create mode 100644
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_fmpsmbus.h
>>> create mode 100644
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_fmpsmbus_ex.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_gpio.h
>>> create mode 100644
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_gpio_ex.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_hash.h
>>> create mode 100644
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_hash_ex.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_hcd.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_i2c.h
>>> create mode 100644
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_i2c_ex.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_i2s.h
>>> create mode 100644
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_i2s_ex.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_irda.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_iwdg.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_lptim.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_ltdc.h
>>> create mode 100644
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_ltdc_ex.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_mmc.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_nand.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_nor.h
>>> create mode 100644
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_pccard.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_pcd.h
>>> create mode 100644
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_pcd_ex.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_pwr.h
>>> create mode 100644
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_pwr_ex.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_qspi.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_rcc.h
>>> create mode 100644
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_rcc_ex.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_rng.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_rtc.h
>>> create mode 100644
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_rtc_ex.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_sai.h
>>> create mode 100644
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_sai_ex.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_sd.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_sdram.h
>>> create mode 100644
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_smartcard.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_smbus.h
>>> create mode 100644
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_spdifrx.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_spi.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_sram.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_tim.h
>>> create mode 100644
>>> bsps/arm/stm32f4/include/stm32f4xx_hal_tim_ex.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_uart.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_usart.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_wwdg.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_adc.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_bus.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_cortex.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_crc.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_dac.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_dma.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_dma2d.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_exti.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_fmc.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_fmpi2c.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_fsmc.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_gpio.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_i2c.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_iwdg.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_lptim.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_pwr.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_rcc.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_rng.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_rtc.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_sdmmc.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_spi.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_system.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_tim.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_usart.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_usb.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_utils.h
>>> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_wwdg.h
>>> create mode 100644 bsps/arm/stm32f4/include/system_stm32f4xx.h
>>> create mode 100644 bsps/arm/stm32f4/start/bspstart_old.c
>>> create mode 100644 spec/build/bsps/arm/stm32f4/optenhal.yml
>>> create mode 100644 spec/build/bsps/arm/stm32f4/opthse.yml
>>> create mode 100644 spec/build/bsps/arm/stm32f4/optusehse.yml
>>> create mode 100644 spec/build/bsps/arm/stm32f4/optvariant.yml
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
