[PATCH 2/2] sptests/spstdc17: New test
Sebastian Huber
Mon Jul 25 08:02:54 UTC 2022
spec/build/testsuites/sptests/grp.yml | 2 +
spec/build/testsuites/sptests/spstdc17.yml | 22 +++++++++
testsuites/sptests/spstdc17/init.c | 57 ++++++++++++++++++++++
testsuites/sptests/spstdc17/spstdc17.doc | 12 +++++
4 files changed, 93 insertions(+)
create mode 100644 spec/build/testsuites/sptests/spstdc17.yml
create mode 100644 testsuites/sptests/spstdc17/init.c
create mode 100644 testsuites/sptests/spstdc17/spstdc17.doc
diff --git a/spec/build/testsuites/sptests/grp.yml b/spec/build/testsuites/sptests/grp.yml
index 891a78eb86..c8f70ed13b 100644
--- a/spec/build/testsuites/sptests/grp.yml
+++ b/spec/build/testsuites/sptests/grp.yml
@@ -394,6 +394,8 @@ links:
uid: spsimplesched03
- role: build-dependency
uid: spsize
+- role: build-dependency
+ uid: spstdc17
uid: spstdthreads01
diff --git a/spec/build/testsuites/sptests/spstdc17.yml b/spec/build/testsuites/sptests/spstdc17.yml
new file mode 100644
index 0000000000..8c60b0a7fb
--- /dev/null
+++ b/spec/build/testsuites/sptests/spstdc17.yml
@@ -0,0 +1,22 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags:
+- -std=c17
+- -pedantic
+- -Wextra
+copyrights:
+- Copyright (C) 2022 embedded brains GmbH (http://www.embedded-brains.de)
+cppflags: []
+cxxflags: []
+enabled-by: true
+features: c cprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/sptests/spstdc17/init.c
+stlib: []
+target: testsuites/sptests/spstdc17.exe
+type: build
+use-after: []
+use-before: []
diff --git a/testsuites/sptests/spstdc17/init.c b/testsuites/sptests/spstdc17/init.c
index 0000000000..0a1a5571ac
--- /dev/null
+++ b/testsuites/sptests/spstdc17/init.c
@@ -0,0 +1,57 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2022
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems.h>
+#include <tmacros.h>
+const char rtems_test_name[] = "SPSTDC17";
+static rtems_task Init( rtems_task_argument arg )
+ (void) arg;
+ TEST_BEGIN();
+ TEST_END();
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/sptests/spstdc17/spstdc17.doc b/testsuites/sptests/spstdc17/spstdc17.doc
index 0000000000..7f83fd9ad3
--- /dev/null
+++ b/testsuites/sptests/spstdc17/spstdc17.doc
@@ -0,0 +1,12 @@
+This file describes the directives and concepts tested by this test set.
+test set name: spstdc17
+directives:
+ - Header file <rtems.h>
+ - Header file <rtems/confdefs.h>
+concepts:
+ - Ensure that the API header files are compatible with the C17 standard.
2.35.3
