[PATCH 1/2] imfs: Add <rtems/imfsimpl.h>
Mon Jul 25 08:02:53 UTC 2022
 cpukit/include/rtems/imfs.h                   | 38 +-------
 cpukit/include/rtems/imfsimpl.h               | 92 +++++++++++++++++++
 cpukit/libfs/src/imfs/imfs_add_node.c         |  2 +-
 cpukit/libfs/src/imfs/imfs_chown.c            |  2 +-
 cpukit/libfs/src/imfs/imfs_fchmod.c           |  2 +-
 cpukit/libfs/src/imfs/imfs_fifo.c             |  2 +-
 cpukit/libfs/src/imfs/imfs_linfile.c          |  2 +-
 cpukit/libfs/src/imfs/imfs_link.c             |  2 +-
 .../libfs/src/imfs/imfs_make_generic_node.c   |  2 +-
 cpukit/libfs/src/imfs/imfs_memfile.c          |  2 +-
 cpukit/libfs/src/imfs/imfs_mknod.c            |  2 +-
 cpukit/libfs/src/imfs/imfs_node.c             |  2 +-
 cpukit/libfs/src/imfs/imfs_rename.c           |  2 +-
 spec/build/cpukit/librtemscpu.yml             |  1 +
 14 files changed, 105 insertions(+), 48 deletions(-)
 create mode 100644 cpukit/include/rtems/imfsimpl.h
diff --git a/cpukit/include/rtems/imfs.h b/cpukit/include/rtems/imfs.h
index 57c498cfe8..7db9b4e462 100644
--- a/cpukit/include/rtems/imfs.h
+++ b/cpukit/include/rtems/imfs.h
@@ -3,7 +3,7 @@
  * @file
- * @brief Header File for the In-Memory File System
+ * @brief This header file defines the API of the In-Memory File System.
@@ -39,7 +39,6 @@
 #include <rtems/libio_.h>
 #include <rtems/pipe.h>
-#include <rtems/score/timecounter.h>
  * @brief In-Memory File System Support.
@@ -372,41 +371,6 @@ static inline IMFS_memfile_t *IMFS_iop_to_memfile( const rtems_libio_t *iop )
   return (IMFS_memfile_t *) iop->pathinfo.node_access;
-static inline time_t _IMFS_get_time( void )
-  struct bintime now;
-  /* Use most efficient way to get the time in seconds (CLOCK_REALTIME) */
-  _Timecounter_Getbintime( &now );
-  return now.sec;
-static inline void IMFS_update_atime( IMFS_jnode_t *jnode )
-  jnode->stat_atime = _IMFS_get_time();
-static inline void IMFS_update_mtime( IMFS_jnode_t *jnode )
-  jnode->stat_mtime = _IMFS_get_time();
-static inline void IMFS_update_ctime( IMFS_jnode_t *jnode )
-  jnode->stat_ctime = _IMFS_get_time();
-static inline void IMFS_mtime_ctime_update( IMFS_jnode_t *jnode )
-  time_t now;
-  now = _IMFS_get_time();
-  jnode->stat_mtime = now;
-  jnode->stat_ctime = now;
 typedef struct {
   const IMFS_mknod_control *directory;
   const IMFS_mknod_control *device;
diff --git a/cpukit/include/rtems/imfsimpl.h b/cpukit/include/rtems/imfsimpl.h
new file mode 100644
index 0000000000..db1ae32af7
--- /dev/null
+++ b/cpukit/include/rtems/imfsimpl.h
@@ -0,0 +1,92 @@
+ * @file
+ * @brief This header file contains interfaces used by the implementation of
+ *   the In-Memory File System.
+ * Copyright (C) 2013, 2018 embedded brains GmbH
+ * are met:
+#ifndef _RTEMS_IMFSIMPL_H
+#define _RTEMS_IMFSIMPL_H
+#include <rtems/imfs.h>
+#include <rtems/score/timecounter.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @addtogroup IMFS
+static inline time_t _IMFS_get_time( void )
+  struct bintime now;
+  /* Use most efficient way to get the time in seconds (CLOCK_REALTIME) */
+  _Timecounter_Getbintime( &now );
+  return now.sec;
+static inline void IMFS_update_atime( IMFS_jnode_t *jnode )
+  jnode->stat_atime = _IMFS_get_time();
+static inline void IMFS_update_mtime( IMFS_jnode_t *jnode )
+  jnode->stat_mtime = _IMFS_get_time();
+static inline void IMFS_update_ctime( IMFS_jnode_t *jnode )
+  jnode->stat_ctime = _IMFS_get_time();
+static inline void IMFS_mtime_ctime_update( IMFS_jnode_t *jnode )
+  time_t now;
+  now = _IMFS_get_time();
+  jnode->stat_mtime = now;
+  jnode->stat_ctime = now;
+#ifdef __cplusplus
+#endif
+#endif /* _RTEMS_IMFSIMPL_H */
diff --git a/cpukit/libfs/src/imfs/imfs_add_node.c b/cpukit/libfs/src/imfs/imfs_add_node.c
index 814736284d..d12ed03077 100644
--- a/cpukit/libfs/src/imfs/imfs_add_node.c
+++ b/cpukit/libfs/src/imfs/imfs_add_node.c
@@ -37,7 +37,7 @@
 #include "config.h"
 #endif
-#include <rtems/imfs.h>
+#include <rtems/imfsimpl.h>
 int IMFS_add_node( const char *path, IMFS_jnode_t *node, void *arg )
diff --git a/cpukit/libfs/src/imfs/imfs_chown.c b/cpukit/libfs/src/imfs/imfs_chown.c
index 5a0049ba2d..20210470a1 100644
--- a/cpukit/libfs/src/imfs/imfs_chown.c
+++ b/cpukit/libfs/src/imfs/imfs_chown.c
@@ -38,7 +38,7 @@
 #include "config.h"
 #endif
 #include <unistd.h>
diff --git a/cpukit/libfs/src/imfs/imfs_fchmod.c b/cpukit/libfs/src/imfs/imfs_fchmod.c
index 7f885a1987..6f6c57ff23 100644
--- a/cpukit/libfs/src/imfs/imfs_fchmod.c
+++ b/cpukit/libfs/src/imfs/imfs_fchmod.c
@@ -38,7 +38,7 @@
 #include "config.h"
 #endif
 int IMFS_fchmod(
   const rtems_filesystem_location_info_t *loc,
diff --git a/cpukit/libfs/src/imfs/imfs_fifo.c b/cpukit/libfs/src/imfs/imfs_fifo.c
index a3154e18bd..be86187663 100644
--- a/cpukit/libfs/src/imfs/imfs_fifo.c
+++ b/cpukit/libfs/src/imfs/imfs_fifo.c
@@ -37,7 +37,7 @@
 #include "config.h"
 #endif
 #include <sys/filio.h>
diff --git a/cpukit/libfs/src/imfs/imfs_linfile.c b/cpukit/libfs/src/imfs/imfs_linfile.c
index 4f961d19e8..c9b1ec9e90 100644
--- a/cpukit/libfs/src/imfs/imfs_linfile.c
+++ b/cpukit/libfs/src/imfs/imfs_linfile.c
@@ -38,7 +38,7 @@
 static ssize_t IMFS_linfile_read(
   rtems_libio_t *iop,
diff --git a/cpukit/libfs/src/imfs/imfs_link.c b/cpukit/libfs/src/imfs/imfs_link.c
index 301a280211..3ea05b0807 100644
--- a/cpukit/libfs/src/imfs/imfs_link.c
+++ b/cpukit/libfs/src/imfs/imfs_link.c
@@ -38,7 +38,7 @@
 #include "config.h"
 #endif
 static const IMFS_node_control IMFS_node_control_hard_link;
diff --git a/cpukit/libfs/src/imfs/imfs_make_generic_node.c b/cpukit/libfs/src/imfs/imfs_make_generic_node.c
index abecf5ec53..23beee431d 100644
--- a/cpukit/libfs/src/imfs/imfs_make_generic_node.c
+++ b/cpukit/libfs/src/imfs/imfs_make_generic_node.c
@@ -37,7 +37,7 @@
 #include "config.h"
 #endif
diff --git a/cpukit/libfs/src/imfs/imfs_memfile.c b/cpukit/libfs/src/imfs/imfs_memfile.c
index 769a570ecf..66c67c6ba0 100644
--- a/cpukit/libfs/src/imfs/imfs_memfile.c
+++ b/cpukit/libfs/src/imfs/imfs_memfile.c
@@ -38,7 +38,7 @@
 #include "config.h"
 #endif
diff --git a/cpukit/libfs/src/imfs/imfs_mknod.c b/cpukit/libfs/src/imfs/imfs_mknod.c
index 17aa1d3802..cd027fe7f6 100644
--- a/cpukit/libfs/src/imfs/imfs_mknod.c
+++ b/cpukit/libfs/src/imfs/imfs_mknod.c
@@ -41,7 +41,7 @@
 #include "config.h"
 #endif
 static const IMFS_mknod_control *get_control(
   const IMFS_mknod_controls *controls,
diff --git a/cpukit/libfs/src/imfs/imfs_node.c b/cpukit/libfs/src/imfs/imfs_node.c
index 91bd89d66c..10e9e72d01 100644
--- a/cpukit/libfs/src/imfs/imfs_node.c
+++ b/cpukit/libfs/src/imfs/imfs_node.c
@@ -41,7 +41,7 @@
 #include "config.h"
 #endif
 IMFS_jnode_t *IMFS_initialize_node(
   IMFS_jnode_t *node,
diff --git a/cpukit/libfs/src/imfs/imfs_rename.c b/cpukit/libfs/src/imfs/imfs_rename.c
index d925591b32..94876d9217 100644
--- a/cpukit/libfs/src/imfs/imfs_rename.c
+++ b/cpukit/libfs/src/imfs/imfs_rename.c
@@ -38,7 +38,7 @@
 #include "config.h"
 #endif
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index f89d2c0eac..e8a9da3e50 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -110,6 +110,7 @@ install:
   - cpukit/include/rtems/fsmount.h
   - cpukit/include/rtems/ide_part_table.h
   - cpukit/include/rtems/imfs.h
+  - cpukit/include/rtems/imfsimpl.h
   - cpukit/include/rtems/init.h
   - cpukit/include/rtems/inttypes.h
   - cpukit/include/rtems/io.h
2.35.3
