[tools v2] tester: Normalize JSON and YAML reports
Wed Jul 27 02:45:02 UTC 2022
OK and thanks.
On 26/7/2022 10:10 pm, Sebastian Huber wrote:
> Report the same data in JSON and YAML reports.  Do not report redundant
> information.
> Update 4671.
> v2:
> * Add 'report-version' attribute with a value of 1.
> * Add 'tester-version' attribute.
> * Use a list for both 'command-line' attributes.
>  tester/rt/test.py | 193 ++++++++++------------------------------------
>  1 file changed, 42 insertions(+), 151 deletions(-)
> diff --git a/tester/rt/test.py b/tester/rt/test.py
> index 113936c..a13b40a 100644
> --- a/tester/rt/test.py
> +++ b/tester/rt/test.py
> @@ -218,76 +218,48 @@ def killall(tests):
>          test.kill()
> +def results_to_data(args, reports, start_time, end_time):
> +    data = {}
> +    data['report-version'] = 1
> +    data['tester-version'] = version.string()
> +    data['command-line'] = args
> +    data['host'] = host.label(mode='all')
> +    data['python'] = sys.version.replace('\n', '')
> +    data['start-time'] = start_time.isoformat()
> +    data['end-time'] = start_time.isoformat()
> +    reports_data = []
> +    for name, run in reports.results.items():
> +        run_data = {}
> +        result = run['result']
> +        run_data['result'] = result
> +        output = []
> +        for line in run['output']:
> +            if line.startswith('] '):
> +                output.append(line[2:])
> +            elif line.startswith('=>  exe:'):
> +                run_data['command-line'] = line[9:].split()
> +        run_data['output'] = output
> +        run_data['executable'] = name
> +        run_data['executable-sha512'] = get_hash512(name)
> +        run_data['start-time'] = run['start'].isoformat()
> +        run_data['end-time'] = run['end'].isoformat()
> +        run_data['bsp'] = run['bsp']
> +        run_data['arch'] = run['bsp_arch']
> +        reports_data.append(run_data)
> +    data['reports'] = reports_data
> +    return data
>  def generate_json_report(args, reports, start_time, end_time,
> -                         total, json_file):
> +                         _total, json_file):
>      import json
> -    import sys
> -    json_log = {}
> -    json_log['Command Line'] = " ".join(args)
> -    json_log['Python'] = sys.version.replace('\n', '')
> -    json_log['test_groups'] = []
> -    json_log['Host'] = host.label(mode='all')
> -    json_log['summary'] = {}
> -    json_log['summary']['passed_count'] = reports.passed
> -    json_log['summary']['failed_count'] = reports.failed
> -    json_log['summary']['user-input_count'] = reports.user_input
> -    json_log['summary']['expected-fail_count'] = reports.expected_fail
> -    json_log['summary']['indeterminate_count'] = reports.indeterminate
> -    json_log['summary']['benchmark_count'] = reports.benchmark
> -    json_log['summary']['timeout_count'] = reports.timeouts
> -    json_log['summary']['test-too-long_count'] = reports.test_too_long
> -    json_log['summary']['invalid_count'] = reports.invalids
> -    json_log['summary']['wrong-version_count'] = reports.wrong_version
> -    json_log['summary']['wrong-build_count'] = reports.wrong_build
> -    json_log['summary']['wrong-tools_count'] = reports.wrong_tools
> -    json_log['summary']['invalid-header_count'] = reports.wrong_header
> -    json_log['summary']['total_count'] = reports.total
> -    time_delta = end_time - start_time
> -    json_log['summary']['average_test_time'] = str(time_delta / total)
> -    json_log['summary']['testing_time'] = str(time_delta)
> -    result_types = [
> -            'failed', 'user-input', 'expected-fail', 'indeterminate',
> -            'benchmark', 'timeout', 'test-too-long', 'invalid', 'wrong-version',
> -            'wrong-build', 'wrong-tools', 'wrong-header'
> -    json_results = {}
> -    for result_type in result_types:
> -        json_log['summary'][result_type] = []
> -    # collate results for JSON log
> -    for name in reports.results:
> -        result_type = reports.results[name]['result']
> -        # map fatal-error on to failed since the report adds both to the failed count
> -        if result_type == "fatal-error":
> -            result_type = "failed"
> -        test_parts = name.split("/")
> -        test_category = test_parts[-2]
> -        test_name = test_parts[-1]
> -        if result_type != 'passed':
> -            json_log['summary'][result_type].append(test_name)
> -        if test_category not in json_results:
> -            json_results[test_category] = []
> -        json_result = {}
> -        # remove the file extension
> -        json_result["name"] = test_name.split('.')[0]
> -        json_result["result"] = result_type
> -        if result_type == "failed" or result_type == "timeout":
> -            json_result["output"] = reports.results[name]["output"]
> -        json_results[test_category].append(json_result)
> -    # convert results to a better format for report generation
> -    sorted_keys = sorted(json_results.keys())
> -    for i in range(len(sorted_keys)):
> -        results_log = {}
> -        results_log["index"] = i + 1
> -        results_log["name"] = sorted_keys[i]
> -        results_log["results"] = json_results[sorted_keys[i]]
> -        json_log["test_groups"].append(results_log)
> -    # write out JSON log
> +    data = results_to_data(args, reports, start_time, end_time);
>      with open(json_file, 'w') as outfile:
> -        json.dump(json_log, outfile, sort_keys=True, indent=4)
> +        json.dump(data, outfile, sort_keys=True, indent=4)
>  def generate_junit_report(args, reports, start_time, end_time,
> @@ -343,97 +315,16 @@ def generate_junit_report(args, reports, start_time, end_time,
>  def generate_yaml_report(args, reports, start_time, end_time,
> -                         total, yaml_file):
> +                         _total, yaml_file):
>      """ Generates a YAML file containing information about the test run,
>      including all test outputs """
>      import yaml
> -    def format_output(output_list):
> -        return "\n".join(output_list).replace("] ", '').replace('=>  ', '')
> -    yaml_log = {}
> -    yaml_log['command-line'] = args
> -    yaml_log['host'] = host.label(mode='all')
> -    yaml_log['python'] = sys.version.replace('\n', '')
> -    yaml_log['summary'] = {}
> -    yaml_log['summary']['passed-count'] = reports.passed
> -    yaml_log['summary']['failed-count'] = reports.failed
> -    yaml_log['summary']['user-input-count'] = reports.user_input
> -    yaml_log['summary']['expected-fail-count'] = reports.expected_fail
> -    yaml_log['summary']['indeterminate-count'] = reports.indeterminate
> -    yaml_log['summary']['benchmark-count'] = reports.benchmark
> -    yaml_log['summary']['timeout-count'] = reports.timeouts
> -    yaml_log['summary']['test-too-long_count'] = reports.test_too_long
> -    yaml_log['summary']['invalid-count'] = reports.invalids
> -    yaml_log['summary']['wrong-version-count'] = reports.wrong_version
> -    yaml_log['summary']['wrong-build-count'] = reports.wrong_build
> -    yaml_log['summary']['wrong-tools-count'] = reports.wrong_tools
> -    yaml_log['summary']['wrong-header-count'] = reports.wrong_header
> -    yaml_log['summary']['total-count'] = reports.total
> -    yaml_log['summary']['average-test-time'] = str(time_delta / total)
> -    yaml_log['summary']['testing-time'] = str(time_delta)
> -    result_types = [
> -        yaml_log['summary'][result_type] = []
> -    result_element = {}
> -    yaml_log['outputs'] = []
> -    # process output of each test
> -    for exe_name in reports.results:
> -        test_parts = exe_name.split("/")
> -        result_element['executable-name'] = test_name
> -        result_element['executable-sha512'] = get_hash512(exe_name)
> -        result_element['execution-start'] = reports.results[exe_name]['start'].isoformat()
> -        result_element['execution-end'] = reports.results[exe_name]['end'].isoformat()
> -        date_diff = reports.results[exe_name]['end'] - reports.results[exe_name]['start']
> -        result_element['execution-duration'] = str(date_diff)
> -        result_element['execution-result'] = reports.results[exe_name]['result']
> -        result_element['bsp'] = reports.results[exe_name]['bsp']
> -        result_element['bsp-arch'] = reports.results[exe_name]['bsp_arch']
> -        result_output = reports.results[exe_name]['output']
> -        dbg_output = []
> -        test_output = []
> -        idxs_output = []  # store indices of given substrings
> -        for elem in result_output:
> -            if '=> ' in elem:
> -                idxs_output.append(result_output.index(elem))
> -            if '*** END' in elem:
> -        if len(idxs_output) == 3:  # test executed and has result
> -            dbg_output = result_output[idxs_output[0]:idxs_output[1]]
> -            dbg_output.append("=== Executed Test ===")
> -            dbg_output = dbg_output + result_output[idxs_output[2]+1:len(result_output)]
> -            test_output = result_output[idxs_output[1]:idxs_output[2]+1]
> -        else:
> -        result_element['debugger-output'] = format_output(dbg_output)
> -        result_element['console-output'] = format_output(test_output)
> -        yaml_log['outputs'].append(result_element)
> -        result_type = reports.results[exe_name]['result']
> -        # map "fatal-error" on to "failed"
> -            yaml_log['summary'][result_type].append(test_name)
>      with open(yaml_file, 'w') as outfile:
> -        yaml.dump(yaml_log, outfile, default_flow_style=False, allow_unicode=True)
> +        yaml.dump(data, outfile, default_flow_style=False, allow_unicode=True)
>  def get_hash512(exe):
