[PATCH] kern_tc.c: Update pps_event() for uniprocessor configurations
Sebastian Huber
Wed Jun 1 06:46:57 UTC 2022
On 30/05/2022 09:29, Gabriel Moyano wrote:
> Since pps->capgen is not used in uniprocessor configurations, there is no need to verified if it is equal to zero
> Update #2349
> cpukit/score/src/kern_tc.c | 4 ++++
> 1 file changed, 4 insertions(+)
> diff --git a/cpukit/score/src/kern_tc.c b/cpukit/score/src/kern_tc.c
> index 92739d8edd..897f81511e 100644
> --- a/cpukit/score/src/kern_tc.c
> +++ b/cpukit/score/src/kern_tc.c
> @@ -2165,7 +2165,11 @@ pps_event(struct pps_state *pps, int event)
> if ((event & pps->ppsparam.mode) == 0)
> return;
> /* If the timecounter was wound up underneath us, bail out. */
> +#if defined(RTEMS_SMP)
> if (pps->capgen == 0 || pps->capgen !=
> +#else
> + if (pps->capgen !=
> +#endif
> atomic_load_acq_int(&pps->capth->th_generation))
> return;
I think this fix is incomplete. What is with:
void
pps_capture(struct pps_state *pps)
struct timehands *th;
KASSERT(pps != NULL, ("NULL pps pointer in pps_capture"));
th = timehands;
pps->capgen = atomic_load_acq_int(&th->th_generation);
pps->capth = th;
#ifdef FFCLOCK
pps->capffth = fftimehands;
#endif
pps->capcount = th->th_counter->tc_get_timecount(th->th_counter);
atomic_thread_fence_acq();
if (pps->capgen != th->th_generation)
pps->capgen = 0;
I don't know why there is this "if" in the code. I will ask on a FreeBSD
mailing list.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
