[PATCH rtems-lwip] lwip: Split sources into origin directories
Vijay Kumar Banerjee vijay at rtems.org
Fri Jun 3 01:11:59 UTC 2022
Hi Pavel,
On Thu, Jun 2, 2022 at 12:09 AM Pavel Pisa <ppisa4lists at pikron.com> wrote:
> Dear Vijay,
> On Thursday 02 of June 2022 05:56:56 Vijay Kumar Banerjee wrote:
> > I have pushed this patch and I would like to add a note regarding that.
> thanks for the work and time.
No problem. I hope we can soon promote the rtems-lwip repository to
the top-level.
> > This patch started interesting discussions about the possible ways to
> > organize code from multiple sources. Pavel also raised an issue with
> > the directory name "uLan". Since the repository is still in a personal
> > area and still in the development stage, we can make rapid changes to
> > the repository. We will change the directory name from uLan to
> > something that's more suitable,
> please no uLAN it is RS-485 protocol. Yes it has and reuses our sysless
> firware base project and uses OOMK build system which we use
> for build of GNU/Linux, sysless, RTEMS, NuttX and even Windows
> applications. Because I used our port of LwIP which uses OMK
> build to test it in RTEMS I have named it lwip-omk and because
> we use the code in our instruments firmware which use OMK build,
> sysless and often uLAN protocol it ended in the repo under
> uLAN project.
> https://sourceforge.net/p/ulan/lwip-omk/ci/omk-devel/tree/
> But using this project name in the case where
> OMK buid system is unwanted, there is nor RS-485 connection
> and no use of other libraries and bare metal support from
> that PiKRON project is so misleading, that I have to insist
> to not use uLAN label...
> I suggest to have only ports directory at the rtems-lwip
> toplevel. We should go through the process to relicense
> all (where we are authors or where we can contact author)
> to RTEMS mainline acceptable licence. If there is some problematic
> driver then it stays in
>   ports/driver/driver_name
> directory so it will be separated and license precisely defined
> in that directory.
This is a good idea, and I totally agree with this approach. The
directories can be named with the target name, and the information of
the source can be included in a file there.
> I still see in the driers base only our own tms570_emac.
> So what is the plan for integrating others?
I realized that a few patches are in my local machine that never made
it to the repository. Kinsey is working on another port. We will have
at least two more ports soon.
> It would be great to have there at least two working
> ports because then it will be seen how to select them
> on the build system level.
> Thanks for updating project documentation
> https://devel.rtems.org/wiki/Packages/LWIP
> There is another task to solve. In the OMK build,
> there has been made possible to configure the most
> of the LwIP options from the project top level
> config.omk and config.target. It should be considered,
> how buffers size, count and many other featires will
> be configured in actual RSB build. Problem is that
> LwIP on targets with little memory (it worked on
> 256 kB TMS570LS3137) and on the other hand configuration
> for some bigger systems as is  Gaisler GR740 or somethink
> NOEL-V based can be significantly different when
> megabytes of RAM can be used.
The waf scripts can be extended in the way similar to top level
rtems-littlevgl that provides a default header file with config info,
which get rewritten by the script based on manual configurations.
https://git.rtems.org/packages/rtems-littlevgl/
> By the way, I am presenting at
> 9th International Workshop on Analogue and Mixed-Signal
> Integrated Circuits for Space Applications
> https://indico.esa.int/event/388/
Nice!
> and I have met there people from TTTech
> and they can have interrest to try RTEMS
> even on their TTEthernet space ASIC
> internal Leon 2 core. But it is memory
> constrained environment so for TCP/IP non-real time
> traffic they most probably cannot use BSD stack,
> so LwIP + RTEMS can be the option there.
This can be a nice project.
> But it is necessary to put project into some
> reusable shape. Unfortunately I do not have
> time to work on it some intensive way now
> and I do not know RSB stuff enough.
Handling the config will be the challenge, but a plain vanilla
rtems-lwip can be built using similar RSB script used for libbsd.
> On the other hand, if they express real interest,
> I can try, if I am able attract some students
> from our universitywho can work on the project.
> I invest a lot to pass knowledge for their serious
> work in this area.
> By the way, we have switched our Computer Architectures
> course to RISC-V in this run
>   https://cw.fel.cvut.cz/wiki/courses/b35apo/en/start
> including simulator
>   https://github.com/cvut/qtrvsim
> and public recording (even English, sorry Czenglish)
>   https://www.youtube.com/playlist?list=PLQL6z4JeTTQnTrML7HgagbjdpCtvdyu0M
Thanks for making the lecture pdfs public and uploading the videos on youtube!
Best regards,
Vijay
> Best wishes,
>                 Pavel Pisa
>  PiKRON s.r.o.       Phone/Fax: +420 284684676
>  Kankovskeho 1235    Phone:     +420 234697622
>  182 00 Praha 8      WWW:   http://www.pikron.com/
>  Czech Republic      e-mail:  pikron at pikron.com
