[PATCH rtems-libbsd 2/2] if_ffec: Allow PHY that is connected to other FFEC
Wed Jun 1 12:50:22 UTC 2022
Should this be upstreamed?
On Mon, May 23, 2022 at 6:22 AM Christian Mauderer
<christian.mauderer at embedded-brains.de> wrote:
> The i.MX6UL (and some others from the i.MX family) have shared MDIO
> lines for multiple FFECs. This patch allows to use the MDIO interface
> from another Ethernet controller.
> Note that you have to make sure that the FFECs are initialized in the
> right order. Normally that can be done via FDT.
>  freebsd/sys/dev/ffec/if_ffec.c | 120 +++++++++++++++++++++++++++++++++
>  1 file changed, 120 insertions(+)
> diff --git a/freebsd/sys/dev/ffec/if_ffec.c b/freebsd/sys/dev/ffec/if_ffec.c
> index 4c1e147b..316e077c 100644
> --- a/freebsd/sys/dev/ffec/if_ffec.c
> +++ b/freebsd/sys/dev/ffec/if_ffec.c
> @@ -209,6 +209,11 @@ struct ffec_softc {
>         int             rx_ic_count;    /* RW, valid values 0..255 */
>         int             tx_ic_time;
>         int             tx_ic_count;
> +#ifdef __rtems__
> +       device_t                mdio_device;
> +       struct mtx              mdio_mtx;
> +#endif /* __rtems__ */
>  static struct resource_spec irq_res_spec[MAX_IRQ_COUNT + 1] = {
> @@ -376,6 +381,13 @@ ffec_miibus_readreg(device_t dev, int phy, int reg)
>         int val;
>         sc = device_get_softc(dev);
> +#ifdef __rtems__
> +       if (sc->mdio_device) {
> +               return (MIIBUS_READREG(sc->mdio_device, phy, reg));
> +       mtx_lock(&sc->mdio_mtx);
>         WR4(sc, FEC_IER_REG, FEC_IER_MII);
> @@ -386,11 +398,17 @@ ffec_miibus_readreg(device_t dev, int phy, int reg)
>         if (!ffec_miibus_iowait(sc)) {
>                 device_printf(dev, "timeout waiting for mii read\n");
> +#ifdef __rtems__
> +               mtx_unlock(&sc->mdio_mtx);
>                 return (-1); /* All-ones is a symptom of bad mdio. */
>         val = RD4(sc, FEC_MMFR_REG) & FEC_MMFR_DATA_MASK;
> +#ifdef __rtems__
>         return (val);
> @@ -400,6 +418,13 @@ ffec_miibus_writereg(device_t dev, int phy, int reg, int val)
>         struct ffec_softc *sc;
> +#ifdef __rtems__
> +               return (MIIBUS_WRITEREG(sc->mdio_device, phy, reg, val));
> @@ -411,9 +436,15 @@ ffec_miibus_writereg(device_t dev, int phy, int reg, int val)
>                 device_printf(dev, "timeout waiting for mii write\n");
> +#ifdef __rtems__
>                 return (-1);
> +#ifdef __rtems__
>         return (0);
> @@ -1577,6 +1608,9 @@ ffec_detach(device_t dev)
>         if (sc->mem_res != NULL)
>                 bus_release_resource(dev, SYS_RES_MEMORY, 0, sc->mem_res);
> +#ifdef __rtems__
> +       mtx_destroy(&sc->mtx);
>         FFEC_LOCK_DESTROY(sc);
>         return (0);
> @@ -1726,6 +1760,80 @@ ffec_set_txic(struct ffec_softc *sc)
>         ffec_set_ic(sc, FEC_TXIC0_REG, sc->tx_ic_count, sc->tx_ic_time);
> +#ifdef __rtems__
> +int
> +ffec_get_phy_information(
> +       struct ffec_softc *sc,
> +       phandle_t node,
> +       device_t dev,
> +       int *phy_addr
> +       phandle_t phy_node;
> +       phandle_t parent_node;
> +       pcell_t phy_handle, phy_reg;
> +       device_t other;
> +       phandle_t xref;
> +       /* Search for the phy-handle and get the address */
> +       if (OF_getencprop(node, "phy-handle", (void *)&phy_handle,
> +           sizeof(phy_handle)) <= 0)
> +               return (ENXIO);
> +       phy_node = OF_node_from_xref(phy_handle);
> +       if (OF_getencprop(phy_node, "reg", (void *)&phy_reg,
> +           sizeof(phy_reg)) <= 0)
> +               return (ENXIO);
> +       *phy_addr = phy_reg;
> +       /* Detect whether PHY handle is connected to this or another FFEC. */
> +       parent_node = phy_node;
> +       while (parent_node != 0) {
> +               if (parent_node == node) {
> +                       /* PHY is directly connected. That's easy. */
> +                       sc->mdio_device = NULL;
> +                       return 0;
> +                * Check whether the node is also an Ethernet controller. Do
> +                * that by just assuming that every Ethernet controller has a
> +                * PHY attached to it.
> +               if (OF_getencprop(parent_node, "phy-handle",
> +                   (void *)&phy_handle, sizeof(phy_handle)) > 0) {
> +                        * Try to find the device of the other Ethernet
> +                        * controller and use that for MDIO communication.
> +                        * Note: This is not really a nice workaround but it
> +                        * works.
> +                       xref = OF_xref_from_node(parent_node);
> +                       if (xref == 0) {
> +                               device_printf(dev,
> +                                   "Couldn't get device that handles PHY\n");
> +                               return (ENXIO);
> +                       other = OF_device_from_xref(xref);
> +                       if (other == 0) {
> +                               return (ENXIO);
> +                       sc->mdio_device = other;
> +                       return 0;
> +               parent_node = OF_parent(parent_node);
> +       return (ENXIO);
>  static int
>  ffec_attach(device_t dev)
> @@ -1743,6 +1851,10 @@ ffec_attach(device_t dev)
>         sc->dev = dev;
>         FFEC_LOCK_INIT(sc);
> +#ifdef __rtems__
> +       mtx_init(&sc->mtx, device_get_nameunit(sc->dev),
> +           MTX_NETWORK_LOCK, MTX_DEF);
>          * There are differences in the implementation and features of the FEC
> @@ -2047,9 +2159,17 @@ ffec_attach(device_t dev)
>         ffec_miigasket_setup(sc);
>         /* Attach the mii driver. */
> +#ifdef __rtems__
> +       OF_device_register_xref(OF_xref_from_node(ofw_node), dev);
> +       if (ffec_get_phy_information(sc, ofw_node, dev, &phynum) != 0) {
> +               phynum = MII_PHY_ANY;
> +       (void) dummy;
> +#else /* __rtems__ */
>         if (fdt_get_phyaddr(ofw_node, dev, &phynum, &dummy) != 0) {
>         error = mii_attach(dev, &sc->miibus, ifp, ffec_media_change,
>             ffec_media_status, BMSR_DEFCAPMASK, phynum, MII_OFFSET_ANY,
>             (sc->fecflags & FECTYPE_MVF) ? MIIF_FORCEANEG : 0);
> 2.35.3
> devel mailing list
> devel at rtems.org
