[PATCH rtems-libbsd 2/2] if_ffec: Allow PHY that is connected to other FFEC
Christian MAUDERER christian.mauderer at embedded-brains.de
Thu Jun 2 07:35:01 UTC 2022
Am 01.06.22 um 14:50 schrieb Gedare Bloom:
> Should this be upstreamed?
I don't think so. The solution is quite device specific and has some
restrictions like the right initialization order (like noted in the
commit description). I don't think that FreeBSD will accept it.
I have seen some discussions on FreeBSD that they think about a more
generic approach. Basically that would make it necessary to split the
MDIO part from the remaining Ethernet controller part and make it a
separate driver. That would most likely make it necessary to change
multiple or all Ethernet drivers. I assume that some-when someone at
FreeBSD will add a solution like that. But till then, I think the
slightly hacked solution that I did with this patch should work well
enough for us.
> On Mon, May 23, 2022 at 6:22 AM Christian Mauderer
> <christian.mauderer at embedded-brains.de> wrote:
>> The i.MX6UL (and some others from the i.MX family) have shared MDIO
>> lines for multiple FFECs. This patch allows to use the MDIO interface
>> from another Ethernet controller.
>> Note that you have to make sure that the FFECs are initialized in the
>> right order. Normally that can be done via FDT.
>>   freebsd/sys/dev/ffec/if_ffec.c | 120 +++++++++++++++++++++++++++++++++
>>   1 file changed, 120 insertions(+)
>> diff --git a/freebsd/sys/dev/ffec/if_ffec.c b/freebsd/sys/dev/ffec/if_ffec.c
>> index 4c1e147b..316e077c 100644
>> --- a/freebsd/sys/dev/ffec/if_ffec.c
>> +++ b/freebsd/sys/dev/ffec/if_ffec.c
>> @@ -209,6 +209,11 @@ struct ffec_softc {
>>          int             rx_ic_count;    /* RW, valid values 0..255 */
>>          int             tx_ic_time;
>>          int             tx_ic_count;
>> +#ifdef __rtems__
>> +       device_t                mdio_device;
>> +       struct mtx              mdio_mtx;
>> +#endif /* __rtems__ */
>>   static struct resource_spec irq_res_spec[MAX_IRQ_COUNT + 1] = {
>> @@ -376,6 +381,13 @@ ffec_miibus_readreg(device_t dev, int phy, int reg)
>>          int val;
>>          sc = device_get_softc(dev);
>> +#ifdef __rtems__
>> +       if (sc->mdio_device) {
>> +               return (MIIBUS_READREG(sc->mdio_device, phy, reg));
>> +       mtx_lock(&sc->mdio_mtx);
>>          WR4(sc, FEC_IER_REG, FEC_IER_MII);
>> @@ -386,11 +398,17 @@ ffec_miibus_readreg(device_t dev, int phy, int reg)
>>          if (!ffec_miibus_iowait(sc)) {
>>                  device_printf(dev, "timeout waiting for mii read\n");
>> +#ifdef __rtems__
>> +               mtx_unlock(&sc->mdio_mtx);
>>                  return (-1); /* All-ones is a symptom of bad mdio. */
>>          val = RD4(sc, FEC_MMFR_REG) & FEC_MMFR_DATA_MASK;
>> +#ifdef __rtems__
>>          return (val);
>> @@ -400,6 +418,13 @@ ffec_miibus_writereg(device_t dev, int phy, int reg, int val)
>>          struct ffec_softc *sc;
>> +#ifdef __rtems__
>> +               return (MIIBUS_WRITEREG(sc->mdio_device, phy, reg, val));
>> @@ -411,9 +436,15 @@ ffec_miibus_writereg(device_t dev, int phy, int reg, int val)
>>                  device_printf(dev, "timeout waiting for mii write\n");
>> +#ifdef __rtems__
>>                  return (-1);
>> +#ifdef __rtems__
>>          return (0);
>> @@ -1577,6 +1608,9 @@ ffec_detach(device_t dev)
>>          if (sc->mem_res != NULL)
>>                  bus_release_resource(dev, SYS_RES_MEMORY, 0, sc->mem_res);
>> +#ifdef __rtems__
>> +       mtx_destroy(&sc->mtx);
>>          FFEC_LOCK_DESTROY(sc);
>>          return (0);
>> @@ -1726,6 +1760,80 @@ ffec_set_txic(struct ffec_softc *sc)
>>          ffec_set_ic(sc, FEC_TXIC0_REG, sc->tx_ic_count, sc->tx_ic_time);
>> +#ifdef __rtems__
>> +int
>> +ffec_get_phy_information(
>> +       struct ffec_softc *sc,
>> +       phandle_t node,
>> +       device_t dev,
>> +       int *phy_addr
>> +       phandle_t phy_node;
>> +       phandle_t parent_node;
>> +       pcell_t phy_handle, phy_reg;
>> +       device_t other;
>> +       phandle_t xref;
>> +       /* Search for the phy-handle and get the address */
>> +       if (OF_getencprop(node, "phy-handle", (void *)&phy_handle,
>> +           sizeof(phy_handle)) <= 0)
>> +               return (ENXIO);
>> +       phy_node = OF_node_from_xref(phy_handle);
>> +       if (OF_getencprop(phy_node, "reg", (void *)&phy_reg,
>> +           sizeof(phy_reg)) <= 0)
>> +               return (ENXIO);
>> +       *phy_addr = phy_reg;
>> +       /* Detect whether PHY handle is connected to this or another FFEC. */
>> +       parent_node = phy_node;
>> +       while (parent_node != 0) {
>> +               if (parent_node == node) {
>> +                       /* PHY is directly connected. That's easy. */
>> +                       sc->mdio_device = NULL;
>> +                       return 0;
>> +                * Check whether the node is also an Ethernet controller. Do
>> +                * that by just assuming that every Ethernet controller has a
>> +                * PHY attached to it.
>> +               if (OF_getencprop(parent_node, "phy-handle",
>> +                   (void *)&phy_handle, sizeof(phy_handle)) > 0) {
>> +                        * Try to find the device of the other Ethernet
>> +                        * controller and use that for MDIO communication.
>> +                        * Note: This is not really a nice workaround but it
>> +                        * works.
>> +                       xref = OF_xref_from_node(parent_node);
>> +                       if (xref == 0) {
>> +                               device_printf(dev,
>> +                                   "Couldn't get device that handles PHY\n");
>> +                               return (ENXIO);
>> +                       other = OF_device_from_xref(xref);
>> +                       if (other == 0) {
>> +                               return (ENXIO);
>> +                       sc->mdio_device = other;
>> +                       return 0;
>> +               parent_node = OF_parent(parent_node);
>> +       return (ENXIO);
>>   static int
>>   ffec_attach(device_t dev)
>> @@ -1743,6 +1851,10 @@ ffec_attach(device_t dev)
>>          sc->dev = dev;
>>          FFEC_LOCK_INIT(sc);
>> +#ifdef __rtems__
>> +       mtx_init(&sc->mtx, device_get_nameunit(sc->dev),
>> +           MTX_NETWORK_LOCK, MTX_DEF);
>>           * There are differences in the implementation and features of the FEC
>> @@ -2047,9 +2159,17 @@ ffec_attach(device_t dev)
>>          ffec_miigasket_setup(sc);
>>          /* Attach the mii driver. */
>> +#ifdef __rtems__
>> +       OF_device_register_xref(OF_xref_from_node(ofw_node), dev);
>> +       if (ffec_get_phy_information(sc, ofw_node, dev, &phynum) != 0) {
>> +               phynum = MII_PHY_ANY;
>> +       (void) dummy;
>> +#else /* __rtems__ */
>>          if (fdt_get_phyaddr(ofw_node, dev, &phynum, &dummy) != 0) {
>>          error = mii_attach(dev, &sc->miibus, ifp, ffec_media_change,
>>              ffec_media_status, BMSR_DEFCAPMASK, phynum, MII_OFFSET_ANY,
>>              (sc->fecflags & FECTYPE_MVF) ? MIIF_FORCEANEG : 0);
>> 2.35.3
>> devel mailing list
>> devel at rtems.org
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
