[PATCH rtems-libbsd 1/2] if_ffec: Reduce buffer size
Christian MAUDERER
christian.mauderer at embedded-brains.de
Thu Jun 2 07:27:52 UTC 2022
Hello Gedare,
Am 01.06.22 um 14:46 schrieb Gedare Bloom:
> On Mon, May 23, 2022 at 6:21 AM Christian Mauderer
> <christian.mauderer at embedded-brains.de> wrote:
>> Typical embedded systems don't have that much memory. Reduce the buffer
>> size to something more sensible for the usual type of application.
>> freebsd/sys/dev/ffec/if_ffec.c | 8 ++++++++
>> 1 file changed, 8 insertions(+)
>> diff --git a/freebsd/sys/dev/ffec/if_ffec.c b/freebsd/sys/dev/ffec/if_ffec.c
>> index 47c0f770..4c1e147b 100644
>> --- a/freebsd/sys/dev/ffec/if_ffec.c
>> +++ b/freebsd/sys/dev/ffec/if_ffec.c
>> @@ -139,9 +139,17 @@ static struct ofw_compat_data compat_data[] = {
>> * Driver data and defines. The descriptor counts must be a power of two.
>> +#ifndef __rtems__
>> #define RX_DESC_COUNT 512
>> +#else /* __rtems__ */
>> +#define RX_DESC_COUNT 64
>> +#endif /* __rtems__ */
> Do we need some way to control this parameter? Or, how will this
> appear if it breaks something?
I don't expect that there will be any problems. But I can take a look
how I can make that a parameter.
Best regards
Christian
>> #define RX_DESC_SIZE (sizeof(struct ffec_hwdesc) * RX_DESC_COUNT)
>> +#ifndef __rtems__
>> #define TX_DESC_COUNT 512
>> +#define TX_DESC_COUNT 64
>> #define TX_DESC_SIZE (sizeof(struct ffec_hwdesc) * TX_DESC_COUNT)
>> #define TX_MAX_DMA_SEGS 8
>> 2.35.3
>> devel mailing list
>> devel at rtems.org
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
