[PATCH rtems-libbsd 1/2] if_ffec: Reduce buffer size
Wed Jun 1 12:46:16 UTC 2022
On Mon, May 23, 2022 at 6:21 AM Christian Mauderer
<christian.mauderer at embedded-brains.de> wrote:
> Typical embedded systems don't have that much memory. Reduce the buffer
> size to something more sensible for the usual type of application.
>  freebsd/sys/dev/ffec/if_ffec.c | 8 ++++++++
>  1 file changed, 8 insertions(+)
> diff --git a/freebsd/sys/dev/ffec/if_ffec.c b/freebsd/sys/dev/ffec/if_ffec.c
> index 47c0f770..4c1e147b 100644
> --- a/freebsd/sys/dev/ffec/if_ffec.c
> +++ b/freebsd/sys/dev/ffec/if_ffec.c
> @@ -139,9 +139,17 @@ static struct ofw_compat_data compat_data[] = {
>   * Driver data and defines.  The descriptor counts must be a power of two.
> +#ifndef __rtems__
>  #define        RX_DESC_COUNT   512
> +#else /* __rtems__ */
> +#define        RX_DESC_COUNT   64
> +#endif /* __rtems__ */
Do we need some way to control this parameter? Or, how will this
appear if it breaks something?
>  #define        RX_DESC_SIZE    (sizeof(struct ffec_hwdesc) * RX_DESC_COUNT)
> +#ifndef __rtems__
>  #define        TX_DESC_COUNT   512
> +#define        TX_DESC_COUNT   64
>  #define        TX_DESC_SIZE    (sizeof(struct ffec_hwdesc) * TX_DESC_COUNT)
>  #define        TX_MAX_DMA_SEGS 8
> 2.35.3
> devel mailing list
> devel at rtems.org
