[PATCH rtems] bsps/imx: Enable clock of ETH2
Christian MAUDERER christian.mauderer at embedded-brains.de
Thu Jun 2 07:39:13 UTC 2022
Am 01.06.22 um 14:42 schrieb Gedare Bloom:
> On Mon, May 23, 2022 at 6:22 AM Christian Mauderer
> <christian.mauderer at embedded-brains.de> wrote:
>>   bsps/arm/imx/start/bspstart.c | 13 +++++++++++++
>>   1 file changed, 13 insertions(+)
>> diff --git a/bsps/arm/imx/start/bspstart.c b/bsps/arm/imx/start/bspstart.c
>> index 04d48d1558..e9cca49200 100644
>> --- a/bsps/arm/imx/start/bspstart.c
>> +++ b/bsps/arm/imx/start/bspstart.c
>> @@ -161,6 +161,18 @@ static void imx_find_gic(const void *fdt)
>>   #endif
>> +static void imx_ccm_enable_eth2_clk(void)
>> +  const void *fdt = bsp_fdt_get();
>> +  if (imx_is_imx6(fdt)) {
>> +    volatile uint32_t *ccm_pll_enet_set = (void *)0x020c80e4;
> Should this magic address be a #define somewhere?
You are right: I was lazy here because it was only a single register and
I thought that it's not that much difference whether I add it as a
single magic address in the code or as a define in a header. But it's a
bit out of style so I'll change it to match the style of other similar
cases.
>> +    const uint32_t ccm_pll_enet_enet2_125m_en = (1 << 20);
>> +    *ccm_pll_enet_set = ccm_pll_enet_enet2_125m_en;
>>   void bsp_start(void)
>>     imx_find_gic(bsp_fdt_get());
>> @@ -169,4 +181,5 @@ void bsp_start(void)
>>       bsp_section_nocacheheap_begin,
>>       (uintptr_t) bsp_section_nocacheheap_size
>> +  imx_ccm_enable_eth2_clk();
>> 2.35.3
>> devel mailing list
>> devel at rtems.org
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
