[PATCH 1/7] TFTPFS: Cleanup: Remove spaces at lines ends
Frank Kuehndel
frank.kuehndel at embedded-brains.de
Fri Jun 3 15:22:40 UTC 2022
From: Frank Kühndel <frank.kuehndel at embedded-brains.de>
cpukit/libfs/src/ftpfs/tftpDriver.c | 20 ++++++++++----------
1 file changed, 10 insertions(+), 10 deletions(-)
diff --git a/cpukit/libfs/src/ftpfs/tftpDriver.c b/cpukit/libfs/src/ftpfs/tftpDriver.c
index bebe748ca5..d0eadcf99a 100644
--- a/cpukit/libfs/src/ftpfs/tftpDriver.c
+++ b/cpukit/libfs/src/ftpfs/tftpDriver.c
@@ -233,12 +233,12 @@ int rtems_tftpfs_initialize(
fs->flags = 0;
fs->nStreams = 0;
fs->tftpStreams = 0;
mt_entry->fs_info = fs;
mt_entry->mt_fs_root->location.node_access = root_path;
mt_entry->mt_fs_root->location.handlers = &rtems_tftp_handlers;
mt_entry->ops = &rtems_tftp_ops;
* Now allocate a semaphore for mutual exclusion.
@@ -258,7 +258,7 @@ int rtems_tftpfs_initialize(
token = strtok_r (NULL, " ", &saveptr);
return 0;
error:
@@ -563,7 +563,7 @@ static int rtems_tftp_open_worker(
* Get the file system info.
fs = tftpfs_info_iop (iop);
* Extract the host name component
@@ -595,7 +595,7 @@ static int rtems_tftp_open_worker(
return ENOENT;
memcpy (&farAddress, he->h_addr, sizeof (farAddress));
* Extract file pathname component
@@ -803,7 +803,7 @@ static ssize_t rtems_tftp_read(
if (!tp)
rtems_set_errno_and_return_minus_one( EIO );
* Read till user request is satisfied or EOF is reached
@@ -918,15 +918,15 @@ static int rtems_tftp_close(
tftpfs_info_t *fs;
struct tftpStream *tp = iop->data1;
int e = 0;
- if (!tp)
+ if (!tp)
rtems_set_errno_and_return_minus_one (EIO);
if (tp->writing)
e = rtems_tftp_flush (tp);
if (!tp->eof && !tp->firstReply) {
2.35.3
