[PATCH 2/7] TFTPFS: Duplicate tftpDriver.c to tftpfs.c
Frank Kuehndel frank.kuehndel at embedded-brains.de
Fri Jun 3 15:22:41 UTC 2022
From: Frank Kühndel <frank.kuehndel at embedded-brains.de>
 cpukit/libfs/src/ftpfs/{tftpDriver.c => tftpfs.c} | 0
 spec/build/cpukit/libtftpfs.yml                   | 4 ++--
 2 files changed, 2 insertions(+), 2 deletions(-)
 rename cpukit/libfs/src/ftpfs/{tftpDriver.c => tftpfs.c} (100%)
diff --git a/cpukit/libfs/src/ftpfs/tftpDriver.c b/cpukit/libfs/src/ftpfs/tftpfs.c
similarity index 100%
rename from cpukit/libfs/src/ftpfs/tftpDriver.c
rename to cpukit/libfs/src/ftpfs/tftpfs.c
diff --git a/spec/build/cpukit/libtftpfs.yml b/spec/build/cpukit/libtftpfs.yml
index 90a0eabc80..f63a50c933 100644
--- a/spec/build/cpukit/libtftpfs.yml
+++ b/spec/build/cpukit/libtftpfs.yml
@@ -2,7 +2,7 @@ SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
 build-type: library
 cflags: []
 copyrights:
-- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+- Copyright (C) 2020, 2022 embedded brains GmbH (http://www.embedded-brains.de)
 cppflags: []
 cxxflags: []
 enabled-by: true
@@ -15,6 +15,6 @@ install:
 install-path: ${BSP_LIBDIR}
 links: []
 source:
-- cpukit/libfs/src/ftpfs/tftpDriver.c
+- cpukit/libfs/src/ftpfs/tftpfs.c
 target: tftpfs
 type: build
2.35.3
