[PATCH 4/7] TFTPFS: Implement block and window size options
Frank Kuehndel
frank.kuehndel at embedded-brains.de
Fri Jun 3 15:22:43 UTC 2022
From: Frank Kühndel <frank.kuehndel at embedded-brains.de>
The original file cpukit/libfs/src/ftpfs/tftpDriver.c
is split into two:
tftpfs.c - This file contains the code from tftpDriver.c
related to file system operations such as mount(),
open(), read(), and so on.
tftpDriver.c - In the original file remains only the code related
to networking. This code implements the Trivial
File Transfer Protocol (TFTP).
Moreover, the code is extended to support
* RFC 2347 TFTP Option Extension
* RFC 2348 TFTP Blocksize Option
* RFC 7440 TFTP Windowsize Option
cpukit/include/rtems/tftp.h | 404 +++++-
cpukit/libfs/src/ftpfs/tftpDriver.c | 1770 ++++++++++++++++----------
cpukit/libfs/src/ftpfs/tftp_driver.h | 76 ++
cpukit/libfs/src/ftpfs/tftpfs.c | 722 ++---------
spec/build/cpukit/libtftpfs.yml | 1 +
5 files changed, 1723 insertions(+), 1250 deletions(-)
create mode 100644 cpukit/libfs/src/ftpfs/tftp_driver.h
diff --git a/cpukit/include/rtems/tftp.h b/cpukit/include/rtems/tftp.h
index 8fa516042b..23929cfacf 100644
--- a/cpukit/include/rtems/tftp.h
+++ b/cpukit/include/rtems/tftp.h
@@ -1,13 +1,20 @@
* @file
- * @brief * Trivial File Transfer Protocol (TFTP)
+ * @ingroup RTEMSAPITFTP
+ * @brief This header file provides interfaces and functions used to
+ * implement the TFTP file system.
- * Transfer file to/from remote host
+ * This file declares the public functions of the Trivial File
+ * Transfer Protocol (TFTP) file system.
- * Copyright (c) 1998 Eric Norum <eric at norum.ca>
+ * Copyright (C) 1998 W. Eric Norum <eric at norum.ca>
+ * Copyright (C) 2022 embedded brains GmbH (http://www.embedded-brains.de)
* modification, are permitted provided that the following conditions
@@ -31,14 +38,87 @@
* POSSIBILITY OF SUCH DAMAGE.
- * Usage:
+ * @defgroup RTEMSAPITFTP Trivial File Transfer Protocol (TFTP) API
+ * @ingroup RTEMSAPIIO
+ * @brief The TFTP client library provides an API to read files from and
+ * to write files to remote servers using the Trivial File Transfer
+ * Protocol (TFTP).
+ * Usage
+ * The pseudo-code below shows the principal usage for reading a file.
+ * int res;
+ * ssize_t bytes;
+ * void *tftp_handle;
+ * tftp_net_config config;
+ * const size_t buffer_size = 4000;
+ * char data_buffer[buffer_size];
+ * tftp_initialize_net_config( &config );
+ * config.options.window_size = 1; // Set desired config values
+ * res = tftp_open(
+ * "127.0.0.1",
+ * "filename.txt",
+ * true, // is_for_reading
+ * &config,
+ * &tftp_handle
+ * if ( res != 0 || tftp_handle == NULL ) {
+ * // Error
+ * // Use tftp_read() (probably in a loop) ...
+ * bytes = tftp_read(
+ * tftp_handle,
+ * data_buffer,
+ * buffer_size
+ * // ... or use tftp_write() instead when the file is open for writing.
+ * res = tftp_close( tftp_handle );
+ * if ( res != 0 ) {
+ * // Error ... check! Especially when writing!
+ * See also the _RTEMS Filesystem Design Guide_ Chapter [_Trivial FTP Client
+ * Filesystem_](https://docs.rtems.org/branches/master/filesystem/trivial_ftp.html).
+ * @defgroup RTEMSTFTPFS Trivial File Transfer Protocol (TFTP) file system
+ * @ingroup FileSystemTypesAndMount
+ * @brief The TFTP file system provides the ability to read files from and
+ * Usage
+ * To open `/bootfiles/image` on `hostname` for reading:
+ * fd = open ("/TFTP/hostname:bootfiles/image", O_RDONLY);
+ * The `TFTP` is the mount path and the `hostname` must be
- * To open `/bootfiles/image' on `hostname' for reading:
- * fd = open ("/TFTP/hostname/bootfiles/image", O_RDONLY);
+ * + an IPv4 address (like `127.0.0.1`) or
+ * + the (full-qualified) name of an IPv4 host (acceptable to
+ * `gethostbyname()`)
- * The 'TFTP' is the mount path and the `hostname' must be four dot-separated
- * decimal values.
+ * IPv6 is currently not supported. `bootfiles/image` is a path on the
+ * TFTP server `hostname` where the file (here `image`) can be found.
#ifndef _RTEMS_TFTP_H
@@ -48,9 +128,12 @@
extern "C" {
#endif
+#include <stdint.h>
#include <rtems/fs.h>
+ * @brief Do not call directly, use mount().
* Filesystem Mount table entry.
int rtems_tftpfs_initialize(
@@ -58,6 +141,307 @@ int rtems_tftpfs_initialize(
const void *data
+ * The functions below use of the TFTP client library standalone
+ * - i.e. without going through the file system.
+ * @brief This block size meets RFC 1350 and avoids the sending of
+ * the `blksize` option to the TFTP server.
+#define TFTP_RFC1350_BLOCK_SIZE 512
+ * @brief This window size avoids the sending of the `windowsize`
+ * option to the TFTP server.
+ * This effectively mimics the operation defined in RFC 1350 which
+ * does not know any window size.
+#define TFTP_RFC1350_WINDOW_SIZE 1
+ * @brief This block size is suggested in RFC 2348 and is used as
+ * default if no different block size is provided.
+#define TFTP_DEFAULT_BLOCK_SIZE 1456
+ * @brief This window size is suggested in RFC 2348 and is used as
+ * default if no different window size is provided.
+#define TFTP_DEFAULT_WINDOW_SIZE 8
+ * @brief This structure represents TFTP options negotiated between
+ * client and server.
+ * RFC 2347 is the basis for the TFTP option.
+typedef struct tftp_options {
+ * @brief This member represents the desired size of a data block.
+ * The TFTP blocksize option is introduced in RFC 2348. It defines the
+ * number of octets in the data packets transferred. Valid values
+ * range between 8 and 65464 octets, inclusive. Values larger
+ * than 1468 may cause packet fragmentation over standard Ethernet.
+ * A value of 512 will prevent this option from being sent to
+ * the server.
+ * The default value is 1456.
+ uint16_t block_size;
+ * @brief This member represents the desired size of a window.
+ * The TFTP windowsize option is introduced in RFC 7440. It defines the
+ * number of data packets send before the receiver must send an
+ * acknowledgment packet. Valid values range between 1 and 65535
+ * packets, inclusive. Simple TFTP servers usually do not support this
+ * option. This option may negatively contribute to network
+ * congestion. This can be avoided by using a window size of 1.
+ * A value of 1 will prevent this option from being sent to
+ * the server.
+ * The default value is 8.
+ uint16_t window_size;
+} tftp_options;
+ * @brief This structure represents configuration value used by the TFTP
+ * client.
+ * As defaults the values suggested in RFC 7440 are used.
+typedef struct tftp_net_config {
+ * @brief This member defines how many attempts are made to send a
+ * network packet to the server.
+ * Repetitions occur when the server does not response to a packet
+ * send by the client within a timeout period. When the here defined
+ * number of repetitions is reached and the server does still not
+ * respond, the connection is considered broken and the file transfer
+ * is ended with an error.
+ * The default value is 6.
+ uint16_t retransmissions;
+ * @brief This member defines the port on which the server is listening
+ * for incoming connections.
+ * The default port number is 69.
+ uint16_t server_port;
+ * @brief This member defines the maximum time in milliseconds the
+ * client waits for an answer packet from the server.
+ * If the time out is exceeded, the client will re-transmit the last
+ * packet it send to the server. In case @c window_size is larger one,
+ * several packets may subject to re-transmission.
+ * Note that this timeout applies only after the first re-transmission
+ * of a packet. The timeout till the first re-transmission is
+ * @c first_timeout.
+ * The default value is 1000ms.
+ uint32_t timeout;
+ * client waits for the first answer packet from the server.
+ * The @c first_timeout is used instead of the regular @c timeout
+ * for the first wait-period directly after the client sends a packet
+ * for the first time to the server. That is, this is the timeout
+ * of the first re-transmission. For any following re-transmissions
+ * of the current packet the regular @c timeout is used.
+ * The default value is 400ms.
+ uint32_t first_timeout;
+ * @brief This member represents the options to be sent to the server.
+ * These option values are sent to the server. Yet, the server may
+ * + ignore one or all options
+ * + ask the client to use a different value for an option
+ * + reject the whole request with an error
+ * If the server rejects a request with options, the current client
+ * implementation will automatically send a second request without
+ * options. Hence, the user should be aware that the actual file
+ * transfer may not use the option values specified here.
+ tftp_options options;
+} tftp_net_config;
+ * @brief Set all members of a @c tftp_net_config structure to their
+ * default values.
+ * @param config references a @c tftp_net_config structure.
+ * The values are set to the defaults defined in
+ * @ref tftp_net_config "`type tftp_net_config`".
+void tftp_initialize_net_config(
+ tftp_net_config *config
+ * @brief Opens and starts a TFTP client session to read or write a
+ * single file.
+ * This directive resolves the hostname or IP address, establishes a connection
+ * to the TFTP server and initiates the data transfer. It will not return
+ * before an error is encountered or the TFTP server has responded to the
+ * read or write request with a network packet.
+ * TFTP uses timeouts (of unspecified length). It does not know keep-alive
+ * messages. If the client does not respond to the server in due time,
+ * the server sets the connection faulty and drops it. To avoid this
+ * the user of this code must read or write enough data fast enough.
+ * "Enough data" means at least so much data which fills a single data
+ * packet or all packets of a window if windows are used. The data
+ * can be read or written in anything from one single large chunk to
+ * byte-by-byte pieces. The point is, one cannot pause the reading
+ * or writing for longer periods of time.
+ * @param hostname is the IPv4 address as string or the name of the TFTP
+ * server to connect to.
+ * @param path is the pathname at the TFTP server side of the file to
+ * read or write. According to RFC 1350 the path must be in
+ * NETASCII. This is ASCII as defined in "USA Standard Code for
+ * Information Interchange" with the modifications specified in "Telnet
+ * Protocol Specification".
+ * @param is_for_reading indicated whether the file is to be read or written.
+ * A value of @c true indicates that the file is intended to be read from
+ * the server. A value of @c false indicates that the file is to be written
+ * to the server.
+ * @param config either references a structure defining the configuration
+ * values for this file transfer or is @c NULL. If it is @c NULL, default
+ * configuration values are used. See @ref tftp_net_config
+ * "`type tftp_net_config`" for a description and the defaults values.
+ * This function copies the data so that the memory pointed to by
+ * @c config can be used for other purposes after the call returns.
+ * @param[out] tftp_handle references a place where a handle of the connection
+ * can be stored. On success a pointer to a handle is stored. On failure
+ * (return value other than 0) a @c NULL pointer is stored. This handle
+ * must be provided to all further calls to tftp_read(),
+ * tftp_write(), and tftp_close().
+ * When this directive stores a non-NULL pointer in this place, a call
+ * to tftp_close() is mandatory to release allocated resources.
+ * This parameter cannot be @c NULL.
+ * @retval 0 When the client session was opened successfully.
+ * @return Returns a POSIX @c errno value in case an error occurred.
+int tftp_open(
+ const char *hostname,
+ const char *path,
+ bool is_for_reading,
+ const tftp_net_config *config,
+ void **tftp_handle
+ * @brief Read data from a TFTP server.
+ * This directive attempts to read data from a TFTP connection open for
+ * reading.
+ * Upon success, the buffer is always filled with @c count bytes of received
+ * data with the exception when the end of the file has been reached.
+ * TFTP cannot recover from errors. Once an error is reported, the
+ * connection must be and can only be closed.
+ * @param tftp_handle is the reference returned by a call to tftp_open().
+ * The file must be opened for reading.
+ * @param[out] buffer references a memory area into which the received
+ * data is written.
+ * @param count defines the size of the @c buffer in bytes.
+ * @retval 0 The end of the file has been reached. There is no more data.
+ * @return If greater or equal to 0, returns the number of bytes written
+ * into the buffer. If the return value is negative, an error occurred.
+ * In this case the negated value is a POSIX @c errno value.
+ssize_t tftp_read(
+ void *tftp_handle,
+ void *buffer,
+ size_t count
+ * @brief Write data to a TFTP server.
+ * This directive attempts to write data to a TFTP connection open for
+ * writing.
+ * On a successful call, all data in the @c buffer will be used. Yet, this
+ * does not imply that all data is actually sent. This depends on
+ * whether a whole data packet or window can be filled.
+ * TFTP cannot recover from errors. Once an error is reported, the connection
+ * must be and can only be closed.
+ * The file must be opened for writing.
+ * @param buffer references a memory area which contains the data to be
+ * sent.
+ * @param count defines the size of the data in @c buffer in bytes.
+ * @return If greater or equal to 0, returns the number of bytes used
+ * from the buffer. The value is always @c count on a successful call.
+ * If the return value is negative, an error occurred. In this case
+ * the negated value is a POSIX @c errno value.
+ssize_t tftp_write(
+ const void *buffer,
+ size_t count
+ * @brief Close a TFTP client connection.
+ * This directive sends all data which are still stored in a write buffer
+ * to the server (if any), tells the server that the connection ends (if
+ * required by RFC 1350) and releases any resources allocated at the
+ * client side.
+ * @note Especially, when writing a file to the server, the return
+ * code of ``tftp_close()`` should be checked. Invoking
+ * ``tftp_close()`` triggers the sending of the last -- not
+ * completely filled -- data block. This may fail the same way as any
+ * ``tftp_write()`` may fail. Therefore, an error returned by
+ * ``tftp_close()`` likely indicates that the file was not
+ * completely transferred.
+ * If this parameter is @c NULL, the directive call is a no-op.
+ * @retval 0 When the client session was closed successfully.
+int tftp_close(
+ void *tftp_handle
#ifdef __cplusplus
#endif
diff --git a/cpukit/libfs/src/ftpfs/tftpDriver.c b/cpukit/libfs/src/ftpfs/tftpDriver.c
index d0eadcf99a..f564f2b4b2 100644
--- a/cpukit/libfs/src/ftpfs/tftpDriver.c
+++ b/cpukit/libfs/src/ftpfs/tftpDriver.c
@@ -3,16 +3,26 @@
* @file
- * Trivial File Transfer Protocol file system (TFTP client) for RFC 1350.
+ * @ingroup RTEMSTFTPFS
+ * @brief This source file contains the implementation of
+ * a Trivial File Transfer Protocol (TFTP) client library.
+ * The code in this file provides the ability to read files from and
+ * Protocol (TFTP). It is used by the @ref tftpfs.c "TFTP file system" and
+ * tested through its test suite. The
+ * following RFCs are implemented:
+ * + RFC 1350 "The TFTP Protocol (Revision 2)"
+ * + RFC 2347 "TFTP Option Extension"
+ * + RFC 2348 "TFTP Blocksize Option"
+ * + RFC 7440 "TFTP Windowsize Option"
- * Modifications to support reference counting in the file system are
- * Copyright (c) 2012 embedded brains GmbH.
+ * Copyright (C) 2012, 2022 embedded brains GmbH (http://www.embedded-brains.de)
@@ -42,30 +52,26 @@
+#include <inttypes.h>
#include <malloc.h>
#include <unistd.h>
#include <fcntl.h>
-#include <rtems/libio_.h>
-#include <rtems/seterr.h>
#include <rtems/tftp.h>
-#include <rtems/thread.h>
#include <sys/types.h>
#include <sys/socket.h>
#include <netinet/in.h>
#include <arpa/inet.h>
#include <netdb.h>
+#include "tftp_driver.h"
#ifdef RTEMS_NETWORKING
#endif
-#ifdef RTEMS_TFTP_DRIVER_DEBUG
-int rtems_tftp_driver_debug = 1;
-#endif
* Range of UDP ports to try
@@ -75,9 +81,21 @@ int rtems_tftp_driver_debug = 1;
* Default limits
#define PACKET_FIRST_TIMEOUT_MILLISECONDS 400L
-#define PACKET_TIMEOUT_MILLISECONDS 6000L
-#define OPEN_RETRY_LIMIT 10
-#define IO_RETRY_LIMIT 10
+#define TFTP_WINDOW_SIZE_MIN 1
+#define TFTP_BLOCK_SIZE_MIN 8
+#define TFTP_BLOCK_SIZE_MAX 65464
+#define TFTP_BLOCK_SIZE_OPTION "blksize"
+#define TFTP_WINDOW_SIZE_OPTION "windowsize"
+#define TFTP_DECIMAL_BASE 10
+#define TFTP_DEFAULT_SERVER_PORT 69
+ * These values are suggested by RFC 7440.
+#define TFTP_RFC7440_DATA_RETRANSMISSIONS 6
+#define TFTP_RFC7440_TIMEOUT_MILLISECONDS 1000
* TFTP opcodes
@@ -87,11 +105,46 @@ int rtems_tftp_driver_debug = 1;
#define TFTP_OPCODE_DATA 3
#define TFTP_OPCODE_ACK 4
#define TFTP_OPCODE_ERROR 5
+#define TFTP_OPCODE_OACK 6
+ * TFTP error codes
+#define TFTP_ERROR_CODE_NOT_DEFINED 0
+#define TFTP_ERROR_CODE_NOT_FOUND 1
+#define TFTP_ERROR_CODE_NO_ACCESS 2
+#define TFTP_ERROR_CODE_DISK_FULL 3
+#define TFTP_ERROR_CODE_ILLEGAL 4
+#define TFTP_ERROR_CODE_UNKNOWN_ID 5
+#define TFTP_ERROR_CODE_FILE_EXISTS 6
+#define TFTP_ERROR_CODE_NO_USER 7
+#define TFTP_ERROR_CODE_OPTION_NEGO 8
+ * Special return values for process_*_packet() functions
+ * (other return values are POSIX errors)
+#define GOT_EXPECTED_PACKET 0
+#define GOT_DUPLICATE_OF_CURRENT_PACKET -1
+#define GOT_OLD_PACKET -2
+#define GOT_FIRST_OUT_OF_ORDER_PACKET -3
- * Largest data transfer
+ * Special argument value for getPacket()
-#define TFTP_BUFSIZE 512
+#define GET_PACKET_DONT_WAIT -1
+ * Special return value for prepare_*_packet_for_sending() functions
+ * (other return values are the length of the packet to be send)
+#define DO_NOT_SEND_PACKET 0
+#define PKT_SIZE_FROM_BLK_SIZE(_blksize) ((_blksize) + 2 * sizeof (uint16_t))
+#define BLK_SIZE_FROM_PKT_SIZE(_pktsize) ((_pktsize) - 2 * sizeof (uint16_t))
+#define MUST_SEND_OPTIONS(_options) (\
+ (_options).block_size != TFTP_RFC1350_BLOCK_SIZE || \
+ (_options).window_size != TFTP_RFC1350_WINDOW_SIZE )
* Packets transferred between machines
@@ -102,7 +155,7 @@ union tftpPacket {
struct tftpRWRQ {
uint16_t opcode;
- char filename_mode[TFTP_BUFSIZE];
+ char filename_mode[];
} tftpRWRQ;
@@ -111,7 +164,7 @@ union tftpPacket {
struct tftpDATA {
uint16_t opcode;
uint16_t blocknum;
- uint8_t data[TFTP_BUFSIZE];
+ uint8_t data[];
} tftpDATA;
@@ -122,13 +175,21 @@ union tftpPacket {
uint16_t blocknum;
} tftpACK;
+ * OACK packet
+ struct tftpOACK {
+ uint16_t opcode;
+ char options[];
+ } tftpOACK;
* ERROR packet
struct tftpERROR {
uint16_t opcode;
uint16_t errorCode;
- char errorMessage[TFTP_BUFSIZE];
+ char errorMessage[];
} tftpERROR;
@@ -137,15 +198,56 @@ union tftpPacket {
struct tftpStream {
- * Buffer for storing most recently-received packet
+ * Buffer for storing packets for sending and receiving. Can point
+ * to the same address when only one buffer is needed for reading.
- union tftpPacket pkbuf;
+ union tftpPacket *receive_buf;
+ union tftpPacket *send_buf;
- * Last block number transferred
+ * Current block number - i.e. the block currently send or received
uint16_t blocknum;
+ * Size of the data area in a DATA single packet.
+ size_t block_size;
+ * The maximum size of a packet. It depends linearly on the block_size.
+ * The receive_buf and (the packets in) the send_buf are of this size.
+ size_t packet_size;
+ * The number of packets which can be stored in the send buffer.
+ * During option negotiation and for reading a file from the server
+ * only a buffer for a single packet is needed. In those cases, this
+ * value is always one. When a file is written to the server,
+ * the value equals the window size:
+ * send_buf_size_in_pkts == server_options.window_size
+ * Packet N is stored in
+ * send_buf + packet_size * (N % send_buf_size_in_pkts)
+ uint16_t send_buf_size_in_pkts;
+ * When writing files with windowsize > 1, the number of the completely
+ * filled packet with the highest block number in the send buffer.
+ * When the user calls write(), the data will be written into
+ * the block after this one.
+ uint16_t blocknum_last_filled;
+ * When writing files with windowsize > 1, the number of the packet
+ * which is the last one in the whole file (i.e. the user
+ * called close()). This block is never full (but maybe empty).
+ uint16_t blocknum_eof_block;
* Data transfer socket
@@ -155,6 +257,9 @@ struct tftpStream {
* Indices into buffer
+ * In case of sending a file with windowsize > 1, these values apply
+ * only to the packet with the highest number in the send buffer
+ * (blocknum_last_filled + 1).
int nleft;
int nused;
@@ -163,143 +268,161 @@ struct tftpStream {
* Flags
int firstReply;
- int eof;
- int writing;
+ bool at_eof;
+ bool is_for_reading;
+ * Function pointers and members for use by communicate_with_server().
+ ssize_t (*prepare_packet_for_sending) (
+ struct tftpStream *tp,
+ bool force_retransmission,
+ union tftpPacket **send_buf,
+ bool *wait_for_packet_reception,
+ const void *create_packet_data
+ int (*process_data_packet) (struct tftpStream *tp, ssize_t len);
+ int (*process_ack_packet) (struct tftpStream *tp, ssize_t len);
+ int (*process_oack_packet) (struct tftpStream *tp, ssize_t len);
+ int (*process_error_packet) (struct tftpStream *tp, ssize_t len);
+ int retransmission_error_code;
+ bool ignore_out_of_order_packets;
+ int32_t blocknum_of_first_packet_of_window;
+ int error;
+ * Configuration and TFTP options
+ * * config.options are options desired by the user (i.e. the values
+ * send to the server).
+ * * server_options are the options agreed by the server
+ * (the option values actually used for the transfer of data).
+ tftp_net_config config;
+ tftp_options server_options;
- * Flags for filesystem info.
+ * Forward declaration cannot be avoided.
-#define TFTPFS_VERBOSE (1 << 0)
+static ssize_t prepare_data_packet_for_sending (
+ const void *path_name
+static ssize_t prepare_ack_packet_for_sending (
- * TFTP File system info.
+ * Calculate the address of packet N in the send buffer
-typedef struct tftpfs_info_s {
- uint32_t flags;
- rtems_mutex tftp_mutex;
- int nStreams;
- struct tftpStream ** volatile tftpStreams;
-} tftpfs_info_t;
-#define tftpfs_info_mount_table(_mt) ((tftpfs_info_t*) ((_mt)->fs_info))
-#define tftpfs_info_pathloc(_pl) ((tftpfs_info_t*) ((_pl)->mt_entry->fs_info))
-#define tftpfs_info_iop(_iop) (tftpfs_info_pathloc (&((_iop)->pathinfo)))
+static union tftpPacket *get_send_buffer_packet (
+ uint16_t packet_num
+ return (union tftpPacket *) ( ( (char *) tp->send_buf) + tp->packet_size *
+ (packet_num % tp->send_buf_size_in_pkts) );
- * Number of streams open at the same time
+ * Create read or write request
-static const rtems_filesystem_operations_table rtems_tftp_ops;
-static const rtems_filesystem_file_handlers_r rtems_tftp_handlers;
-static bool rtems_tftp_is_directory(
+static size_t create_request (
+ union tftpPacket *send_buf,
+ size_t data_size,
const char *path,
- size_t pathlen
+ const tftp_options *options
- return path [pathlen - 1] == '/';
+ size_t res_size;
+ char *cur = send_buf->tftpRWRQ.filename_mode;
-int rtems_tftpfs_initialize(
- rtems_filesystem_mount_table_entry_t *mt_entry,
- const void *data
- const char *device = mt_entry->dev;
- size_t devicelen = strlen (device);
- tftpfs_info_t *fs = NULL;
- char *root_path;
- if (devicelen == 0) {
- root_path = malloc (1);
- if (root_path == NULL)
- goto error;
- root_path [0] = '\0';
+ send_buf->tftpRWRQ.opcode = htons (
+ is_for_reading ? TFTP_OPCODE_RRQ : TFTP_OPCODE_WRQ
+ res_size = snprintf (cur, data_size, "%s%c%s", path, 0, "octet");
+ if (res_size >= data_size) {
+ return -1;
- else {
- root_path = malloc (devicelen + 2);
- goto error;
- root_path = memcpy (root_path, device, devicelen);
- root_path [devicelen] = '/';
- root_path [devicelen + 1] = '\0';
+ res_size++;
+ data_size -= res_size;
+ cur += res_size;
+ if (options->block_size != TFTP_RFC1350_BLOCK_SIZE) {
+ cur,
+ data_size,
+ "%s%c%"PRIu16,
+ TFTP_BLOCK_SIZE_OPTION,
+ 0,
+ options->block_size
+ return -1;
+ res_size++;
+ cur += res_size;
- fs = malloc (sizeof (*fs));
- if (fs == NULL)
- goto error;
- fs->flags = 0;
- fs->nStreams = 0;
- fs->tftpStreams = 0;
- mt_entry->fs_info = fs;
- mt_entry->mt_fs_root->location.node_access = root_path;
- mt_entry->mt_fs_root->location.handlers = &rtems_tftp_handlers;
- mt_entry->ops = &rtems_tftp_ops;
- * Now allocate a semaphore for mutual exclusion.
- * NOTE: This could be in an fsinfo for this filesystem type.
- rtems_mutex_init (&fs->tftp_mutex, "TFTPFS");
- if (data) {
- char* config = (char*) data;
- char* token;
- char* saveptr;
- token = strtok_r (config, " ", &saveptr);
- while (token) {
- if (strcmp (token, "verbose") == 0)
- fs->flags |= TFTPFS_VERBOSE;
- token = strtok_r (NULL, " ", &saveptr);
+ if (options->window_size != TFTP_RFC1350_WINDOW_SIZE) {
+ cur,
+ data_size,
+ "%s%c%"PRIu16,
+ TFTP_WINDOW_SIZE_OPTION,
+ 0,
+ options->window_size
+ return -1;
+ res_size++;
+ cur += res_size;
- return 0;
-error:
- free (fs);
- free (root_path);
- rtems_set_errno_and_return_minus_one (ENOMEM);
+ return cur - (char *)send_buf;
- * Release a stream and clear the pointer to it
-static void
-releaseStream (tftpfs_info_t *fs, int s)
+static bool parse_decimal_number (
+ char **pos,
+ size_t *remain,
+ long min,
+ long max,
+ uint16_t *variable
- if (fs->tftpStreams[s] && (fs->tftpStreams[s]->socket >= 0))
- close (fs->tftpStreams[s]->socket);
- rtems_mutex_lock (&fs->tftp_mutex);
- free (fs->tftpStreams[s]);
- fs->tftpStreams[s] = NULL;
- rtems_mutex_unlock (&fs->tftp_mutex);
+ long value;
+ const char *start = *pos;
+ if (*remain < 2) {
+ return false;
+ value = strtoul(start, pos, TFTP_DECIMAL_BASE);
+ if (value < min || value > max || **pos != 0) {
+ return false;
+ *variable = (uint16_t) value;
+ (*pos)++;
+ *remain -= *pos - start;
-static void
-rtems_tftpfs_shutdown (rtems_filesystem_mount_table_entry_t* mt_entry)
- tftpfs_info_t *fs = tftpfs_info_mount_table (mt_entry);
- int s;
- for (s = 0; s < fs->nStreams; s++)
- releaseStream (fs, s);
- rtems_mutex_destroy (&fs->tftp_mutex);
- free (fs);
- free (mt_entry->mt_fs_root->location.node_access);
+ return true;
* Map error message
-static int
-tftpErrno (struct tftpStream *tp)
+static int tftpErrno (uint16_t error_code)
unsigned int tftpError;
static const int errorMap[] = {
@@ -311,9 +434,10 @@ tftpErrno (struct tftpStream *tp)
ENXIO,
EEXIST,
ESRCH,
+ ENOTSUP, /* Error: Option negotiation failed (RFC 2347) */
- tftpError = ntohs (tp->pkbuf.tftpERROR.errorCode);
+ tftpError = ntohs (error_code);
if (tftpError < (sizeof errorMap / sizeof errorMap[0]))
return errorMap[tftpError];
else
@@ -321,25 +445,87 @@ tftpErrno (struct tftpStream *tp)
- * Send a message to make the other end shut up
+ * Parse options from an OACK packet
-static void
-sendStifle (struct tftpStream *tp, struct sockaddr_in *to)
+static bool parse_options (
+ union tftpPacket *receive_buf,
+ size_t packet_size,
+ tftp_options *options_in,
+ tftp_options *options_out
+ char *pos = receive_buf->tftpOACK.options;
+ size_t remain = packet_size - sizeof (receive_buf->tftpOACK.opcode);
+ * Make sure there is a 0 byte in the end before comparing strings
+ if (remain > 0 && pos[remain - 1] != 0) {
+ return false;
+ while (remain > 0) {
+ if (strcasecmp(pos, TFTP_BLOCK_SIZE_OPTION) == 0 &&
+ options_in->block_size != TFTP_RFC1350_BLOCK_SIZE) {
+ remain -= sizeof (TFTP_BLOCK_SIZE_OPTION);
+ pos += sizeof (TFTP_BLOCK_SIZE_OPTION);
+ if (!parse_decimal_number (
+ &pos,
+ &remain,
+ TFTP_BLOCK_SIZE_MIN,
+ options_in->block_size,
+ &options_out->block_size)) {
+ return false;
+ } else if (strcasecmp(pos, TFTP_WINDOW_SIZE_OPTION) == 0 &&
+ options_in->window_size != TFTP_RFC1350_WINDOW_SIZE) {
+ remain -= sizeof (TFTP_WINDOW_SIZE_OPTION);
+ pos += sizeof (TFTP_WINDOW_SIZE_OPTION);
+ &pos,
+ &remain,
+ TFTP_WINDOW_SIZE_MIN,
+ options_in->window_size,
+ &options_out->window_size)) {
+ return false;
+ } else {
+ return false; /* Unknown option */
+ return true;
+ * Send an error message
+static void send_error (
+ struct sockaddr_in *to,
+ uint8_t error_code,
+ const char *error_message
int len;
struct {
uint16_t opcode;
uint16_t errorCode;
- char errorMessage[12];
+ char errorMessage[80];
} msg;
* Create the error packet (Unknown transfer ID).
msg.opcode = htons (TFTP_OPCODE_ERROR);
- msg.errorCode = htons (5);
- len = sizeof msg.opcode + sizeof msg.errorCode + 1;
- len += sprintf (msg.errorMessage, "GO AWAY");
+ msg.errorCode = htons (error_code);
+ len = snprintf (msg.errorMessage, sizeof (msg.errorMessage), error_message);
+ if (len >= sizeof (msg.errorMessage)) {
+ len = sizeof (msg.errorMessage) - 1;
+ len += sizeof (msg.opcode) + sizeof (msg.errorCode) + 1;
* Send it
@@ -348,32 +534,47 @@ sendStifle (struct tftpStream *tp, struct sockaddr_in *to)
- * Wait for a data packet
+ * Send a message to make the other end shut up
+static void sendStifle (struct tftpStream *tp, struct sockaddr_in *to)
+ send_error (tp, to, TFTP_ERROR_CODE_UNKNOWN_ID, "GO AWAY");
+ * Wait for a packet
-static int
+static ssize_t
getPacket (struct tftpStream *tp, int retryCount)
- int len;
+ ssize_t len;
struct timeval tv;
- if (retryCount == 0) {
- tv.tv_sec = PACKET_FIRST_TIMEOUT_MILLISECONDS / 1000L;
- tv.tv_usec = (PACKET_FIRST_TIMEOUT_MILLISECONDS % 1000L) * 1000L;
- else {
- tv.tv_sec = PACKET_TIMEOUT_MILLISECONDS / 1000L;
- tv.tv_usec = (PACKET_TIMEOUT_MILLISECONDS % 1000L) * 1000L;
+ int flags = 0;
+ if (retryCount == GET_PACKET_DONT_WAIT) {
+ flags = MSG_DONTWAIT;
+ } else if (retryCount == 0) {
+ tv.tv_sec = tp->config.first_timeout / 1000L;
+ tv.tv_usec = (tp->config.first_timeout % 1000L) * 1000L;
+ setsockopt (tp->socket, SOL_SOCKET, SO_RCVTIMEO, &tv, sizeof tv);
+ } else {
+ tv.tv_sec = tp->config.timeout / 1000L;
+ tv.tv_usec = (tp->config.timeout % 1000L) * 1000L;
- setsockopt (tp->socket, SOL_SOCKET, SO_RCVTIMEO, &tv, sizeof tv);
for (;;) {
union {
struct sockaddr s;
struct sockaddr_in i;
} from;
socklen_t fromlen = sizeof from;
- len = recvfrom (tp->socket, &tp->pkbuf,
- sizeof tp->pkbuf, 0,
- &from.s, &fromlen);
+ len = recvfrom (tp->socket,
+ tp->receive_buf,
+ tp->packet_size,
+ flags,
+ &from.s,
+ &fromlen
if (len < 0)
break;
if (from.i.sin_addr.s_addr == tp->farAddress.sin_addr.s_addr) {
@@ -391,397 +592,747 @@ getPacket (struct tftpStream *tp, int retryCount)
sendStifle (tp, &from.i);
- tv.tv_sec = 0;
- tv.tv_usec = 0;
- if (rtems_tftp_driver_debug) {
- if (len >= (int) sizeof tp->pkbuf.tftpACK) {
- int opcode = ntohs (tp->pkbuf.tftpDATA.opcode);
- switch (opcode) {
- default:
- printf ("TFTP: OPCODE %d\n", opcode);
- break;
- case TFTP_OPCODE_DATA:
- printf ("TFTP: RECV %d\n", ntohs (tp->pkbuf.tftpDATA.blocknum));
- break;
- case TFTP_OPCODE_ACK:
- printf ("TFTP: GOT ACK %d\n", ntohs (tp->pkbuf.tftpACK.blocknum));
- break;
- else {
- printf ("TFTP: %d-byte packet\n", len);
+ if (retryCount != GET_PACKET_DONT_WAIT) {
+ tv.tv_sec = 0;
+ tv.tv_usec = 0;
-#endif
return len;
+static int process_unexpected_packet (struct tftpStream *tp, ssize_t len)
+ (void) len;
+ send_error (
+ tp,
+ &tp->farAddress,
+ TFTP_ERROR_CODE_ILLEGAL,
+ "Got packet with unexpected opcode from server"
+ return EPROTO;
+static int process_malformed_packet (struct tftpStream *tp, ssize_t len)
+ (void) len;
+ send_error (
+ tp,
+ &tp->farAddress,
+ "Got malformed packet from server"
+ return EPROTO;
+static int process_error_packet (struct tftpStream *tp, ssize_t len)
+ (void) len;
+ return tftpErrno (tp->receive_buf->tftpERROR.errorCode);
- * Send an acknowledgement
+ * When an RRQ or a WRQ with options is sent and the server responds with
+ * an error, this function will trigger a re-sent of an RRQ or WRQ
+ * without options (falling back to old RFC1350).
+ * If someone wants to change the implementation to force using options
+ * (i.e. prevent fallback to RFC1350), at least these points must be
+ * considered:
+ * * Use `process_error_packet()` instead of
+ * `process_error_packet_option_negotiation()`
+ * * React to DATA and ACK packets, which are an immediate response to
+ * an RRQ or a WRQ with options, with an error packet.
+ * * Check the option values in the OACK whether they are in the
+ * desired range.
-static int
-sendAck (struct tftpStream *tp)
+static int process_error_packet_option_negotiation (
+ struct tftpStream *tp, ssize_t len
- printf ("TFTP: ACK %d\n", tp->blocknum);
-#endif
+ (void) len;
+ * Setting tp->config.options causes an RRQ or a WRQ to be created without
+ * options.
+ * Setting tp->server_option is defensive programming as these fields
+ * should already have these values.
+ tp->config.options.block_size = TFTP_RFC1350_BLOCK_SIZE;
+ tp->config.options.window_size = TFTP_RFC1350_WINDOW_SIZE;
+ tp->server_options.block_size = TFTP_RFC1350_BLOCK_SIZE;
+ tp->server_options.window_size = TFTP_RFC1350_WINDOW_SIZE;
+ tp->process_error_packet = process_error_packet;
+ * GOT_FIRST_OUT_OF_ORDER_PACKET will trigger a re-send of the RRQ or WRQ.
+ return GOT_FIRST_OUT_OF_ORDER_PACKET;
+static int process_data_packet (struct tftpStream *tp, ssize_t len)
+ ssize_t plen;
+ int32_t pkt_blocknum;
+ if (len < sizeof (tp->receive_buf->tftpACK)) {
+ return process_malformed_packet (tp, len);
+ pkt_blocknum = (int32_t) ntohs (tp->receive_buf->tftpACK.blocknum);
+ if (pkt_blocknum == 0) {
+ * In case of reading a file from the server:
+ * If the latest ACK packet(s) did not reach the server, the server
+ * starts the window from the last ACK it received. This if-clause
+ * ensures, the client sends an ACK after having seen `windowsize`
+ * packets.
+ if (pkt_blocknum < tp->blocknum_of_first_packet_of_window &&
+ pkt_blocknum >= (int32_t) tp->blocknum + 1 -
+ (int32_t) tp->server_options.window_size) {
+ tp->blocknum_of_first_packet_of_window = pkt_blocknum;
+ if (!tp->ignore_out_of_order_packets &&
+ pkt_blocknum > (int32_t) tp->blocknum + 1) {
+ tp->ignore_out_of_order_packets = true;
+ } else if (pkt_blocknum == (int32_t) tp->blocknum) {
+ * If the last ACK packet send by the client did not reach the
+ * server, the server re-sends all packets of the window. In this
+ * case, the client must re-send the ACK packet after having
+ * received the last packet of the window (even through it has
+ * already received that packet before).
+ * GOT_OLD_PACKET would wrongly suppress this.
+ return GOT_DUPLICATE_OF_CURRENT_PACKET;
+ } else if (pkt_blocknum != (int32_t) tp->blocknum + 1) {
+ return GOT_OLD_PACKET;
+ tp->ignore_out_of_order_packets = false;
+ tp->blocknum++;
+ tp->nused = 0; /* Only for 2nd, 3rd, 4th DATA packet received */
+ tp->nleft = BLK_SIZE_FROM_PKT_SIZE (len);
+ tp->at_eof = (tp->nleft < tp->server_options.block_size);
+ * After the last DATA packet, the client must send a final ACK
+ if (tp->at_eof) {
+ plen = prepare_ack_packet_for_sending (tp, true, &send_buf, NULL, NULL);
+ * Send it. Errors during send will not matter for this last ACK.
+ sendto (
+ tp->socket,
+ send_buf,
+ plen,
+ 0,
+ (struct sockaddr *) &tp->farAddress,
+ sizeof (tp->farAddress)
+ tp->prepare_packet_for_sending = prepare_ack_packet_for_sending;
+ return GOT_EXPECTED_PACKET;
+static int process_ack_packet (struct tftpStream *tp, ssize_t len)
+ uint16_t blocknum_ack;
+ blocknum_ack = ntohs (tp->receive_buf->tftpACK.blocknum);
+ if ((int32_t) blocknum_ack == tp->blocknum_of_first_packet_of_window - 1 &&
+ blocknum_ack != 0
+ tp->blocknum = tp->blocknum_of_first_packet_of_window;
+ if ((int32_t) blocknum_ack < tp->blocknum_of_first_packet_of_window ||
+ blocknum_ack > tp->blocknum_last_filled) {
+ tp->blocknum = blocknum_ack + 1;
+ tp->blocknum_of_first_packet_of_window = (int32_t) tp->blocknum;
+ tp->prepare_packet_for_sending = prepare_data_packet_for_sending;
+ const void *not_used
+ (void) not_used;
+ ssize_t len;
+ *send_buf = get_send_buffer_packet (tp, tp->blocknum);
+ len = PKT_SIZE_FROM_BLK_SIZE (
+ (tp->blocknum == tp->blocknum_eof_block) ? tp->nused : tp->block_size
+ (*send_buf)->tftpDATA.opcode = htons (TFTP_OPCODE_DATA);
+ (*send_buf)->tftpDATA.blocknum = htons (tp->blocknum);
+ * If the client sends the last packet of a window,
+ * it must wait for an ACK and - in case no ACK is received - begin
+ * a retransmission with the first packet of the window.
+ * Note that the last DATA block for the whole transfer is also
+ * a "last packet of a window".
+ if ((int32_t) tp->blocknum + 1 >=
+ tp->blocknum_of_first_packet_of_window + tp->send_buf_size_in_pkts ||
+ tp->blocknum == tp->blocknum_eof_block) {
+ tp->blocknum = (uint16_t) tp->blocknum_of_first_packet_of_window;
+ } else {
+ tp->blocknum++;
+ *wait_for_packet_reception = false;
+ tp->process_data_packet = process_unexpected_packet;
+ tp->process_ack_packet = process_ack_packet;
+ tp->process_oack_packet = process_unexpected_packet;
+ * Our last packet won't necessarily be acknowledged!
+ if (tp->blocknum == tp->blocknum_eof_block) {
+ tp->retransmission_error_code = 0;
+ return len;
+ (void) wait_for_packet_reception;
+ if (!force_retransmission &&
+ tp->blocknum_of_first_packet_of_window - 1 +
+ (int32_t) tp->server_options.window_size > (int32_t) tp->blocknum) {
+ return DO_NOT_SEND_PACKET;
+ tp->blocknum_of_first_packet_of_window = (int32_t) tp->blocknum + 1;
* Create the acknowledgement
- tp->pkbuf.tftpACK.opcode = htons (TFTP_OPCODE_ACK);
- tp->pkbuf.tftpACK.blocknum = htons (tp->blocknum);
+ *send_buf = tp->send_buf;
+ (*send_buf)->tftpACK.opcode = htons (TFTP_OPCODE_ACK);
+ (*send_buf)->tftpACK.blocknum = htons (tp->blocknum);
+ tp->process_data_packet = process_data_packet;
+ tp->process_ack_packet = process_unexpected_packet;
+ return sizeof (tp->send_buf->tftpACK);
+static int process_oack_packet (struct tftpStream *tp, ssize_t len)
+ if (!parse_options(tp->receive_buf,
+ len,
+ &tp->config.options,
+ &tp->server_options)) {
+ send_error (
+ tp,
+ &tp->farAddress,
+ TFTP_ERROR_CODE_OPTION_NEGO,
+ "Bad options, option values or malformed OACK packet"
+ return EPROTO;
+ if (tp->is_for_reading) {
+ * Since no DATA packet has been received yet, tell
+ * tftp_read() there is no data left.
+ tp->nleft = 0;
+ } else {
+ tp->blocknum_of_first_packet_of_window = 1;
+static ssize_t prepare_request_packet_for_sending (
+ ssize_t len;
+ len = create_request (
+ *send_buf,
+ tp->block_size,
+ tp->is_for_reading,
+ path_name,
+ if (len < 0) {
+ tp->error = ENAMETOOLONG;
+ } else {
+ tp->process_data_packet = tp->is_for_reading ?
+ process_data_packet : process_unexpected_packet;
+ tp->process_ack_packet = tp->is_for_reading ?
+ process_unexpected_packet : process_ack_packet;
+ tp->process_oack_packet = MUST_SEND_OPTIONS(tp->config.options) ?
+ process_oack_packet : process_unexpected_packet;
+ tp->process_error_packet = MUST_SEND_OPTIONS(tp->config.options) ?
+ process_error_packet_option_negotiation : process_error_packet;
- * Send it
+ * getPacket() will change these values when the first packet is
+ * received. Yet, this first packet may be an unexpected one
+ * (e.g. an ERROR or having a wrong block number).
+ * If a second, third, forth, ... RRQ/WRQ is to be sent, it should
+ * be directed to the server port again and not to the port the
+ * first unexpected packet came from.
- if (sendto (tp->socket, (char *)&tp->pkbuf, sizeof tp->pkbuf.tftpACK, 0,
- (struct sockaddr *)&tp->farAddress,
- sizeof tp->farAddress) < 0)
- return errno;
- return 0;
+ tp->farAddress.sin_port = htons (tp->config.server_port);
+ tp->firstReply = 1;
+ return len;
- * Convert a path to canonical form
+ * Conduct one communication step with the server. For windowsize == 1,
+ * one step is:
+ * a) Send a packet to the server
+ * b) Receive a reply packet from the server
+ * c) Handle errors (if any)
+ * d) If no packet has been received from the server and the maximum
+ * retransmission count has not yet been reached, start over with a)
+ * The flow of packets (i.e. which packet to send and which packet(s) to
+ * expect from the server) is controlled by function pointers found in
+ * struct tftpStream.
+ * Besides of handling errors and retransmissions, the essential data exchange
+ * follows these patterns:
+ * Connection establishment and option negotiation:
+ * * Send RRQ/WRQ (read or write request packet)
+ * * Receive OACK (read and write) or ACK (write only) or DATA (read only)
+ * Read step with windowsize == 1:
+ * * Send ACK packet
+ * * Receive DATA packet
+ * Sending the very last ACK packet for a "read" session is treated as a
+ * special case.
+ * Write step with windowsize == 1:
+ * * Send DATA packet
+ * * Receive ACK packet
+ * A windowsize lager than one makes thinks more complicated.
+ * In this case, a step normally only receives (read) or only sends (write)
+ * a packet. The sending or receiving of the ACK packets is skipped normally
+ * and happens only at the last step of the window (in which case this last
+ * step is similar to the windowsize == 1 case):
+ * Normal read step with windowsize > 1:
+ * Last read step of a window with windowsize > 1:
+ * Normal write step with windowsize > 1:
+ * * Check for an ACK packet but do not wait for it
+ * Last write step of a window with windowsize > 1:
+ * The "normal write step for windowsize > 1" checks whether an ACK packet
+ * has been received after each sending of a DATA packet. Package lost and
+ * exchanges in the network can give rise to situations in which the server
+ * sends more than a single ACK packet during a window. If these packets
+ * are not reacted on immediately, the network would be flooded with
+ * surplus packets. (An example where two ACK packets appear in a window
+ * appears in test case "read_file_windowsize_trouble" where the client/server
+ * roles are exchanged.)
-static void
-fixPath (char *path)
+static int communicate_with_server (
- char *inp, *outp, *base;
- outp = inp = path;
- base = NULL;
- for (;;) {
- if (inp[0] == '.') {
- if (inp[1] == '\0')
+ ssize_t len;
+ uint16_t opcode;
+ bool received_duplicated_or_old_package = false;
+ bool force_retransmission = false;
+ bool wait_for_packet_reception;
+ int retryCount = 0;
+ while (tp->error == 0) {
+ if (!received_duplicated_or_old_package) {
+ wait_for_packet_reception = true;
+ len = tp->prepare_packet_for_sending (
+ tp,
+ force_retransmission,
+ &send_buf,
+ &wait_for_packet_reception,
+ create_packet_data
+ if (len < 0) {
+ if (tp->error == 0) {
+ tp->error = EIO;
break;
- if (inp[1] == '/') {
- inp += 2;
- continue;
- if (inp[1] == '.') {
- if (inp[2] == '\0') {
- if ((base != NULL) && (outp > base)) {
- outp--;
- while ((outp > base) && (outp[-1] != '/'))
- outp--;
+ if (len != DO_NOT_SEND_PACKET) {
+ * Send the packet
+ if (sendto (tp->socket, send_buf, len, 0,
+ (struct sockaddr *)&tp->farAddress,
+ sizeof tp->farAddress) < 0) {
+ tp->error = EIO;
break;
- if (inp[2] == '/') {
- inp += 3;
- if (base == NULL)
- continue;
- if (outp > base) {
- outp--;
- outp--;
- continue;
- if (base == NULL)
- base = inp;
- while (inp[0] != '/') {
- if ((*outp++ = *inp++) == '\0')
- return;
- *outp++ = '/';
- while (inp[0] == '/')
- inp++;
- *outp = '\0';
- return;
+ received_duplicated_or_old_package = false;
+ force_retransmission = false;
-static void rtems_tftp_eval_path(rtems_filesystem_eval_path_context_t *self)
- int eval_flags = rtems_filesystem_eval_path_get_flags (self);
- if ((eval_flags & RTEMS_FS_MAKE) == 0) {
- int rw = RTEMS_FS_PERMS_READ | RTEMS_FS_PERMS_WRITE;
- if ((eval_flags & rw) != rw) {
- rtems_filesystem_location_info_t *currentloc =
- rtems_filesystem_eval_path_get_currentloc (self);
- char *current = currentloc->node_access;
- size_t currentlen = strlen (current);
- const char *path = rtems_filesystem_eval_path_get_path (self);
- size_t pathlen = rtems_filesystem_eval_path_get_pathlen (self);
- size_t len = currentlen + pathlen;
- rtems_filesystem_eval_path_clear_path (self);
- current = realloc (current, len + 1);
- if (current != NULL) {
- memcpy (current + currentlen, path, pathlen);
- current [len] = '\0';
- if (!rtems_tftp_is_directory (current, len)) {
- fixPath (current);
- currentloc->node_access = current;
- } else {
- rtems_filesystem_eval_path_error (self, ENOMEM);
+ * Get reply
+ len = getPacket (
+ tp,
+ wait_for_packet_reception ? retryCount : GET_PACKET_DONT_WAIT
+ if (len >= (int) sizeof (tp->receive_buf->tftpDATA.opcode)) {
+ opcode = ntohs (tp->receive_buf->tftpDATA.opcode);
+ switch (opcode) {
+ case TFTP_OPCODE_DATA:
+ tp->error = tp->process_data_packet (tp, len);
+ break;
+ case TFTP_OPCODE_ACK:
+ tp->error = tp->process_ack_packet (tp, len);
+ break;
+ case TFTP_OPCODE_OACK:
+ tp->error = tp->process_oack_packet (tp, len);
+ break;
+ case TFTP_OPCODE_ERROR:
+ tp->error = tp->process_error_packet (tp, len);
+ break;
+ default:
+ tp->error = process_unexpected_packet (tp, len);
+ break;
+ if (tp->error == GOT_EXPECTED_PACKET) {
+ break;
+ } else if (tp->error == GOT_DUPLICATE_OF_CURRENT_PACKET) {
+ tp->error = 0;
+ } else if (tp->error == GOT_OLD_PACKET) {
+ received_duplicated_or_old_package = true;
+ tp->error = 0;
+ } else if (tp->error <= GOT_FIRST_OUT_OF_ORDER_PACKET) {
+ force_retransmission = true;
+ tp->error = 0;
+ } /* else ... tp->error > 0 means "exit this function with error" */
+ } else if (len >= 0) {
+ tp->error = process_malformed_packet (tp, len);
+ } else if (len < 0 && !wait_for_packet_reception) {
+ tp->error = 0;
+ break;
} else {
- rtems_filesystem_eval_path_error (self, EINVAL);
+ * Timeout or other problems to receive packets
+ * Attempt a retransmission
+ if (++retryCount >= (int) tp->config.retransmissions) {
+ tp->error = tp->retransmission_error_code;
+ break;
- } else {
- rtems_filesystem_eval_path_error (self, EIO);
+ return tp->error;
- * The routine which does most of the work for the IMFS open handler
+ * Allocate and initialize an struct tftpStream object.
+ * This function does not check whether the config values are in valid ranges.
-static int rtems_tftp_open_worker(
- rtems_libio_t *iop,
- char *full_path_name,
- int oflag
+static struct tftpStream *create_stream(
+ const struct in_addr *farAddress,
- tftpfs_info_t *fs;
- struct tftpStream *tp;
- int retryCount;
- struct in_addr farAddress;
- int s;
- int len;
- char *cp1;
- char *cp2;
- char *remoteFilename;
- rtems_interval now;
- char *hostname;
+ struct tftpStream *tp = NULL;
+ tp = malloc (sizeof (struct tftpStream));
+ if (tp == NULL) {
+ return NULL;
- * Get the file system info.
+ * Initialize fields accessed by _Tftp_Destroy().
- fs = tftpfs_info_iop (iop);
+ tp->receive_buf = NULL;
+ tp->send_buf = NULL;
+ tp->socket = 0;
- * Extract the host name component
+ * Allocate send and receive buffer for exchange of RRQ/WRQ and ACK/OACK.
- if (*full_path_name == '/')
- full_path_name++;
+ tp->block_size = TFTP_RFC1350_BLOCK_SIZE;
+ tp->packet_size = PKT_SIZE_FROM_BLK_SIZE (tp->block_size);
+ tp->receive_buf = malloc (tp->packet_size);
+ if (tp->receive_buf == NULL) {
+ _Tftp_Destroy (tp);
+ return NULL;
+ tp->send_buf = tp->receive_buf;
+ tp->send_buf_size_in_pkts = 1;
- hostname = full_path_name;
- cp1 = strchr (full_path_name, ':');
- if (!cp1) {
-#ifdef RTEMS_NETWORKING
- hostname = "BOOTP_HOST";
-#endif
+ * Create the socket
+ if ((tp->socket = socket (AF_INET, SOCK_DGRAM, 0)) < 0) {
+ return NULL;
+ * Setup configuration and options
+ if ( config == NULL ) {
+ tftp_initialize_net_config (&tp->config);
} else {
- *cp1 = '\0';
- ++cp1;
+ tp->config = *config;
- * Convert hostname to Internet address
+ * If the server does not confirm our option values later on,
+ * use numbers from the original RFC 1350 for the actual transfer.
+ * Set the UDP destination to the TFTP server
+ * port on the remote machine.
+ tp->farAddress.sin_family = AF_INET;
+ tp->farAddress.sin_addr = *farAddress;
+ tp->nleft = 0;
+ tp->nused = 0;
+ tp->blocknum = 0;
+ tp->blocknum_last_filled = 0;
+ tp->blocknum_eof_block = UINT16_MAX;
+ tp->at_eof = false;
+ tp->is_for_reading = is_for_reading;
+ tp->prepare_packet_for_sending = prepare_request_packet_for_sending;
+ tp->retransmission_error_code = EIO;
+ tp->blocknum_of_first_packet_of_window = INT32_MIN;
+ tp->error = 0;
+ return tp;
+ * Change the size of the receive and send buffer to match the options
+ * values acknowledged by the server.
+static struct tftpStream *reallocate_stream_buffer(struct tftpStream *tp)
+ tp->block_size = tp->server_options.block_size;
+ * Defensive programming
+ if (tp->receive_buf == tp->send_buf) {
+ } else {
+ free (tp->send_buf);
+ tp->receive_buf = realloc (tp->receive_buf, tp->packet_size);
+ } else {
+ tp->send_buf_size_in_pkts = tp->server_options.window_size;
+ tp->send_buf = malloc (
+ tp->send_buf_size_in_pkts * tp->packet_size
+ if (tp->receive_buf == NULL || tp->send_buf == NULL) {
+ sendStifle (tp, &tp->farAddress);
+ return NULL;
+ return tp;
+ * Convert hostname to an Internet address
+static struct in_addr *get_ip_address(
+ struct in_addr *farAddress
if (strcmp (hostname, "BOOTP_HOST") == 0)
- farAddress = rtems_bsdnet_bootp_server_address;
+ *farAddress = rtems_bsdnet_bootp_server_address;
else
+ if (inet_aton (hostname, farAddress) == 0) {
#endif
- if (inet_aton (hostname, &farAddress) == 0) {
struct hostent *he = gethostbyname(hostname);
- if (he == NULL)
- return ENOENT;
- memcpy (&farAddress, he->h_addr, sizeof (farAddress));
+ if (he == NULL) {
+ return NULL;
+ memcpy (farAddress, he->h_addr, sizeof (*farAddress));
+#ifdef RTEMS_NETWORKING
+#endif
+ return farAddress;
- * Extract file pathname component
- if (strcmp (cp1, "BOOTP_FILE") == 0) {
- cp1 = rtems_bsdnet_bootp_boot_file_name;
+void tftp_initialize_net_config (tftp_net_config *config)
+ static const tftp_net_config default_config = {
+ .retransmissions = TFTP_RFC7440_DATA_RETRANSMISSIONS,
+ .server_port = TFTP_DEFAULT_SERVER_PORT,
+ .timeout = TFTP_RFC7440_TIMEOUT_MILLISECONDS,
+ .first_timeout = PACKET_FIRST_TIMEOUT_MILLISECONDS,
+ .options = {
+ .block_size = TFTP_DEFAULT_BLOCK_SIZE,
+ .window_size = TFTP_DEFAULT_WINDOW_SIZE
+ if (config != NULL) {
+ memcpy (config, &default_config, sizeof (default_config));
+int tftp_open(
+ const char *path,
+ struct tftpStream *tp;
+ struct in_addr farAddress;
+ int err;
+ rtems_interval now;
#endif
- if (*cp1 == '\0')
- return ENOENT;
- remoteFilename = cp1;
- if (strlen (remoteFilename) > (TFTP_BUFSIZE - 10))
- return ENOENT;
- * Find a free stream
+ * Check parameters
- for (s = 0 ; s < fs->nStreams ; s++) {
- if (fs->tftpStreams[s] == NULL)
- break;
+ if (tftp_handle == NULL) {
+ return EINVAL;
- if (s == fs->nStreams) {
- * Reallocate stream pointers
- * Guard against the case where realloc() returns NULL.
- struct tftpStream **np;
- np = realloc (fs->tftpStreams, ++fs->nStreams * sizeof *fs->tftpStreams);
- if (np == NULL) {
- return ENOMEM;
- fs->tftpStreams = np;
+ *tftp_handle = NULL;
+ if (hostname == NULL || path == NULL) {
+ return EINVAL;
+ if (config != NULL && (
+ config->options.window_size < TFTP_WINDOW_SIZE_MIN ||
+ config->options.block_size < TFTP_BLOCK_SIZE_MIN ||
+ config->options.block_size > TFTP_BLOCK_SIZE_MAX ) ) {
+ return EINVAL;
- tp = fs->tftpStreams[s] = malloc (sizeof (struct tftpStream));
- if (tp == NULL)
- return ENOMEM;
- iop->data0 = s;
- iop->data1 = tp;
- * Create the socket
+ * Create tftpStream structure
- if ((tp->socket = socket (AF_INET, SOCK_DGRAM, 0)) < 0) {
+ if (get_ip_address( hostname, &farAddress ) == NULL) {
+ return ENOENT;
+ tp = create_stream( config, &farAddress, is_for_reading );
+ if (tp == NULL) {
return ENOMEM;
* Bind the socket to a local address
+ * This legacy code is left here in case RTEMS legacy networking
+ * needs to bind the socket. According to man-page and POSIX documentation
+ * the OS does automatically bind a client socket to a free port. Hence,
+ * this code is not needed for use with libbsd.
retryCount = 0;
now = rtems_clock_get_ticks_since_boot();
for (;;) {
+ static int use_counter = 0;
int try = (now + retryCount) % 10;
tp->myAddress.sin_family = AF_INET;
- tp->myAddress.sin_port = htons (UDP_PORT_BASE + fs->nStreams * try + s);
+ tp->myAddress.sin_port = htons (UDP_PORT_BASE + use_counter * try);
tp->myAddress.sin_addr.s_addr = htonl (INADDR_ANY);
- if (bind (tp->socket, (struct sockaddr *)&tp->myAddress, sizeof tp->myAddress) >= 0)
+ if (bind (tp->socket, (struct sockaddr *)&tp->myAddress, sizeof tp->myAddress) >= 0) {
+ use_counter = ( use_counter + 1 ) % 100;
break;
if (++retryCount == 10) {
return EBUSY;
+#endif
- * Set the UDP destination to the TFTP server
- * port on the remote machine.
- tp->farAddress.sin_family = AF_INET;
- tp->farAddress.sin_addr = farAddress;
- tp->farAddress.sin_port = htons (69);
- * Start the transfer
+ * Send RRQ or WRQ and wait for reply
- tp->firstReply = 1;
- retryCount = 0;
- for (;;) {
- * Create the request
- if ((oflag & O_ACCMODE) == O_RDONLY) {
- tp->writing = 0;
- tp->pkbuf.tftpRWRQ.opcode = htons (TFTP_OPCODE_RRQ);
- else {
- tp->writing = 1;
- tp->pkbuf.tftpRWRQ.opcode = htons (TFTP_OPCODE_WRQ);
- cp1 = (char *) tp->pkbuf.tftpRWRQ.filename_mode;
- cp2 = (char *) remoteFilename;
- while ((*cp1++ = *cp2++) != '\0')
- continue;
- cp2 = "octet";
- continue;
- len = cp1 - (char *)&tp->pkbuf.tftpRWRQ;
- * Send the request
- if (sendto (tp->socket, (char *)&tp->pkbuf, len, 0,
- sizeof tp->farAddress) < 0) {
- return EIO;
- * Get reply
- len = getPacket (tp, retryCount);
- if (!tp->writing
- && (opcode == TFTP_OPCODE_DATA)
- && (ntohs (tp->pkbuf.tftpDATA.blocknum) == 1)) {
- tp->nused = 0;
- tp->blocknum = 1;
- tp->nleft = len - 2 * sizeof (uint16_t );
- tp->eof = (tp->nleft < TFTP_BUFSIZE);
- if (sendAck (tp) != 0) {
- return EIO;
- break;
- if (tp->writing
- && (opcode == TFTP_OPCODE_ACK)
- && (ntohs (tp->pkbuf.tftpACK.blocknum) == 0)) {
- tp->nused = 0;
- tp->blocknum = 1;
- break;
- if (opcode == TFTP_OPCODE_ERROR) {
- int e = tftpErrno (tp);
- return e;
- * Keep trying
- if (++retryCount >= OPEN_RETRY_LIMIT) {
- return EIO;
+ err = communicate_with_server (tp, path);
+ if ( err != 0 ) {
+ return err;
- return 0;
-static int rtems_tftp_open(
- const char *new_name,
- int oflag,
- mode_t mode
- char *full_path_name;
- int err;
- full_path_name = iop->pathinfo.node_access;
- if (rtems_tftp_is_directory (full_path_name, strlen (full_path_name))) {
- rtems_set_errno_and_return_minus_one (ENOTSUP);
- if (fs->flags & TFTPFS_VERBOSE)
- printf ("TFTPFS: %s\n", full_path_name);
- err = rtems_tftp_open_worker (iop, full_path_name, oflag);
- if (err != 0) {
- rtems_set_errno_and_return_minus_one (err);
+ *tftp_handle = reallocate_stream_buffer ( tp );
+ if( *tftp_handle == NULL ) {
+ return ENOMEM;
return 0;
@@ -790,19 +1341,19 @@ static int rtems_tftp_open(
* Read from a TFTP stream
-static ssize_t rtems_tftp_read(
+ssize_t tftp_read(
void *buffer,
size_t count
char *bp;
- struct tftpStream *tp = iop->data1;
- int retryCount;
+ struct tftpStream *tp = tftp_handle;
int nwant;
+ int err;
- if (!tp)
- rtems_set_errno_and_return_minus_one( EIO );
+ if (tp == NULL || !tp->is_for_reading || buffer == NULL)
+ return -EIO;
* Read till user request is satisfied or EOF is reached
@@ -816,7 +1367,7 @@ static ssize_t rtems_tftp_read(
ncopy = nwant;
else
ncopy = tp->nleft;
- memcpy (bp, &tp->pkbuf.tftpDATA.data[tp->nused], ncopy);
+ memcpy (bp, &tp->receive_buf->tftpDATA.data[tp->nused], ncopy);
tp->nused += ncopy;
tp->nleft -= ncopy;
bp += ncopy;
@@ -824,39 +1375,29 @@ static ssize_t rtems_tftp_read(
if (nwant == 0)
break;
- if (tp->eof)
+ if (tp->at_eof) {
break;
* Wait for the next packet
- retryCount = 0;
- for (;;) {
- int len = getPacket (tp, retryCount);
- if (len >= (int)sizeof tp->pkbuf.tftpACK) {
- uint16_t nextBlock = tp->blocknum + 1;
- if ((opcode == TFTP_OPCODE_DATA)
- && (ntohs (tp->pkbuf.tftpDATA.blocknum) == nextBlock)) {
- tp->nused = 0;
- tp->nleft = len - 2 * sizeof (uint16_t);
- tp->blocknum++;
- rtems_set_errno_and_return_minus_one (EIO);
- break;
- rtems_set_errno_and_return_minus_one (tftpErrno (tp));
- * Keep trying?
- if (++retryCount == IO_RETRY_LIMIT)
+ tp->retransmission_error_code = -EIO;
+ err = communicate_with_server(tp, NULL);
+ if (err == tp->retransmission_error_code) {
+ return -EIO;
+ * If communicate_with_server() returns an error, either
+ * * an error message from the server was received or
+ * * an error message was already sent to the server
+ * Setting tp->at_eof true, prevents all further calls to
+ * communicate_with_server() and suppresses the sending of
+ * an error message to the server by tftp_close().
+ if (err != 0) {
+ tp->at_eof = true;
+ return -err;
return count - nwant;
@@ -864,101 +1405,110 @@ static ssize_t rtems_tftp_read(
* Flush a write buffer and wait for acknowledgement
+ * This function returns only if there is at least one packet buffer free
+ * in the tp->send_buf. This ensures that tftp_write() can store
+ * further data for sending in this free packet buffer.
+ * When the end of file has been reached (i.e. tftp_close() called this
+ * function), this function returns only after all packets
+ * in the write buffer have been send and acknowledged (or if an error
+ * occurred).
static int rtems_tftp_flush (struct tftpStream *tp)
- int wlen, rlen;
- int retryCount = 0;
+ int err;
- wlen = tp->nused + 2 * sizeof (uint16_t );
- for (;;) {
- tp->pkbuf.tftpDATA.opcode = htons (TFTP_OPCODE_DATA);
- tp->pkbuf.tftpDATA.blocknum = htons (tp->blocknum);
- printf ("TFTP: SEND %d (%d)\n", tp->blocknum, tp->nused);
-#endif
- if (sendto (tp->socket, (char *)&tp->pkbuf, wlen, 0,
- return EIO;
- rlen = getPacket (tp, retryCount);
+ if (tp->at_eof) {
+ return 0;
+ do {
- * Our last packet won't necessarily be acknowledged!
- if ((rlen < 0) && (tp->nused < sizeof tp->pkbuf.tftpDATA.data))
- return 0;
- if (rlen >= (int)sizeof tp->pkbuf.tftpACK) {
- int opcode = ntohs (tp->pkbuf.tftpACK.opcode);
- if ((opcode == TFTP_OPCODE_ACK)
- && (ntohs (tp->pkbuf.tftpACK.blocknum) == tp->blocknum)) {
- tp->nused = 0;
- tp->blocknum++;
- return 0;
- return tftpErrno (tp);
+ if (err != 0) {
+ return err;
+ } while(
+ (int32_t) tp->blocknum_last_filled + 1 >=
+ * tp->blocknum_eof_block == tp->blocknum_last_filled
+ * holds only true when the user invoked tftp_close().
+ (tp->blocknum_eof_block == tp->blocknum_last_filled &&
+ tp->blocknum_of_first_packet_of_window <=
+ (int32_t) tp->blocknum_eof_block)
- * Keep trying?
- return EIO;
+ return 0;
* Close a TFTP stream
-static int rtems_tftp_close(
+int tftp_close(
+ void *tftp_handle
int e = 0;
- if (!tp)
+ if (tp == NULL) {
+ return 0;
- if (tp->writing)
+ if (!tp->is_for_reading) {
+ tp->blocknum_last_filled++;
+ tp->blocknum_eof_block = tp->blocknum_last_filled;
e = rtems_tftp_flush (tp);
- if (!tp->eof && !tp->firstReply) {
+ if (!tp->at_eof && !tp->firstReply) {
* Tell the other end to stop
rtems_interval ticksPerSecond;
- sendStifle (tp, &tp->farAddress);
+ send_error (
+ tp,
+ &tp->farAddress,
+ TFTP_ERROR_CODE_NO_USER,
+ "User (client) stopped reading or "
+ "server stopped sending packets (timeout)"
ticksPerSecond = rtems_clock_get_ticks_per_second();
rtems_task_wake_after (1 + ticksPerSecond / 10);
- releaseStream (fs, iop->data0);
- if (e)
- rtems_set_errno_and_return_minus_one (e);
- return 0;
+ return e;
-static ssize_t rtems_tftp_write(
const void *buffer,
size_t count
const char *bp;
int nleft, nfree, ncopy;
+ int err;
* Bail out if an error has occurred
- if (!tp->writing)
+ if (tp == NULL || tp->is_for_reading || tp->at_eof || buffer == NULL) {
+ return -EIO;
* Write till user request is satisfied
@@ -970,119 +1520,45 @@ static ssize_t rtems_tftp_write(
bp = buffer;
nleft = count;
while (nleft) {
- nfree = sizeof tp->pkbuf.tftpDATA.data - tp->nused;
+ nfree = tp->block_size - tp->nused;
if (nleft < nfree)
ncopy = nleft;
else
ncopy = nfree;
- memcpy (&tp->pkbuf.tftpDATA.data[tp->nused], bp, ncopy);
+ send_buf = get_send_buffer_packet (tp, tp->blocknum_last_filled + 1);
+ memcpy (&send_buf->tftpDATA.data[tp->nused], bp, ncopy);
tp->nused += ncopy;
nleft -= ncopy;
bp += ncopy;
- if (tp->nused == sizeof tp->pkbuf.tftpDATA.data) {
- int e = rtems_tftp_flush (tp);
- if (e) {
- tp->writing = 0;
+ if (tp->nused == tp->block_size) {
+ err = rtems_tftp_flush (tp);
+ if (err) {
+ return -err;
+ tp->nused = 0;
return count;
- * Dummy version to let fopen(xxxx,"w") work properly.
-static int rtems_tftp_ftruncate(
- rtems_libio_t *iop RTEMS_UNUSED,
- off_t count RTEMS_UNUSED
- return 0;
-static int rtems_tftp_fstat(
- const rtems_filesystem_location_info_t *loc,
- struct stat *buf
+void _Tftp_Destroy(
+ void *tftp_handle
- const char *path = loc->node_access;
- size_t pathlen = strlen (path);
- buf->st_mode = S_IRWXU | S_IRWXG | S_IRWXO
- | (rtems_tftp_is_directory (path, pathlen) ? S_IFDIR : S_IFREG);
- return 0;
-static int rtems_tftp_clone(
- rtems_filesystem_location_info_t *loc
- int rv = 0;
- loc->node_access = strdup (loc->node_access);
- if (loc->node_access == NULL) {
- errno = ENOMEM;
- rv = -1;
+ if (tp == NULL) {
+ return;
- return rv;
-static void rtems_tftp_free_node_info(
- free (loc->node_access);
+ if (tp->socket >= 0) {
+ close (tp->socket);
-static bool rtems_tftp_are_nodes_equal(
- const rtems_filesystem_location_info_t *a,
- const rtems_filesystem_location_info_t *b
- return strcmp (a->node_access, b->node_access) == 0;
+ free (tp->receive_buf);
+ free (tp);
-static const rtems_filesystem_operations_table rtems_tftp_ops = {
- .lock_h = rtems_filesystem_default_lock,
- .unlock_h = rtems_filesystem_default_unlock,
- .eval_path_h = rtems_tftp_eval_path,
- .link_h = rtems_filesystem_default_link,
- .are_nodes_equal_h = rtems_tftp_are_nodes_equal,
- .mknod_h = rtems_filesystem_default_mknod,
- .rmnod_h = rtems_filesystem_default_rmnod,
- .fchmod_h = rtems_filesystem_default_fchmod,
- .chown_h = rtems_filesystem_default_chown,
- .clonenod_h = rtems_tftp_clone,
- .freenod_h = rtems_tftp_free_node_info,
- .mount_h = rtems_filesystem_default_mount,
- .unmount_h = rtems_filesystem_default_unmount,
- .fsunmount_me_h = rtems_tftpfs_shutdown,
- .utimens_h = rtems_filesystem_default_utimens,
- .symlink_h = rtems_filesystem_default_symlink,
- .readlink_h = rtems_filesystem_default_readlink,
- .rename_h = rtems_filesystem_default_rename,
- .statvfs_h = rtems_filesystem_default_statvfs
-static const rtems_filesystem_file_handlers_r rtems_tftp_handlers = {
- .open_h = rtems_tftp_open,
- .close_h = rtems_tftp_close,
- .read_h = rtems_tftp_read,
- .write_h = rtems_tftp_write,
- .ioctl_h = rtems_filesystem_default_ioctl,
- .lseek_h = rtems_filesystem_default_lseek,
- .fstat_h = rtems_tftp_fstat,
- .ftruncate_h = rtems_tftp_ftruncate,
- .fsync_h = rtems_filesystem_default_fsync_or_fdatasync,
- .fdatasync_h = rtems_filesystem_default_fsync_or_fdatasync,
- .fcntl_h = rtems_filesystem_default_fcntl,
- .kqfilter_h = rtems_filesystem_default_kqfilter,
- .mmap_h = rtems_filesystem_default_mmap,
- .poll_h = rtems_filesystem_default_poll,
- .readv_h = rtems_filesystem_default_readv,
- .writev_h = rtems_filesystem_default_writev
diff --git a/cpukit/libfs/src/ftpfs/tftp_driver.h b/cpukit/libfs/src/ftpfs/tftp_driver.h
new file mode 100644
index 0000000000..506fb17245
--- /dev/null
+++ b/cpukit/libfs/src/ftpfs/tftp_driver.h
@@ -0,0 +1,76 @@
+ * @file
+ * @brief This header file provides private interfaces of the
+ * TFTP client library.
+ * This file declares the private functions of the Trivial File
+ * Transfer Protocol (TFTP) client library.
+ * Copyright (C) 2022 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifndef _TFTP_DRIVER_H
+#define _TFTP_DRIVER_H
+/* Remove for C++ code */
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @brief Free the resources associated with a TFTP client connection.
+ * This directive releases any resources allocated at the client side.
+ * The connection is not closed which implies that the server will not
+ * be informed and data is likely lost. According to RFC 1350 the
+ * server will recognize the defect connection by timeouts.
+ * This directive is internally used when the TFTP file system is unmounted.
+ void *tftp_handle
+/* Only non-private to ease unit testing */
+ssize_t _Tftpfs_Parse_options(
+ const char *option_str,
+ tftp_net_config *tftp_config,
+ uint32_t *flags
+#ifdef __cplusplus
+#endif
+#endif /* _TFTP_DRIVER_H */
diff --git a/cpukit/libfs/src/ftpfs/tftpfs.c b/cpukit/libfs/src/ftpfs/tftpfs.c
index d0eadcf99a..2327aea5da 100644
--- a/cpukit/libfs/src/ftpfs/tftpfs.c
+++ b/cpukit/libfs/src/ftpfs/tftpfs.c
@@ -3,16 +3,21 @@
* @file
- * Transfer file to/from remote host
+ * the Trivial File Transfer Protocol (TFTP) file system.
+ * The code in this file handles the file system operations (such as
+ * `mount()`, `open()`, `read()`, `write()`, `close()` etc.).
+ * The networking part, i.e. the actual Trivial File Transfer Protocol
+ * implementation, is realized in another file - the
+ * @ref tftpDriver.c "TFTP client library".
- * Copyright (c) 1998 Eric Norum <eric at norum.ca>
+ * Copyright (C) 1998 W. Eric Norum <eric at norum.ca>
@@ -42,6 +47,7 @@
#include <malloc.h>
@@ -52,120 +58,8 @@
-#include <sys/types.h>
-#include <sys/socket.h>
-#include <netinet/in.h>
-#include <arpa/inet.h>
-#include <netdb.h>
-#include <rtems/rtems_bsdnet.h>
-#endif
-#endif
- * Range of UDP ports to try
-#define UDP_PORT_BASE 3180
- * Default limits
-#define PACKET_FIRST_TIMEOUT_MILLISECONDS 400L
- * TFTP opcodes
-#define TFTP_OPCODE_RRQ 1
-#define TFTP_OPCODE_WRQ 2
-#define TFTP_OPCODE_DATA 3
-#define TFTP_OPCODE_ACK 4
-#define TFTP_OPCODE_ERROR 5
- * Packets transferred between machines
-union tftpPacket {
- * RRQ/WRQ packet
- struct tftpRWRQ {
- uint16_t opcode;
- } tftpRWRQ;
- * DATA packet
- struct tftpDATA {
- uint16_t opcode;
- uint16_t blocknum;
- } tftpDATA;
- * ACK packet
- struct tftpACK {
- uint16_t opcode;
- } tftpACK;
- * ERROR packet
- struct tftpERROR {
- uint16_t opcode;
- uint16_t errorCode;
- } tftpERROR;
- * State of each TFTP stream
-struct tftpStream {
- * Data transfer socket
- int socket;
- struct sockaddr_in myAddress;
- struct sockaddr_in farAddress;
- * Indices into buffer
- int nleft;
- int nused;
- * Flags
- int firstReply;
- int eof;
- int writing;
@@ -178,18 +72,16 @@ struct tftpStream {
uint32_t flags;
- int nStreams;
+ size_t nStreams;
+ void ** volatile tftpStreams;
+ tftp_net_config tftp_config;
} tftpfs_info_t;
+/* Forward declarations */
@@ -201,6 +93,60 @@ static bool rtems_tftp_is_directory(
+ * Return value:
+ * 0 if options have been pracessed without error
+ * N+1 if parsing failed at position N
+ uint32_t *flags
+ const char *cur_pos = option_str;
+ size_t verbose_len = strlen ("verbose");
+ size_t rfc1350_len = strlen ("rfc1350");
+ int len;
+ while(cur_pos != NULL && *cur_pos != '\0') {
+ if (strncmp (cur_pos, "verbose", verbose_len) == 0) {
+ *flags |= TFTPFS_VERBOSE;
+ len = (int) verbose_len;
+ } else if (strncmp (cur_pos, "rfc1350", rfc1350_len) == 0) {
+ tftp_config->options.block_size = TFTP_RFC1350_BLOCK_SIZE;
+ tftp_config->options.window_size = TFTP_RFC1350_WINDOW_SIZE;
+ len = (int) rfc1350_len;
+ } else if (sscanf(
+ cur_pos,
+ "blocksize=%"SCNu16"%n",
+ &tftp_config->options.block_size,
+ &len
+ ) == 1) {
+ cur_pos,
+ "windowsize=%"SCNu16"%n",
+ &tftp_config->options.window_size,
+ &len
+ ) == 1) {
+ } else if (*cur_pos == ',') { /* skip surplus "," */
+ len = 0;
+ } else {
+ return cur_pos - option_str + 1;
+ cur_pos += len;
+ if (*cur_pos != ',' && *cur_pos != '\0') {
+ if (*cur_pos == ',') {
+ cur_pos++;
+ return 0;
const void *data
@@ -210,6 +156,8 @@ int rtems_tftpfs_initialize(
char *root_path;
+ size_t err_pos;
+ int errno_store = ENOMEM;
@@ -234,6 +182,19 @@ int rtems_tftpfs_initialize(
fs->nStreams = 0;
+ tftp_initialize_net_config (&fs->tftp_config);
+ err_pos = _Tftpfs_Parse_options (data, &fs->tftp_config, &fs->flags);
+ if (err_pos != 0) {
+ printf(
+ "TFTP FS: ERROR in mount options '%s'.\n"
+ "TFTP FS: Cannot parse from this point: '%s'\n",
+ ((char *) data),
+ ((char *) data) + (err_pos - 1)
+ errno_store = EINVAL;
+ goto error;
@@ -247,18 +208,6 @@ int rtems_tftpfs_initialize(
- if (data) {
- char* token;
- char* saveptr;
- while (token) {
return 0;
error:
@@ -266,19 +215,16 @@ error:
free (fs);
free (root_path);
+ rtems_set_errno_and_return_minus_one (errno_store);
+ * Clear the pointer to a stream
static void
+releaseStream (tftpfs_info_t *fs, size_t s)
@@ -287,166 +233,18 @@ static void
- int s;
+ size_t s;
+ void *tp;
+ for (s = 0; s < fs->nStreams; s++) {
+ tp = fs->tftpStreams[s];
+ _Tftp_Destroy(tp);
free (fs);
- * Map error message
-static int
- unsigned int tftpError;
- static const int errorMap[] = {
- EINVAL,
- ENOENT,
- EPERM,
- ENOSPC,
- EINVAL,
- ENXIO,
- EEXIST,
- ESRCH,
- if (tftpError < (sizeof errorMap / sizeof errorMap[0]))
- return errorMap[tftpError];
- else
- return 1000 + tftpError;
-static void
- int len;
- struct {
- uint16_t opcode;
- } msg;
- * Create the error packet (Unknown transfer ID).
- msg.opcode = htons (TFTP_OPCODE_ERROR);
- * Send it
- sendto (tp->socket, (char *)&msg, len, 0, (struct sockaddr *)to, sizeof *to);
-static int
-getPacket (struct tftpStream *tp, int retryCount)
- int len;
- struct timeval tv;
- else {
- for (;;) {
- union {
- struct sockaddr s;
- struct sockaddr_in i;
- } from;
- socklen_t fromlen = sizeof from;
- if (len < 0)
- break;
- if (from.i.sin_addr.s_addr == tp->farAddress.sin_addr.s_addr) {
- if (tp->firstReply) {
- tp->firstReply = 0;
- tp->farAddress.sin_port = from.i.sin_port;
- if (tp->farAddress.sin_port == from.i.sin_port)
- break;
- * Packet is from someone with whom we are
- * not interested. Tell them to go away.
- sendStifle (tp, &from.i);
- tv.tv_sec = 0;
- tv.tv_usec = 0;
- switch (opcode) {
- default:
- break;
- break;
- break;
- else {
-#endif
- return len;
-static int
-#endif
- * Create the acknowledgement
- * Send it
- return errno;
- return 0;
@@ -548,16 +346,12 @@ static int rtems_tftp_open_worker(
tftpfs_info_t *fs;
- int retryCount;
- int s;
- int len;
+ void *tp;
+ size_t s;
char *cp1;
- char *cp2;
char *hostname;
+ int err;
@@ -575,27 +369,14 @@ static int rtems_tftp_open_worker(
if (!cp1) {
+#else
+ return EINVAL; /* No ':' in path: no hostname or no filename */
#endif
} else {
*cp1 = '\0';
++cp1;
- if (strcmp (hostname, "BOOTP_HOST") == 0)
- else
-#endif
- struct hostent *he = gethostbyname(hostname);
- if (he == NULL)
- return ENOENT;
@@ -607,8 +388,20 @@ static int rtems_tftp_open_worker(
if (*cp1 == '\0')
return ENOENT;
- return ENOENT;
+ * Establish the connection
+ err = tftp_open (
+ hostname,
+ remoteFilename,
+ (oflag & O_ACCMODE) == O_RDONLY,
+ &fs->tftp_config,
+ &tp
+ if (err != 0) {
+ return err;
@@ -623,134 +416,21 @@ static int rtems_tftp_open_worker(
+ void **np;
if (np == NULL) {
+ tftp_close( tp );
return ENOMEM;
+ fs->tftpStreams[s] = tp;
- if (tp == NULL)
- return ENOMEM;
iop->data0 = s;
iop->data1 = tp;
- return ENOMEM;
- * Bind the socket to a local address
- retryCount = 0;
- now = rtems_clock_get_ticks_since_boot();
- for (;;) {
- int try = (now + retryCount) % 10;
- tp->myAddress.sin_family = AF_INET;
- tp->myAddress.sin_addr.s_addr = htonl (INADDR_ANY);
- break;
- if (++retryCount == 10) {
- return EBUSY;
- retryCount = 0;
- for (;;) {
- tp->writing = 0;
- else {
- tp->writing = 1;
- continue;
- cp2 = "octet";
- continue;
- return EIO;
- * Get reply
- if (!tp->writing
- tp->nused = 0;
- tp->blocknum = 1;
- return EIO;
- break;
- if (tp->writing
- tp->nused = 0;
- tp->blocknum = 1;
- break;
- return e;
- * Keep trying
- return EIO;
return 0;
@@ -796,116 +476,13 @@ static ssize_t rtems_tftp_read(
size_t count
- char *bp;
- int retryCount;
- int nwant;
+ void *tp = iop->data1;
+ ssize_t result = tftp_read (tp, buffer, count);
- if (!tp)
- * Read till user request is satisfied or EOF is reached
- bp = buffer;
- nwant = count;
- while (nwant) {
- if (tp->nleft) {
- int ncopy;
- if (nwant < tp->nleft)
- ncopy = nwant;
- else
- ncopy = tp->nleft;
- tp->nused += ncopy;
- tp->nleft -= ncopy;
- bp += ncopy;
- nwant -= ncopy;
- if (nwant == 0)
- break;
- if (tp->eof)
- break;
- * Wait for the next packet
- retryCount = 0;
- for (;;) {
- tp->nused = 0;
- tp->blocknum++;
- break;
- * Keep trying?
- return count - nwant;
- * Flush a write buffer and wait for acknowledgement
-static int rtems_tftp_flush (struct tftpStream *tp)
- int wlen, rlen;
- for (;;) {
-#endif
- return EIO;
- return 0;
- tp->nused = 0;
- tp->blocknum++;
- return 0;
- * Keep trying?
- return EIO;
+ if (result < 0) {
+ rtems_set_errno_and_return_minus_one (-result);
+ return result;
@@ -916,7 +493,7 @@ static int rtems_tftp_close(
tftpfs_info_t *fs;
int e = 0;
@@ -927,18 +504,8 @@ static int rtems_tftp_close(
if (!tp)
- if (tp->writing)
- e = rtems_tftp_flush (tp);
- * Tell the other end to stop
- rtems_interval ticksPerSecond;
- ticksPerSecond = rtems_clock_get_ticks_per_second();
- rtems_task_wake_after (1 + ticksPerSecond / 10);
+ e = tftp_close (tp);
if (e)
return 0;
@@ -950,44 +517,13 @@ static ssize_t rtems_tftp_write(
size_t count
- const char *bp;
- int nleft, nfree, ncopy;
+ ssize_t result = tftp_write (tp, buffer, count);
- * Bail out if an error has occurred
- if (!tp->writing)
- * Write till user request is satisfied
- * Notice that the buffer is flushed as soon as it is filled rather
- * than waiting for the next write or a close. This ensures that
- * the flush in close writes a less than full buffer so the far
- * end can detect the end-of-file condition.
- bp = buffer;
- nleft = count;
- while (nleft) {
- if (nleft < nfree)
- ncopy = nleft;
- else
- ncopy = nfree;
- nleft -= ncopy;
- bp += ncopy;
- if (e) {
- tp->writing = 0;
+ if (result < 0) {
- return count;
+ return result;
diff --git a/spec/build/cpukit/libtftpfs.yml b/spec/build/cpukit/libtftpfs.yml
index f63a50c933..6cf6b46ea8 100644
--- a/spec/build/cpukit/libtftpfs.yml
+++ b/spec/build/cpukit/libtftpfs.yml
@@ -15,6 +15,7 @@ install:
install-path: ${BSP_LIBDIR}
links: []
source:
+- cpukit/libfs/src/ftpfs/tftpDriver.c
- cpukit/libfs/src/ftpfs/tftpfs.c
target: tftpfs
type: build
2.35.3
