[PATCH 3/7] TFTPFS: Restore tftpDriver.c
Wed Jun 8 09:12:56 UTC 2022
On 06/06/2022 17:34, Joel Sherrill wrote:
> On Mon, Jun 6, 2022 at 9:02 AM Frank Kühndel
> <frank.kuehndel at embedded-brains.de
> <mailto:frank.kuehndel at embedded-brains.de>> wrote:
>     Hello Joel,
>     *From: *"Joel Sherrill" <joel at rtems.org <mailto:joel at rtems.org>>
>     *To: *"Frank Kühndel" <frank.kuehndel at embedded-brains.de
>     *Cc: *"rtems-devel at rtems.org <mailto:rtems-devel at rtems.org>"
>     <devel at rtems.org <mailto:devel at rtems.org>>
>     *Sent: *Saturday, June 4, 2022 1:05:25 AM
>     *Subject: *Re: [PATCH 3/7] TFTPFS: Restore tftpDriver.c
>      > Is this really just a move/rename? Does it preserve the git blame
>     info?
>     This (PATCH 3/7) is really a file "copy/recreate" (git blame info
>     will *NOT* be preserved). The move/rename is (at the very beginning
>     of) PATCH 2/7. My understanding is, that the git blame info will be
>     "moved" by PATCH 2/7 from original file tftpDriver.c to the
>     "copied/moved" tftpfs.c file provided the person commiting the
>     patches does not apply the trick described in the link I send in the
>     cover letter of this patch set. If that trick is applied both files
>     tftpDriver.c and tftpfs.c will have an intact git blame info - at
>     least as long as nothing "surprising" like a git rebase happens.
>     My feeling is that more original code survived in tftpfs.c than in
>     tftpDriver.c. Therefore, in case the trick is not applied (i.e. only
>     one file ends up with an intact git blame info) it is preferable
>     that this be tftpfs.c.
> OK. Work with Christian or Sebastian to make sure it gets committed
> correctly.
We don't use merge commits and never made any attempts to help git blame
doing the right thing. I will just squash the commits together.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
