[PATCH 2/2] arm: Fix PMSA regions for contiguous sections
Mon Jun 6 19:02:36 UTC 2022
Looks good to me
On Fri, Jun 3, 2022 at 12:38 AM Sebastian Huber
> Sections with identical attributes may be contiguous with a respective
> begin and end address which is not on a minimum region boundary.  The
> begin address is aligned down to the region base address.  The end
> address is aligned up to the region end address.  Account for this in
> the check for contiguous sections.
>  cpukit/score/cpu/arm/aarch32-psma-init.c | 8 ++++----
>  1 file changed, 4 insertions(+), 4 deletions(-)
> diff --git a/cpukit/score/cpu/arm/aarch32-psma-init.c b/cpukit/score/cpu/arm/aarch32-psma-init.c
> index 9edbb517fc..c6aebdc4be 100644
> --- a/cpukit/score/cpu/arm/aarch32-psma-init.c
> +++ b/cpukit/score/cpu/arm/aarch32-psma-init.c
> @@ -135,16 +135,16 @@ size_t _AArch32_PMSA_Map_sections_to_regions(
>        if ( attr == region_attr ) {
>          uint32_t region_end;
> -        if ( end == region_base ) {
> -          /* Extend the region region */
> +        if ( end - region_base <= AARCH32_PMSA_MIN_REGION_ALIGN ) {
> +          /* Extend the region */
>            regions[ ri ].base = base;
>            break;
>          region_end = region_limit + AARCH32_PMSA_MIN_REGION_ALIGN;
> -        if ( base == region_end ) {
> +        if ( region_end - base <= AARCH32_PMSA_MIN_REGION_ALIGN ) {
>            regions[ ri ].limit = limit;
>            break;
> 2.35.3
> devel mailing list
> devel at rtems.org
