[PATCH 1/2] bsps/stm32h7: move BSP start hooks into boards subdirectories
Karel Gardas
karel at functional.vision
Fri Jun 3 09:59:25 UTC 2022
The idea here is to prepare for better per-board specialization
of the hooks function code.
Sponsored-By: Precidata
.../stm/nucleo-h743zi/stm32h7-bspstarthooks.c | 78 +++++++++++++++++++
.../stm32h743i-eval/stm32h7-bspstarthooks.c | 78 +++++++++++++++++++
.../stm32h747i-disco/stm32h7-bspstarthooks.c | 78 +++++++++++++++++++
.../stm32h757i-eval/stm32h7-bspstarthooks.c | 78 +++++++++++++++++++
.../stm/stm32h7b3i-dk/stm32h7-bspstarthooks.c | 78 +++++++++++++++++++
bsps/arm/stm32h7/include/bsp.h | 6 ++
bsps/arm/stm32h7/start/bspstarthooks.c | 48 +-----------
.../bsps/arm/stm32h7/bspnucleoh743zi.yml | 1 +
spec/build/bsps/arm/stm32h7/bspstm32h7.yml | 1 +
.../arm/stm32h7/bspstm32h747i-disco-m4.yml | 1 +
.../bsps/arm/stm32h7/bspstm32h747i-disco.yml | 1 +
.../arm/stm32h7/bspstm32h757i-eval-m4.yml | 1 +
.../bsps/arm/stm32h7/bspstm32h757i-eval.yml | 1 +
.../bsps/arm/stm32h7/bspstm32h7b3i-dk.yml | 1 +
14 files changed, 407 insertions(+), 44 deletions(-)
create mode 100644 bsps/arm/stm32h7/boards/stm/nucleo-h743zi/stm32h7-bspstarthooks.c
create mode 100644 bsps/arm/stm32h7/boards/stm/stm32h743i-eval/stm32h7-bspstarthooks.c
create mode 100644 bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h7-bspstarthooks.c
create mode 100644 bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h7-bspstarthooks.c
create mode 100644 bsps/arm/stm32h7/boards/stm/stm32h7b3i-dk/stm32h7-bspstarthooks.c
diff --git a/bsps/arm/stm32h7/boards/stm/nucleo-h743zi/stm32h7-bspstarthooks.c b/bsps/arm/stm32h7/boards/stm/nucleo-h743zi/stm32h7-bspstarthooks.c
new file mode 100644
index 0000000000..8d34e357ee
--- /dev/null
+++ b/bsps/arm/stm32h7/boards/stm/nucleo-h743zi/stm32h7-bspstarthooks.c
@@ -0,0 +1,78 @@
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#include <bsp.h>
+#include <bsp/bootcard.h>
+#include <bsp/linker-symbols.h>
+#include <bsp/start.h>
+#include <stm32h7/hal.h>
+#include <stm32h7/memory.h>
+#include <stm32h7/mpu-config.h>
+#include <rtems/score/armv7m.h>
+#include <string.h>
+void bsp_start_hook_0(void)
+ if ((RCC->AHB3ENR & RCC_AHB3ENR_FMCEN) == 0) {
+ * Only perform the low-level initialization if necessary. An initialized
+ * FMC indicates that a boot loader already performed the low-level
+ * initialization.
+ SystemInit();
+ stm32h7_init_power();
+ stm32h7_init_oscillator();
+ stm32h7_init_clocks();
+ stm32h7_init_peripheral_clocks();
+ HAL_RCC_MCOConfig(RCC_MCO1, RCC_MCO1SOURCE_HSI, RCC_MCODIV_1);
+ HAL_Init();
+ SystemInit_ExtMemCtl();
+#if __CORTEX_M == 0x07U
+ if ((SCB->CCR & SCB_CCR_IC_Msk) == 0) {
+ SCB_EnableICache();
+ if ((SCB->CCR & SCB_CCR_DC_Msk) == 0) {
+ SCB_EnableDCache();
+ _ARMV7M_MPU_Setup(stm32h7_config_mpu_region, stm32h7_config_mpu_region_count);
+#endif
+void bsp_start_hook_1(void)
+ bsp_start_copy_sections_compact();
+ SCB_CleanDCache();
+ SCB_InvalidateICache();
+#endif
+ bsp_start_clear_bss();
diff --git a/bsps/arm/stm32h7/boards/stm/stm32h743i-eval/stm32h7-bspstarthooks.c b/bsps/arm/stm32h7/boards/stm/stm32h743i-eval/stm32h7-bspstarthooks.c
--- /dev/null
+++ b/bsps/arm/stm32h7/boards/stm/stm32h743i-eval/stm32h7-bspstarthooks.c
@@ -0,0 +1,78 @@
+ * are met:
+#include <bsp.h>
+ * initialization.
+ SystemInit();
+ HAL_Init();
+#endif
+#endif
diff --git a/bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h7-bspstarthooks.c b/bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h7-bspstarthooks.c
--- /dev/null
+++ b/bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h7-bspstarthooks.c
@@ -0,0 +1,78 @@
+ * are met:
+#include <bsp.h>
+ * initialization.
+ SystemInit();
+ HAL_Init();
+#endif
+#endif
diff --git a/bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h7-bspstarthooks.c b/bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h7-bspstarthooks.c
--- /dev/null
+++ b/bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h7-bspstarthooks.c
@@ -0,0 +1,78 @@
+ * are met:
+#include <bsp.h>
+ * initialization.
+ SystemInit();
+ HAL_Init();
+#endif
+#endif
diff --git a/bsps/arm/stm32h7/boards/stm/stm32h7b3i-dk/stm32h7-bspstarthooks.c b/bsps/arm/stm32h7/boards/stm/stm32h7b3i-dk/stm32h7-bspstarthooks.c
--- /dev/null
+++ b/bsps/arm/stm32h7/boards/stm/stm32h7b3i-dk/stm32h7-bspstarthooks.c
@@ -0,0 +1,78 @@
+ * are met:
+#include <bsp.h>
+ * initialization.
+ SystemInit();
+ HAL_Init();
+#endif
+#endif
diff --git a/bsps/arm/stm32h7/include/bsp.h b/bsps/arm/stm32h7/include/bsp.h
index 0ed9c361a5..08311bf51e 100644
--- a/bsps/arm/stm32h7/include/bsp.h
+++ b/bsps/arm/stm32h7/include/bsp.h
@@ -57,6 +57,12 @@ extern "C" {
uint32_t stm32h7_systick_frequency(void);
+/* default functions */
+void stm32h7_init_power(void);
+void stm32h7_init_oscillator(void);
+void stm32h7_init_clocks(void);
+void stm32h7_init_peripheral_clocks(void);
#ifdef __cplusplus
diff --git a/bsps/arm/stm32h7/start/bspstarthooks.c b/bsps/arm/stm32h7/start/bspstarthooks.c
index 54df5a2da8..1be1182404 100644
--- a/bsps/arm/stm32h7/start/bspstarthooks.c
+++ b/bsps/arm/stm32h7/start/bspstarthooks.c
@@ -41,7 +41,7 @@ void HAL_MspInit(void)
__HAL_RCC_SYSCFG_CLK_ENABLE();
-static void init_power(void)
HAL_PWREx_ConfigSupply(STM32H7_PWR_SUPPLY);
__HAL_PWR_VOLTAGESCALING_CONFIG(stm32h7_config_pwr_regulator_voltagescaling);
@@ -51,7 +51,7 @@ static void init_power(void)
-static void init_oscillator(void)
HAL_StatusTypeDef status;
@@ -61,7 +61,7 @@ static void init_oscillator(void)
-static void init_clocks(void)
@@ -74,7 +74,7 @@ static void init_clocks(void)
-static void init_peripheral_clocks(void)
@@ -84,43 +84,3 @@ static void init_peripheral_clocks(void)
-void bsp_start_hook_0(void)
- if ((RCC->AHB3ENR & RCC_AHB3ENR_FMCEN) == 0) {
- * Only perform the low-level initialization if necessary. An initialized
- * FMC indicates that a boot loader already performed the low-level
- * initialization.
- SystemInit();
- init_power();
- init_oscillator();
- init_clocks();
- init_peripheral_clocks();
- HAL_RCC_MCOConfig(RCC_MCO1, RCC_MCO1SOURCE_HSI, RCC_MCODIV_1);
- HAL_Init();
- SystemInit_ExtMemCtl();
-#if __CORTEX_M == 0x07U
- if ((SCB->CCR & SCB_CCR_IC_Msk) == 0) {
- SCB_EnableICache();
- if ((SCB->CCR & SCB_CCR_DC_Msk) == 0) {
- SCB_EnableDCache();
- _ARMV7M_MPU_Setup(stm32h7_config_mpu_region, stm32h7_config_mpu_region_count);
-#endif
-void bsp_start_hook_1(void)
- bsp_start_copy_sections_compact();
- SCB_CleanDCache();
- SCB_InvalidateICache();
-#endif
- bsp_start_clear_bss();
diff --git a/spec/build/bsps/arm/stm32h7/bspnucleoh743zi.yml b/spec/build/bsps/arm/stm32h7/bspnucleoh743zi.yml
index 9a3e556eda..f36c93a8ae 100644
--- a/spec/build/bsps/arm/stm32h7/bspnucleoh743zi.yml
+++ b/spec/build/bsps/arm/stm32h7/bspnucleoh743zi.yml
@@ -14,6 +14,7 @@ links:
- role: build-dependency
uid: grp
source:
+- bsps/arm/stm32h7/boards/stm/nucleo-h743zi/stm32h7-bspstarthooks.c
- bsps/arm/stm32h7/boards/stm/nucleo-h743zi/stm32h7-config-clk.c
- bsps/arm/stm32h7/boards/stm/nucleo-h743zi/stm32h7-config-osc.c
- bsps/arm/stm32h7/boards/stm/nucleo-h743zi/stm32h7-config-per.c
diff --git a/spec/build/bsps/arm/stm32h7/bspstm32h7.yml b/spec/build/bsps/arm/stm32h7/bspstm32h7.yml
index 52d47295d9..fe0451850d 100644
--- a/spec/build/bsps/arm/stm32h7/bspstm32h7.yml
+++ b/spec/build/bsps/arm/stm32h7/bspstm32h7.yml
uid: grp
source:
+- bsps/arm/stm32h7/boards/stm/stm32h743i-eval/stm32h7-bspstarthooks.c
- bsps/arm/stm32h7/boards/stm/stm32h743i-eval/stm32h7-config-clk.c
- bsps/arm/stm32h7/boards/stm/stm32h743i-eval/stm32h7-config-osc.c
- bsps/arm/stm32h7/boards/stm/stm32h743i-eval/stm32h7-config-per.c
diff --git a/spec/build/bsps/arm/stm32h7/bspstm32h747i-disco-m4.yml b/spec/build/bsps/arm/stm32h7/bspstm32h747i-disco-m4.yml
index 6356ccf942..27b8c34db2 100644
--- a/spec/build/bsps/arm/stm32h7/bspstm32h747i-disco-m4.yml
+++ b/spec/build/bsps/arm/stm32h7/bspstm32h747i-disco-m4.yml
@@ -16,6 +16,7 @@ links:
uid: tststm32h757i-eval
source:
+- bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h7-bspstarthooks.c
- bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h7-config-clk.c
- bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h7-config-osc.c
- bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h7-config-per.c
diff --git a/spec/build/bsps/arm/stm32h7/bspstm32h747i-disco.yml b/spec/build/bsps/arm/stm32h7/bspstm32h747i-disco.yml
index dcd5216391..8b13d16844 100644
--- a/spec/build/bsps/arm/stm32h7/bspstm32h747i-disco.yml
+++ b/spec/build/bsps/arm/stm32h7/bspstm32h747i-disco.yml
source:
diff --git a/spec/build/bsps/arm/stm32h7/bspstm32h757i-eval-m4.yml b/spec/build/bsps/arm/stm32h7/bspstm32h757i-eval-m4.yml
index 4850396281..5e9819a308 100644
--- a/spec/build/bsps/arm/stm32h7/bspstm32h757i-eval-m4.yml
+++ b/spec/build/bsps/arm/stm32h7/bspstm32h757i-eval-m4.yml
source:
+- bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h7-bspstarthooks.c
- bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h7-config-clk.c
- bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h7-config-osc.c
- bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h7-config-per.c
diff --git a/spec/build/bsps/arm/stm32h7/bspstm32h757i-eval.yml b/spec/build/bsps/arm/stm32h7/bspstm32h757i-eval.yml
index c8a4df954a..5d7ee1348d 100644
--- a/spec/build/bsps/arm/stm32h7/bspstm32h757i-eval.yml
+++ b/spec/build/bsps/arm/stm32h7/bspstm32h757i-eval.yml
source:
diff --git a/spec/build/bsps/arm/stm32h7/bspstm32h7b3i-dk.yml b/spec/build/bsps/arm/stm32h7/bspstm32h7b3i-dk.yml
index 907c107a33..20f5cb9a72 100644
--- a/spec/build/bsps/arm/stm32h7/bspstm32h7b3i-dk.yml
+++ b/spec/build/bsps/arm/stm32h7/bspstm32h7b3i-dk.yml
uid: ../../tstsmallmem
source:
+- bsps/arm/stm32h7/boards/stm/stm32h7b3i-dk/stm32h7-bspstarthooks.c
- bsps/arm/stm32h7/boards/stm/stm32h7b3i-dk/stm32h7-config-clk.c
- bsps/arm/stm32h7/boards/stm/stm32h7b3i-dk/stm32h7-config-osc.c
- bsps/arm/stm32h7/boards/stm/stm32h7b3i-dk/stm32h7-config-per.c
2.25.1
