[PATCH rtems v2] bsps/imx: Enable clock of ETH2
Christian Mauderer christian.mauderer at embedded-brains.de
Tue Jun 7 13:05:42 UTC 2022
 .../include/arm/freescale/imx/imx6ul_ccmreg.h | 152 ++++++++++++++++++
 bsps/arm/imx/start/bspstart.c                 |  20 +++
 spec/build/bsps/arm/imx/bspimx.yml            |   1 +
 3 files changed, 173 insertions(+)
 create mode 100644 bsps/arm/imx/include/arm/freescale/imx/imx6ul_ccmreg.h
diff --git a/bsps/arm/imx/include/arm/freescale/imx/imx6ul_ccmreg.h b/bsps/arm/imx/include/arm/freescale/imx/imx6ul_ccmreg.h
new file mode 100644
index 0000000000..e4b597ba32
--- /dev/null
+++ b/bsps/arm/imx/include/arm/freescale/imx/imx6ul_ccmreg.h
@@ -0,0 +1,152 @@
+ * Copyright (C) 2022 embedded brains GmbH
+ * are met:
+#ifndef IMX6UL_CCMREG_H
+#define IMX6UL_CCMREG_H
+#include <bsp/utility.h>
+typedef struct {
+	uint32_t ccr;
+	uint32_t ccdr;
+	uint32_t csr;
+	uint32_t ccsr;
+	uint32_t cacrr;
+	uint32_t cbcdr;
+	uint32_t cbcmr;
+	uint32_t cscmr1;
+	uint32_t cscmr2;
+	uint32_t cscdr1;
+	uint32_t cs1cdr;
+	uint32_t cs2cdr;
+	uint32_t cdcdr;
+	uint32_t chsccdr;
+	uint32_t cscdr2;
+	uint32_t cscdr3;
+	uint32_t reserved_40[2];
+	uint32_t cdhipr;
+	uint32_t reserved_4c[2];
+	uint32_t clpcr;
+	uint32_t cisr;
+	uint32_t cimr;
+	uint32_t ccosr;
+	uint32_t cgpr;
+	uint32_t ccgr0;
+	uint32_t ccgr1;
+	uint32_t ccgr2;
+	uint32_t ccgr3;
+	uint32_t ccgr4;
+	uint32_t ccgr5;
+	uint32_t ccgr6;
+	uint32_t reserved_84[1];
+	uint32_t cmeor;
+} imx6ul_ccm;
+typedef struct {
+	uint32_t pll_arm;
+	uint32_t pll_arm_set;
+	uint32_t pll_arm_clr;
+	uint32_t pll_arm_tog;
+	uint32_t pll_usb1;
+	uint32_t pll_usb1_set;
+	uint32_t pll_usb1_clr;
+	uint32_t pll_usb1_tog;
+	uint32_t pll_usb2;
+	uint32_t pll_usb2_set;
+	uint32_t pll_usb2_clr;
+	uint32_t pll_usb2_tog;
+	uint32_t pll_sys;
+	uint32_t pll_sys_set;
+	uint32_t pll_sys_clr;
+	uint32_t pll_sys_tog;
+	uint32_t pll_sys_ss;
+	uint32_t reserved_44[3];
+	uint32_t pll_sys_num;
+	uint32_t reserved_54[3];
+	uint32_t pll_sys_denom;
+	uint32_t reserved_64[3];
+	uint32_t pll_audio;
+	uint32_t pll_audio_set;
+	uint32_t pll_audio_clr;
+	uint32_t pll_audio_tog;
+	uint32_t pll_audio_num;
+	uint32_t reserved_84[3];
+	uint32_t pll_audio_denom;
+	uint32_t reserved_94[3];
+	uint32_t pll_video;
+	uint32_t pll_video_set;
+	uint32_t pll_video_clr;
+	uint32_t pll_video_tog;
+	uint32_t pll_video_num;
+	uint32_t reserved_b4[3];
+	uint32_t pll_video_denom;
+	uint32_t reserved_c4[7];
+	uint32_t pll_enet;
+#define IMX6UL_CCM_ANALOG_PLL_ENET_LOCK BSP_BIT32(31)
+#define IMX6UL_CCM_ANALOG_PLL_ENET_ENET_25M_REF_EN BSP_BIT32(21)
+#define IMX6UL_CCM_ANALOG_PLL_ENET_ENET2_125M_EN BSP_BIT32(20)
+#define IMX6UL_CCM_ANALOG_PLL_ENET_ENABLE_125M BSP_BIT32(19)
+#define IMX6UL_CCM_ANALOG_PLL_ENET_PFD_OFFSET_EN BSP_BIT32(18)
+#define IMX6UL_CCM_ANALOG_PLL_ENET_BYPASS BSP_BIT32(16)
+#define IMX6UL_CCM_ANALOG_PLL_ENET_BYPASS_CLK_SRC(val) BSP_FLD32(val, 14, 15)
+#define IMX6UL_CCM_ANALOG_PLL_ENET_BYPASS_CLK_SRC_GET(val) BSP_FLD32GET(val, 14, 15)
+#define IMX6UL_CCM_ANALOG_PLL_ENET_BYPASS_CLK_SRC_SET(val) BSP_FLD32SET(val, 14, 15)
+#define IMX6UL_CCM_ANALOG_PLL_ENET_ENET1_125M_EN BSP_BIT32(13)
+#define IMX6UL_CCM_ANALOG_PLL_ENET_POWERDOWN BSP_BIT32(12)
+#define IMX6UL_CCM_ANALOG_PLL_ENET_ENET1_DIV_SELECT(val) BSP_FLD32(val, 3, 2)
+#define IMX6UL_CCM_ANALOG_PLL_ENET_ENET1_DIV_SELECT_GET(val) BSP_FLD32GET(val, 3, 2)
+#define IMX6UL_CCM_ANALOG_PLL_ENET_ENET1_DIV_SELECT_SET(val) BSP_FLD32SET(val, 3, 2)
+#define IMX6UL_CCM_ANALOG_PLL_ENET_ENET0_DIV_SELECT(val) BSP_FLD32(val, 0, 1)
+#define IMX6UL_CCM_ANALOG_PLL_ENET_ENET0_DIV_SELECT_GET(val) BSP_FLD32GET(val, 0, 1)
+#define IMX6UL_CCM_ANALOG_PLL_ENET_ENET0_DIV_SELECT_SET(val) BSP_FLD32SET(val, 0, 1)
+	uint32_t pll_enet_set;
+	uint32_t pll_enet_clr;
+	uint32_t pll_enet_tog;
+	uint32_t pfd_480;
+	uint32_t pfd_480_set;
+	uint32_t pfd_480_clr;
+	uint32_t pfd_480_tog;
+	uint32_t pfd_528;
+	uint32_t pfd_528_set;
+	uint32_t pfd_528_clr;
+	uint32_t pfd_528_tog;
+	uint32_t reserved_110[16];
+	uint32_t misc0;
+	uint32_t misc0_set;
+	uint32_t misc0_clr;
+	uint32_t misc0_tog;
+	uint32_t misc1;
+	uint32_t misc1_set;
+	uint32_t misc1_clr;
+	uint32_t misc1_tog;
+	uint32_t misc2;
+	uint32_t misc2_set;
+	uint32_t misc2_clr;
+	uint32_t misc2_tog;
+} imx6ul_ccm_analog;
+#endif /* IMX6UL_CCMREG_H */
diff --git a/bsps/arm/imx/start/bspstart.c b/bsps/arm/imx/start/bspstart.c
index 04d48d1558..552935ee69 100644
--- a/bsps/arm/imx/start/bspstart.c
+++ b/bsps/arm/imx/start/bspstart.c
@@ -14,6 +14,7 @@
 #include <bsp/linker-symbols.h>
 #include <dev/clock/arm-generic-timer.h>
 #include <libcpu/arm-cp15.h>
+#include <arm/freescale/imx/imx6ul_ccmreg.h>
 #include <libfdt.h>
@@ -161,6 +162,24 @@ static void imx_find_gic(const void *fdt)
 #endif
+static void imx_ccm_enable_eth2_clk(void)
+  const void *fdt = bsp_fdt_get();
+  if (imx_is_imx6(fdt)) {
+    int node;
+    volatile imx6ul_ccm_analog *ccm_analog = NULL;
+    node = fdt_node_offset_by_compatible(fdt, -1, "fsl,imx6ul-anatop");
+    if (node >= 0) {
+        ccm_analog = imx_get_reg_of_node(fdt, node);
+    if (ccm_analog != NULL) {
+        ccm_analog->pll_enet_set = IMX6UL_CCM_ANALOG_PLL_ENET_ENET2_125M_EN;
 void bsp_start(void)
   imx_find_gic(bsp_fdt_get());
@@ -169,4 +188,5 @@ void bsp_start(void)
     bsp_section_nocacheheap_begin,
     (uintptr_t) bsp_section_nocacheheap_size
+  imx_ccm_enable_eth2_clk();
diff --git a/spec/build/bsps/arm/imx/bspimx.yml b/spec/build/bsps/arm/imx/bspimx.yml
index 24e56a499f..6ff2093f7e 100644
--- a/spec/build/bsps/arm/imx/bspimx.yml
+++ b/spec/build/bsps/arm/imx/bspimx.yml
@@ -23,6 +23,7 @@ install:
   - bsps/arm/imx/include/arm/freescale/imx/imx_srcreg.h
   - bsps/arm/imx/include/arm/freescale/imx/imx_uartreg.h
   - bsps/arm/imx/include/arm/freescale/imx/imx_wdogreg.h
+  - bsps/arm/imx/include/arm/freescale/imx/imx6ul_ccmreg.h
   - bsps/arm/include/arm/freescale/imx/imx_iomuxreg.h
   - bsps/arm/include/arm/freescale/imx/imx_iomuxvar.h
 - destination: ${BSP_INCLUDEDIR}/bsp
2.35.3
