[PATCH rtems v2] bsps/imx: Enable clock of ETH2
Chris Johns
chrisj at rtems.org
Wed Jun 8 00:49:14 UTC 2022
Does the BSP doco in the User Manual need updating to mention the clock setting
and the required FDT?
This code fails silently and so documentation is fine or I think the user should
be alerted some other way.
Otherwise OK to push :)
Thanks
On 7/6/2022 11:05 pm, Christian Mauderer wrote:
> .../include/arm/freescale/imx/imx6ul_ccmreg.h | 152 ++++++++++++++++++
> bsps/arm/imx/start/bspstart.c | 20 +++
> spec/build/bsps/arm/imx/bspimx.yml | 1 +
> 3 files changed, 173 insertions(+)
> create mode 100644 bsps/arm/imx/include/arm/freescale/imx/imx6ul_ccmreg.h
> diff --git a/bsps/arm/imx/include/arm/freescale/imx/imx6ul_ccmreg.h b/bsps/arm/imx/include/arm/freescale/imx/imx6ul_ccmreg.h
> new file mode 100644
> index 0000000000..e4b597ba32
> --- /dev/null
> +++ b/bsps/arm/imx/include/arm/freescale/imx/imx6ul_ccmreg.h
> @@ -0,0 +1,152 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * Copyright (C) 2022 embedded brains GmbH
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + * notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + * notice, this list of conditions and the following disclaimer in the
> + * documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifndef IMX6UL_CCMREG_H
> +#define IMX6UL_CCMREG_H
> +#include <bsp/utility.h>
> +typedef struct {
> + uint32_t ccr;
> + uint32_t ccdr;
> + uint32_t csr;
> + uint32_t ccsr;
> + uint32_t cacrr;
> + uint32_t cbcdr;
> + uint32_t cbcmr;
> + uint32_t cscmr1;
> + uint32_t cscmr2;
> + uint32_t cscdr1;
> + uint32_t cs1cdr;
> + uint32_t cs2cdr;
> + uint32_t cdcdr;
> + uint32_t chsccdr;
> + uint32_t cscdr2;
> + uint32_t cscdr3;
> + uint32_t reserved_40[2];
> + uint32_t cdhipr;
> + uint32_t reserved_4c[2];
> + uint32_t clpcr;
> + uint32_t cisr;
> + uint32_t cimr;
> + uint32_t ccosr;
> + uint32_t cgpr;
> + uint32_t ccgr0;
> + uint32_t ccgr1;
> + uint32_t ccgr2;
> + uint32_t ccgr3;
> + uint32_t ccgr4;
> + uint32_t ccgr5;
> + uint32_t ccgr6;
> + uint32_t reserved_84[1];
> + uint32_t cmeor;
> +} imx6ul_ccm;
> +typedef struct {
> + uint32_t pll_arm;
> + uint32_t pll_arm_set;
> + uint32_t pll_arm_clr;
> + uint32_t pll_arm_tog;
> + uint32_t pll_usb1;
> + uint32_t pll_usb1_set;
> + uint32_t pll_usb1_clr;
> + uint32_t pll_usb1_tog;
> + uint32_t pll_usb2;
> + uint32_t pll_usb2_set;
> + uint32_t pll_usb2_clr;
> + uint32_t pll_usb2_tog;
> + uint32_t pll_sys;
> + uint32_t pll_sys_set;
> + uint32_t pll_sys_clr;
> + uint32_t pll_sys_tog;
> + uint32_t pll_sys_ss;
> + uint32_t reserved_44[3];
> + uint32_t pll_sys_num;
> + uint32_t reserved_54[3];
> + uint32_t pll_sys_denom;
> + uint32_t reserved_64[3];
> + uint32_t pll_audio;
> + uint32_t pll_audio_set;
> + uint32_t pll_audio_clr;
> + uint32_t pll_audio_tog;
> + uint32_t pll_audio_num;
> + uint32_t reserved_84[3];
> + uint32_t pll_audio_denom;
> + uint32_t reserved_94[3];
> + uint32_t pll_video;
> + uint32_t pll_video_set;
> + uint32_t pll_video_clr;
> + uint32_t pll_video_tog;
> + uint32_t pll_video_num;
> + uint32_t reserved_b4[3];
> + uint32_t pll_video_denom;
> + uint32_t reserved_c4[7];
> + uint32_t pll_enet;
> +#define IMX6UL_CCM_ANALOG_PLL_ENET_LOCK BSP_BIT32(31)
> +#define IMX6UL_CCM_ANALOG_PLL_ENET_ENET_25M_REF_EN BSP_BIT32(21)
> +#define IMX6UL_CCM_ANALOG_PLL_ENET_ENET2_125M_EN BSP_BIT32(20)
> +#define IMX6UL_CCM_ANALOG_PLL_ENET_ENABLE_125M BSP_BIT32(19)
> +#define IMX6UL_CCM_ANALOG_PLL_ENET_PFD_OFFSET_EN BSP_BIT32(18)
> +#define IMX6UL_CCM_ANALOG_PLL_ENET_BYPASS BSP_BIT32(16)
> +#define IMX6UL_CCM_ANALOG_PLL_ENET_BYPASS_CLK_SRC(val) BSP_FLD32(val, 14, 15)
> +#define IMX6UL_CCM_ANALOG_PLL_ENET_BYPASS_CLK_SRC_GET(val) BSP_FLD32GET(val, 14, 15)
> +#define IMX6UL_CCM_ANALOG_PLL_ENET_BYPASS_CLK_SRC_SET(val) BSP_FLD32SET(val, 14, 15)
> +#define IMX6UL_CCM_ANALOG_PLL_ENET_ENET1_125M_EN BSP_BIT32(13)
> +#define IMX6UL_CCM_ANALOG_PLL_ENET_POWERDOWN BSP_BIT32(12)
> +#define IMX6UL_CCM_ANALOG_PLL_ENET_ENET1_DIV_SELECT(val) BSP_FLD32(val, 3, 2)
> +#define IMX6UL_CCM_ANALOG_PLL_ENET_ENET1_DIV_SELECT_GET(val) BSP_FLD32GET(val, 3, 2)
> +#define IMX6UL_CCM_ANALOG_PLL_ENET_ENET1_DIV_SELECT_SET(val) BSP_FLD32SET(val, 3, 2)
> +#define IMX6UL_CCM_ANALOG_PLL_ENET_ENET0_DIV_SELECT(val) BSP_FLD32(val, 0, 1)
> +#define IMX6UL_CCM_ANALOG_PLL_ENET_ENET0_DIV_SELECT_GET(val) BSP_FLD32GET(val, 0, 1)
> +#define IMX6UL_CCM_ANALOG_PLL_ENET_ENET0_DIV_SELECT_SET(val) BSP_FLD32SET(val, 0, 1)
> + uint32_t pll_enet_set;
> + uint32_t pll_enet_clr;
> + uint32_t pll_enet_tog;
> + uint32_t pfd_480;
> + uint32_t pfd_480_set;
> + uint32_t pfd_480_clr;
> + uint32_t pfd_480_tog;
> + uint32_t pfd_528;
> + uint32_t pfd_528_set;
> + uint32_t pfd_528_clr;
> + uint32_t pfd_528_tog;
> + uint32_t reserved_110[16];
> + uint32_t misc0;
> + uint32_t misc0_set;
> + uint32_t misc0_clr;
> + uint32_t misc0_tog;
> + uint32_t misc1;
> + uint32_t misc1_set;
> + uint32_t misc1_clr;
> + uint32_t misc1_tog;
> + uint32_t misc2;
> + uint32_t misc2_set;
> + uint32_t misc2_clr;
> + uint32_t misc2_tog;
> +} imx6ul_ccm_analog;
> +#endif /* IMX6UL_CCMREG_H */
> diff --git a/bsps/arm/imx/start/bspstart.c b/bsps/arm/imx/start/bspstart.c
> index 04d48d1558..552935ee69 100644
> --- a/bsps/arm/imx/start/bspstart.c
> +++ b/bsps/arm/imx/start/bspstart.c
> @@ -14,6 +14,7 @@
> #include <bsp/linker-symbols.h>
> #include <dev/clock/arm-generic-timer.h>
> #include <libcpu/arm-cp15.h>
> +#include <arm/freescale/imx/imx6ul_ccmreg.h>
> #include <libfdt.h>
> @@ -161,6 +162,24 @@ static void imx_find_gic(const void *fdt)
> #endif
> +static void imx_ccm_enable_eth2_clk(void)
> + const void *fdt = bsp_fdt_get();
> + if (imx_is_imx6(fdt)) {
> + int node;
> + volatile imx6ul_ccm_analog *ccm_analog = NULL;
> + node = fdt_node_offset_by_compatible(fdt, -1, "fsl,imx6ul-anatop");
> + if (node >= 0) {
> + ccm_analog = imx_get_reg_of_node(fdt, node);
> + if (ccm_analog != NULL) {
> + ccm_analog->pll_enet_set = IMX6UL_CCM_ANALOG_PLL_ENET_ENET2_125M_EN;
> void bsp_start(void)
> imx_find_gic(bsp_fdt_get());
> @@ -169,4 +188,5 @@ void bsp_start(void)
> bsp_section_nocacheheap_begin,
> (uintptr_t) bsp_section_nocacheheap_size
> + imx_ccm_enable_eth2_clk();
> diff --git a/spec/build/bsps/arm/imx/bspimx.yml b/spec/build/bsps/arm/imx/bspimx.yml
> index 24e56a499f..6ff2093f7e 100644
> --- a/spec/build/bsps/arm/imx/bspimx.yml
> +++ b/spec/build/bsps/arm/imx/bspimx.yml
> @@ -23,6 +23,7 @@ install:
> - bsps/arm/imx/include/arm/freescale/imx/imx_srcreg.h
> - bsps/arm/imx/include/arm/freescale/imx/imx_uartreg.h
> - bsps/arm/imx/include/arm/freescale/imx/imx_wdogreg.h
> + - bsps/arm/imx/include/arm/freescale/imx/imx6ul_ccmreg.h
> - bsps/arm/include/arm/freescale/imx/imx_iomuxreg.h
> - bsps/arm/include/arm/freescale/imx/imx_iomuxvar.h
> - destination: ${BSP_INCLUDEDIR}/bsp
