[PATCH] testsuite/libtests: Add exit03 to test exit() with C++
chrisj at rtems.org
chrisj at rtems.org
Wed Jun 8 04:49:37 UTC 2022
Updates #4661
spec/build/testsuites/libtests/exit03.yml | 20 ++++
spec/build/testsuites/libtests/grp.yml | 2 +
testsuites/libtests/exit03/exit03.doc | 11 ++
testsuites/libtests/exit03/exit03.scn | 5 +
testsuites/libtests/exit03/init.c | 122 ++++++++++++++++++++++
testsuites/libtests/exit03/stdio.cc | 61 +++++++++++
6 files changed, 221 insertions(+)
create mode 100644 spec/build/testsuites/libtests/exit03.yml
create mode 100644 testsuites/libtests/exit03/exit03.doc
create mode 100644 testsuites/libtests/exit03/exit03.scn
create mode 100644 testsuites/libtests/exit03/init.c
create mode 100644 testsuites/libtests/exit03/stdio.cc
diff --git a/spec/build/testsuites/libtests/exit03.yml b/spec/build/testsuites/libtests/exit03.yml
new file mode 100644
index 0000000000..d9bd123de0
--- /dev/null
+++ b/spec/build/testsuites/libtests/exit03.yml
@@ -0,0 +1,20 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags: []
+copyrights:
+- Copyright (C) 2022 Chris Johns (Contemporary Software)
+cppflags: []
+cxxflags: []
+enabled-by: true
+features: c cxx cxxprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/libtests/exit03/init.c
+- testsuites/libtests/exit03/stdio.cc
+stlib: []
+target: testsuites/libtests/exit03.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/libtests/grp.yml b/spec/build/testsuites/libtests/grp.yml
index d352c8221c..793e1f3fef 100644
--- a/spec/build/testsuites/libtests/grp.yml
+++ b/spec/build/testsuites/libtests/grp.yml
@@ -113,6 +113,8 @@ links:
uid: exit01
- role: build-dependency
uid: exit02
+- role: build-dependency
+ uid: exit03
uid: fcntl
diff --git a/testsuites/libtests/exit03/exit03.doc b/testsuites/libtests/exit03/exit03.doc
index 0000000000..c575ef40fb
--- /dev/null
+++ b/testsuites/libtests/exit03/exit03.doc
@@ -0,0 +1,11 @@
+This file describes the directives and concepts tested by this test set.
+test set name: exit03
+directives:
+ exit()
+concepts:
+ Ensure exit() in a C++ application works.
diff --git a/testsuites/libtests/exit03/exit03.scn b/testsuites/libtests/exit03/exit03.scn
index 0000000000..03d45a0c1f
--- /dev/null
+++ b/testsuites/libtests/exit03/exit03.scn
@@ -0,0 +1,5 @@
+caught exception
+IO on std::cout
+IO on std::cerr
+*** END OF TEST EXIT 3 ***
diff --git a/testsuites/libtests/exit03/init.c b/testsuites/libtests/exit03/init.c
index 0000000000..b761c0af4a
--- /dev/null
+++ b/testsuites/libtests/exit03/init.c
@@ -0,0 +1,122 @@
+ * Copyright (c) 2022 Chris Johns (Contemporary Software). All rights reserved.
+ * Copyright (c) 2013 embedded brains GmbH. All rights reserved.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include "tmacros.h"
+#include <stdlib.h>
+/* Use assert() not rtems_test_assert() since it uses exit() */
+#include <assert.h>
+#include <rtems.h>
+void cplusplus_stdio(void);
+const char rtems_test_name[] = "EXIT 3";
+#define EXIT_STATUS 123
+static int counter;
+static void atexit_0(void)
+ assert(counter == 0);
+ ++counter;
+static void fatal_extension(
+ rtems_fatal_source source,
+ bool always_set_to_false,
+ rtems_fatal_code error
+ if (
+ source == RTEMS_FATAL_SOURCE_EXIT
+ && !always_set_to_false
+ && error == EXIT_STATUS
+ && counter == 1
+ TEST_END();
+static void exit_task(rtems_task_argument arg)
+ int rv;
+ rv = atexit(atexit_0);
+ assert(rv == 0);
+ cplusplus_stdio();
+ exit(EXIT_STATUS);
+static void Init(rtems_task_argument arg)
+ rtems_status_code sc;
+ rtems_id id;
+ TEST_BEGIN();
+ sc = rtems_task_create(
+ rtems_build_name('E', 'X', 'I', 'T'),
+ RTEMS_MINIMUM_PRIORITY,
+ RTEMS_MINIMUM_STACK_SIZE,
+ RTEMS_DEFAULT_MODES,
+ RTEMS_DEFAULT_ATTRIBUTES,
+ &id
+ assert(sc == RTEMS_SUCCESSFUL);
+ sc = rtems_task_start(id, exit_task, 0);
+ rtems_task_exit();
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_INITIAL_EXTENSIONS \
+ { .fatal = fatal_extension }, \
+ RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_MAXIMUM_TASKS 2
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_MAXIMUM_POSIX_KEYS 2
+#include <rtems/confdefs.h>
diff --git a/testsuites/libtests/exit03/stdio.cc b/testsuites/libtests/exit03/stdio.cc
index 0000000000..2a14089d01
--- /dev/null
+++ b/testsuites/libtests/exit03/stdio.cc
@@ -0,0 +1,61 @@
+ * are met:
+#endif
+#include <exception>
+#include <iostream>
+extern "C" {
+static void throw_something() {
+ throw std::runtime_error("something");
+static void throw_and_catch() {
+ try {
+ throw_something();
+ std::cout << "nothing caught exception" << std::endl;
+ } catch (std::runtime_error& e) {
+ std::cout << "caught exception" << std::endl;
+void cplusplus_stdio(void) {
+ std::set_terminate([](){
+ std::cout << "FATAL: terminate called" << std::endl;
+ std::abort();
+ throw_and_catch();
+ std::cout << "IO on std::cout" << std::endl;
+ std::cerr << "IO on std::cerr" << std::endl;
2.19.1
