ok
On Tue, Jun 7, 2022 at 10:49 PM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
> Updates #4661
> spec/build/testsuites/libtests/exit03.yml | 20 ++++
> spec/build/testsuites/libtests/grp.yml | 2 +
> testsuites/libtests/exit03/exit03.doc | 11 ++
> testsuites/libtests/exit03/exit03.scn | 5 +
> testsuites/libtests/exit03/init.c | 122 ++++++++++++++++++++++
> testsuites/libtests/exit03/stdio.cc | 61 +++++++++++
> 6 files changed, 221 insertions(+)
> create mode 100644 spec/build/testsuites/libtests/exit03.yml
> create mode 100644 testsuites/libtests/exit03/exit03.doc
> create mode 100644 testsuites/libtests/exit03/exit03.scn
> create mode 100644 testsuites/libtests/exit03/init.c
> create mode 100644 testsuites/libtests/exit03/stdio.cc
> diff --git a/spec/build/testsuites/libtests/exit03.yml b/spec/build/testsuites/libtests/exit03.yml
> new file mode 100644
> index 0000000000..d9bd123de0
> --- /dev/null
> +++ b/spec/build/testsuites/libtests/exit03.yml
> @@ -0,0 +1,20 @@
> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> +build-type: test-program
> +cflags: []
> +copyrights:
> +- Copyright (C) 2022 Chris Johns (Contemporary Software)
> +cppflags: []
> +cxxflags: []
> +enabled-by: true
> +features: c cxx cxxprogram
> +includes: []
> +ldflags: []
> +links: []
> +source:
> +- testsuites/libtests/exit03/init.c
> +- testsuites/libtests/exit03/stdio.cc
> +stlib: []
> +target: testsuites/libtests/exit03.exe
> +type: build
> +use-after: []
> +use-before: []
> diff --git a/spec/build/testsuites/libtests/grp.yml b/spec/build/testsuites/libtests/grp.yml
> index d352c8221c..793e1f3fef 100644
> --- a/spec/build/testsuites/libtests/grp.yml
> +++ b/spec/build/testsuites/libtests/grp.yml
> @@ -113,6 +113,8 @@ links:
> uid: exit01
> - role: build-dependency
> uid: exit02
> +- role: build-dependency
> + uid: exit03
> uid: fcntl
> diff --git a/testsuites/libtests/exit03/exit03.doc b/testsuites/libtests/exit03/exit03.doc
> index 0000000000..c575ef40fb
> --- /dev/null
> +++ b/testsuites/libtests/exit03/exit03.doc
> @@ -0,0 +1,11 @@
> +This file describes the directives and concepts tested by this test set.
> +test set name: exit03
> +directives:
> + exit()
> +concepts:
> + Ensure exit() in a C++ application works.
> diff --git a/testsuites/libtests/exit03/exit03.scn b/testsuites/libtests/exit03/exit03.scn
> index 0000000000..03d45a0c1f
> --- /dev/null
> +++ b/testsuites/libtests/exit03/exit03.scn
> @@ -0,0 +1,5 @@
> +caught exception
> +IO on std::cout
> +IO on std::cerr
> +*** END OF TEST EXIT 3 ***
> diff --git a/testsuites/libtests/exit03/init.c b/testsuites/libtests/exit03/init.c
> index 0000000000..b761c0af4a
> --- /dev/null
> +++ b/testsuites/libtests/exit03/init.c
> @@ -0,0 +1,122 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * Copyright (c) 2022 Chris Johns (Contemporary Software). All rights reserved.
> + * Copyright (c) 2013 embedded brains GmbH. All rights reserved.
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + * notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + * notice, this list of conditions and the following disclaimer in the
> + * documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include "tmacros.h"
> +#include <stdlib.h>
> +/* Use assert() not rtems_test_assert() since it uses exit() */
> +#include <assert.h>
> +#include <rtems.h>
> +void cplusplus_stdio(void);
> +const char rtems_test_name[] = "EXIT 3";
> +#define EXIT_STATUS 123
> +static int counter;
> +static void atexit_0(void)
> + assert(counter == 0);
> + ++counter;
> +static void fatal_extension(
> + rtems_fatal_source source,
> + bool always_set_to_false,
> + rtems_fatal_code error
> + if (
> + source == RTEMS_FATAL_SOURCE_EXIT
> + && !always_set_to_false
> + && error == EXIT_STATUS
> + && counter == 1
> + TEST_END();
> +static void exit_task(rtems_task_argument arg)
> + int rv;
> + rv = atexit(atexit_0);
> + assert(rv == 0);
> + cplusplus_stdio();
> + exit(EXIT_STATUS);
> +static void Init(rtems_task_argument arg)
> + rtems_status_code sc;
> + rtems_id id;
> + TEST_BEGIN();
> + sc = rtems_task_create(
> + rtems_build_name('E', 'X', 'I', 'T'),
> + RTEMS_MINIMUM_PRIORITY,
> + RTEMS_MINIMUM_STACK_SIZE,
> + RTEMS_DEFAULT_MODES,
> + RTEMS_DEFAULT_ATTRIBUTES,
> + &id
> + assert(sc == RTEMS_SUCCESSFUL);
> + sc = rtems_task_start(id, exit_task, 0);
> + rtems_task_exit();
> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> +#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
> +#define CONFIGURE_INITIAL_EXTENSIONS \
> + { .fatal = fatal_extension }, \
> + RTEMS_TEST_INITIAL_EXTENSION
> +#define CONFIGURE_MAXIMUM_TASKS 2
> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> +#define CONFIGURE_MAXIMUM_POSIX_KEYS 2
> +#include <rtems/confdefs.h>
> diff --git a/testsuites/libtests/exit03/stdio.cc b/testsuites/libtests/exit03/stdio.cc
> index 0000000000..2a14089d01
> --- /dev/null
> +++ b/testsuites/libtests/exit03/stdio.cc
> @@ -0,0 +1,61 @@
> + * are met:
> +#endif
> +#include <exception>
> +#include <iostream>
> +extern "C" {
> +static void throw_something() {
> + throw std::runtime_error("something");
> +static void throw_and_catch() {
> + try {
> + throw_something();
> + std::cout << "nothing caught exception" << std::endl;
> + } catch (std::runtime_error& e) {
> + std::cout << "caught exception" << std::endl;
> +void cplusplus_stdio(void) {
> + std::set_terminate([](){
> + std::cout << "FATAL: terminate called" << std::endl;
> + std::abort();
> + throw_and_catch();
> + std::cout << "IO on std::cout" << std::endl;
> + std::cerr << "IO on std::cerr" << std::endl;
> 2.19.1
> devel mailing list
> devel at rtems.org
