[gcc] Enable TLS support for RTEMS in libstdc++
Wed Jun 8 14:11:27 UTC 2022
On Wed, Jun 8, 2022 at 8:47 AM Sebastian Huber <
> On 08/06/2022 15:39, Joel Sherrill wrote:
> > Is TLS actually supported on all targets except MIPS?
> I only added MIPS since this target has a fundamental issue with the TLS
> support.
> Which target would you also exclude?
About half of them.
arch64 - Yes
arm - Yes
bfin - ?
i386 - Yes
lm32 - ?
m68k - Yes
microblaze - Yes
mips - No
moxie - ?
nios2 -?
or1k - ?
powerpc - Yes
riscv - Probably
sh - ?
sparc - Yes
sparc64 - ?
v850 - ?
x86_64 - Likely
I'm not even sure there is a definition of how TLS is implemented
on some of these architectures. Maybe GCC has a generic way of
handling TLS that a port could fall back on, but I am unaware of it.
If we are to maintain a thread safe C Library, then we have to be
sure TLS is always supported or we have to have a fallback
method.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220608/6fcc2845/attachment.htm>
