[gcc] Enable TLS support for RTEMS in libstdc++
Wed Jun 8 14:18:50 UTC 2022
On 08/06/2022 16:11, Joel Sherrill wrote:
> On Wed, Jun 8, 2022 at 8:47 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     On 08/06/2022 15:39, Joel Sherrill wrote:
>      > Is TLS actually supported on all targets except MIPS?
>     I only added MIPS since this target has a fundamental issue with the
>     TLS
>     support.
>     Which target would you also exclude?
> About half of them.
It seems to be only bfin, lm32, moxie, or1k, and v850. Are these targets
still in use? Do we have a maintainer for these targets?
> arch64 - Yes
> arm - Yes
> bfin - ?
> i386 - Yes
> lm32 - ?
> m68k - Yes
> microblaze - Yes
> mips - No
> moxie - ?
> nios2 -?
nios2 - Yes
> or1k - ?
> powerpc - Yes
> riscv - Probably
riscv - Yes
> sh - ?
> sparc - Yes
> sparc64 - ?
> v850 - ?
> x86_64 - Likely
> I'm not even sure there is a definition of how TLS is implemented
> on some of these architectures. Maybe GCC has a generic way of
> handling TLS that a port could fall back on, but I am unaware of it.
> If we are to maintain a thread safe C Library, then we have to be
> sure TLS is always supported or we have to have a fallback
> method.
The fallback method for C++ is only thread safe if you have enough POSIX
keys configured.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
