[PATCH rtems-docs v2] TFTPFS: New documentation
Frank Kuehndel frank.kuehndel at embedded-brains.de
Thu Jun 9 13:21:05 UTC 2022
From: Frank Kühndel <frank.kuehndel at embedded-brains.de>
 filesystem/index.rst       |   1 +
 filesystem/trivial_ftp.rst | 564 ++++++++++++++++++++++++++++++++++++-
 2 files changed, 562 insertions(+), 3 deletions(-)
diff --git a/filesystem/index.rst b/filesystem/index.rst
index f4e2ed6..64a2f1d 100644
--- a/filesystem/index.rst
+++ b/filesystem/index.rst
@@ -9,6 +9,7 @@ RTEMS Filesystem Design Guide (|version|).
 .. topic:: Copyrights and License
     | |copy| 1988, 2015 On-Line Applications Research Corporation (OAR)
+    | |copy| 2022 embedded brains GmbH (http://www.embedded-brains.de)
     .. include:: ../common/license.rst
diff --git a/filesystem/trivial_ftp.rst b/filesystem/trivial_ftp.rst
index e43c036..3ef8bba 100644
--- a/filesystem/trivial_ftp.rst
+++ b/filesystem/trivial_ftp.rst
@@ -3,7 +3,565 @@
 Trivial FTP Client Filesystem
-This chapter describes the Trivial FTP (TFTP) Client Filesystem.
+This chapter describes the Trivial File Transfer Protocol (TFTP) Client
+Filesystem.  TFTP is designed to be an especially simple protocol which
+uses the User Datagram Protocol (UDP) for data transfer over the Internet.
+Its purpose is to send a single file between to network nodes (client and
+server).  A file can be sent in both directions, i.e. a client can either
+read a file from a server or write a file to the server.
-This chapter should be written after the IMFS chapter is completed and describe
-the implementation of the TFTP.
+Besides reading or writing a file no other operations are supported.  That
+is, one cannot seek the file, not append to the end of a file, not open
+the file for reading and writing at the same time, not list directories,
+not move files and so on.
+TFTP is inherent insecure as it does not provide any means for
+authentication or encryption.  Therefore, it is highly recommended not
+to employ it on public networks.  Nevertheless, it is still widely used
+to load software and configuration data during early boot stages over
+a Local Area Network (LAN).
+RTEMS TFTP Filesystem Implementation
+The RTEMS TFTP filesystem implements a TFTP client which can be used
+through the file system.  With other words, one needs to mount the
+TFTP filesystem and can afterwards open a file for reading or writing
+below that mount point.  The content of that file is then effectively
+read from or written to the remote server.  The RTEMS implementation
+implements the following features:
+* `RFC 1350 <https://www.rfc-editor.org/rfc/rfc1350.html>`_
+  *The TFTP Protocol (Revision 2)*
+* `RFC 2347 <https://www.rfc-editor.org/rfc/rfc2347.html>`_
+  *TFTP Option Extension*
+* `RFC 2348 <https://www.rfc-editor.org/rfc/rfc2348.html>`_
+  *TFTP Blocksize Option*
+* `RFC 7440 <https://www.rfc-editor.org/rfc/rfc7440.html>`_
+  *TFTP Windowsize Option*
+Many simple TFTP server do not support options (RFC 2347). Therefore, in
+case the server rejects the first request with options, the RTEMS client
+makes automatically a second attempt using only the "classical" RFC 1350.
+The implementation has the following shortcomings:
+* IPv6 is not supported (yet).
+* No congestion control is implemented.
+  (Congestion is simply expressed a network traffic jam which involves
+  package loss.)  This implementation would worsen a congestion situation
+  and squeeze out TCP connections.  If that is a concern in your setup,
+  it can be prevented by using value `1` as `windowsize` when mounting
+  the TFTP file system.
+* One must call ``open()``, ``read()``, ``write()`` and ``close()``
+  at a good pace.
+  TFTP is designed to read or write a whole already existing file in
+  one sweep.  It uses timeouts (of unspecified length) and it does not
+  know keep-alive messages.  If the client does not respond to the
+  server in due time, the server sets the connection faulty and drops it.
+  To avoid this, the user must read or write enough data fast enough.
+  The point here is, one cannot pause the reading or writing for longer
+  periods of time.  TFTP cannot be used for example to write log files
+  where all few seconds a line is written.  Also opening the
+  file at the beginning of an application and closing it that the end
+  will certainly lead to a timeout.  As another example, one cannot
+  read a file by reading one byte per second, this will trigger a
+  timeout and the server closes the connection.  The opening, reading
+  or writing and closing must happen in swift consecutive steps.
+* The transfer mode is always ``octet``.  The only alternative
+  ``netascii`` cannot be selected.
+* Block number roll-over is currently not supported.  Therefore,
+  the maximum file size is limited to max-block-number times blocksize.
+  For RFC 1350 blocksize is would be 65535 * 512 = 32 MB.  For the
+  default blocksize is would be 65535 * 1456 = 90 MB.
+* The inherent insecurity of the protocol has already be mentioned but
+  it is worth repeating.
+Prerequisites
+To use the RTEMS TFTP filesystem one needs:
+* The RTEMS tools (cross-compiler, linker, debugger etc.)
+* The RTEMS Board Support Package (BSP)
+* A network stack for RTEMS, for example RTEMS libbsd
+As an example the ARM architecture and a xilinx_zynq_a9 BSP is used below
+together with RTEMS libbsd.  The instructions are tested with RTEMS
+version 6.  It is recommended to actually use ``arm/xilinx_zynq_a9_qemu``
+for the first experiments as other BSPs tend to require different
+configuration values and/or command line options.
+Moreover, it is recommended to first execute any code using QEMU as
+simulator so that no hardware is needed.  Therefore, ``qemu-system-arm``
+must be installed.  In Linux distributions this executable is usually
+available in the repositories as package ``qemu-arm``.
+RTEMS Tools
+Instructions on how to obtain, compile and install the RTEMS tools can
+be found in the *RTEMS User Manual* chapter *2. Quick Start*.  To
+follow the suggested example ``6/rtems-arm`` should be used as
+target architecture argument of the ``../source-builder/sb-set-builder``
+command.
+RTEMS Board Support Package
+Instructions on how to obtain, compile and install a BSP can be found
+in the *RTEMS User Manual* section *Build a Board Support Package (BSP)*.
+The bsp-option should have the following value to match the example BSP:
+.. code-block:: none
+  --rtems-bsps=arm/xilinx_zynq_a9_qemu
+RTEMS libbsd
+Instructions on how to obtain, compile and install RTEMS libbsd can be
+found in the ``README.rst`` of the ``rtems-libbsd`` GIT repository:
+``git://git.rtems.org/rtems-libbsd.git``.
+Make sure to compile and install libbsd for the correct RTEMS version
+(here ``6``).  The default build set (``--buildset=buildset/default.ini``)
+does suffice and as BSP ``--rtems-bsp=arm/xilinx_zynq_a9_qemu`` is
+to be used with the ``waf configure`` command.
+RTEMS Configuration
+To make the TFTP filesystem available to an RTEMS application and have
+it initialized, the macro ``CONFIGURE_FILESYSTEM_TFTPFS`` must be
+defined when configuring RTEMS (typically in the ``init.c`` file):
+.. code-block:: c
+  #define CONFIGURE_FILESYSTEM_TFTPFS
+Moreover, libbsd and RTEMS must be configured appropriately as well.
+For orientation, the code below is from an application using TFTP FS
+(file ``tftp_init.c``).
+.. code-block:: c
+  /* Configure libbsd. */
+  #define RTEMS_BSD_CONFIG_NET_PF_UNIX
+  #define RTEMS_BSD_CONFIG_NET_IF_BRIDGE
+  #define RTEMS_BSD_CONFIG_NET_IF_LAGG
+  #define RTEMS_BSD_CONFIG_NET_IF_VLAN
+  #define RTEMS_BSD_CONFIG_BSP_CONFIG
+  #define RTEMS_BSD_CONFIG_INIT
+  #include <machine/rtems-bsd-config.h>
+  /* RTEMS configuration for libbsd */
+  #define CONFIGURE_MAXIMUM_USER_EXTENSIONS 1
+  #define CONFIGURE_INIT_TASK_STACK_SIZE (32 * 1024)
+  #define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_DEFAULT_MODES
+  #define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
+  #define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
+  /* RTEMS configuration for tftp */
+  #define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 64
+  /* Simple RTEMS configuration */
+  #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+  #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+  #define CONFIGURE_UNLIMITED_OBJECTS
+  #define CONFIGURE_UNIFIED_WORK_AREAS
+  #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+  #include <rtems/confdefs.h>
+Application Linkage
+The TFTP filesystem is compiled and linked into ``libtftpfs``.  After
+installation it should be in a place like:
+  <PREFIX>/arm-rtems6/xilinx_zynq_a9_qemu/lib/libtftpfs.a
+An RTEMS application which wants to use the TFTP filesystem must be linked
+with the libraries ``libtftpfs``, ``libbsd``, and ``libm`` --- in this order.
+An example build target in a ``wscript`` for use with the RTEMS WAF build
+system could be:
+.. code-block:: python
+  def build(ctx):
+      rtems.build(ctx)
+      ctx(features = 'c cprogram',
+          target = 'tftp_app.exe',
+          cflags = '-g -O2',
+          source = ['tftp_app.c', 'tftp_init.c'],
+          lib    = ['tftpfs', 'bsd', 'm'])
+Network Configuration and TFTP Server
+QEMU has a simple build-in TFTP server which can serve files for reading
+only.  By default it is reachable from the application executed by QEMU
+at IP address ``10.0.2.2`` if SLIRP networking is used.  For the
+example ``arm/xilinx_zynq_a9_qemu`` BSP, the QEMU option
+  -nic user,model=cadence_gem,tftp=/tmp
+will cause this TFTP server to deliver files found below directory
+``/tmp``.  Note that SLIRP requires that the application uses DHCP.
+Alternatively, it is of course possible to use other kinds of QEMU
+networking (as for example the TAP virtual Ethernet interface described
+in the above mentioned ``README.rst`` in section *Qemu and Networking*).
+Also an external TFTP server can be used.
+External TFTP Server Example for OpenSUSE
+This example uses ``atftp`` as an external TFTP server to which the RTEMS
+TFTP file system running in an QEMU instance connects to.  ``atftp`` was
+compiled from the sources.  Instructions how to compile and install
+``atftp`` can be found in the ``INSTALL`` file which comes with its sources.
+On an OpenSUSE 15.3 machine, the following commands sets up ``atftp``
+for use with the mentioned TAP interface (these commands must be executed
+as root; ``<APP-USER>`` must be replaced by the name of the "normal"
+user starting the RTEMS application in QEMU later on; for other
+distributions the ``firewall-cmd`` commands must be
+replaced by the equivalent of that distribution):
+.. code-block:: shell
+  # Create and configure TAP interface
+  ip tuntap add qtap mode tap user <APP-USER>
+  ip link set dev qtap up
+  ip addr add 169.254.1.1/16 dev qtap
+  # Open firewalld as non-permanent configuration
+  firewall-cmd --zone=home --add-service=tftp
+  firewall-cmd --zone=home --add-interface=qtap
+  # Start TFTP daemon
+  touch /var/log/atftpd/atftp.log
+  chown tftp.tftp /var/log/atftpd/atftp.log
+  atftpd --user tftp --group tftp --daemon --verbose \
+      --logfile /var/log/atftpd/atftp.log /srv/tftpboot
+The ``atftp`` server will then be reachable from an application executed
+by QEMU at the address of the TAP interface which is in this case
+``169.254.1.1``.  When used with this TAP interface, the QEMU network
+option must be changed to (replacing the ``-net`` options in the examples
+found in the already mentioned ``README.rst`` of the ``rtems-libbsd`` GIT
+repository):
+   -nic tap,model=cadence_gem,ifname=qtap,script=no,downscript=no
+Usage
+The following diagram shows how the TFTP filesystem is used by an
+application.  The mount point can be any directory.  The name ``/tftp``
+used in the figure serves only as an example.  The final unmounting and
+remove directory steps are optional.
+.. figure:: ../images/filesystem/tftpfs_usage.png
+  :width: 90%
+  :align: center
+  :alt: TFTP Usage Diagram
+Mounting the TFTP Filesystem
+When mounting the TFTP filesystem, the argument ``filesystemtype`` must
+be ``RTEMS_FILESYSTEM_TYPE_TFTPFS`` (``#include <rtems/libio.h>``).
+The argument ``data`` can either be
+* a 0-terminated C string of comma separated mount options or
+* ``NULL`` for mounting with default values.
+The mount options are case sensitive.  Spaces are not allowed in the string.
+If conflicting options are specified, the ones more to the right (i.e. end
+of the string) take precedence.  These mount options are supported:
+``blocksize=N``
+  where ``N`` is a decimal integer number.
+  The TFTP blocksize option is introduced in RFC 2348.  It defines the
+  number of octets in the data packages transferred.  Valid values
+  range between 8 and 65464 octets, inclusive.  Values larger
+  than 1468 may cause package fragmentation over standard Ethernet.
+  A value of 512 will prevent this option from being sent to
+  the server.
+  The default value is 1456.
+``windowsize=N``
+  The TFTP windowsize option is introduced in RFC 7440.  It defines the
+  number of data packages send before the receiver must send an
+  acknowledgment package.  Valid values range between 1 and 65535
+  packages, inclusive.  Simple TFTP servers usually do not support this
+  option.  This option may negatively contribute to network
+  congestion.  This can be avoided by using a window size of 1.
+  A value of 1 will prevent this option from being sent to
+  the server.
+  The default value is 8.
+``rfc1350``
+  The TFTP client should strictly follow RFC 1350 and not send any
+  options to the server.  Many simple TFTP server do still not support
+  the option extension defined in RFC 2347.  The TFTP filesystem will
+  always make a second option-less connection attempt to the TFTP server
+  in case a first attempt with options was rejected with an error message.
+  This option is equivalent to ``blocksize=512,windowsize=1``.
+``verbose``
+  During operation, print messages to ``stdout``.  This option has
+  currently little effect.  It is kept to be compatible to older
+  implementations.
+Opening a File
+Files must be opened by using either ``O_RDONLY`` or ``O_WRONLY``
+as flags but not both.  Other flags are not supported.
+The ``pathname`` argument to ``open()`` has the following format:
+  <PREFIX>/<server-address>:<path-on-server>
+``<PREFIX>``
+  The path to the point where the TFTP filesystem is mounted.  This can
+  be a relative path from the current working directory or an absolute
+  path.
+``<server-address>``
+  The network address for the TFTP server from which to download the
+  file or to which the file should be sent.  This is either
+    * an IPv4 address (like `127.0.0.1`) or
+    * the (full-qualified) name of an IPv4 host (acceptable to
+      ``gethostbyname()``)
+  The port number cannot be specified and will always be the one reserved
+  for TFTP: 69.
+``<path-on-server>``
+  The path and file name at which the TFTP server will find or create the
+  file.  Any directories in this path must already exist.  It is not
+  possible to create or read directories with TFTP.  RFC 1350 specifies
+  that this ``<path-on-server>`` must be in *netascii*:
+      This is ascii as defined in "USA Standard Code for Information
+      Interchange" [1] with the modifications specified in "Telnet
+      Protocol Specification" [3].
+      [1] USA Standard Code for Information Interchange, USASI X3.4-1968.
+      [3] Postel, J., "Telnet Protocol Specification," RFC 764,
+      USC/Information Sciences Institute, June, 1980.
+Example pathnames:
+.. code-block:: c
+  "/tftp/169.254.1.1:file.txt"
+  "/TFTPFS/tftp-server.sample.org:bootfiles/image"
+In the above examples, ``/tftp`` and ``/TFTPFS`` are the directory at which
+the TFTP filesystem is mounted.  ``169.254.1.1`` and
+``tftp-server.sample.org`` are the network address of the TFTP server to
+contact.  ``file.txt`` and ``bootfiles/image`` are the file name and
+the path at the server side.
+Closing a File
+Especially, when writing a file to the server, the return
+code of ``close()`` should be checked.  Invoking ``close()`` triggers
+the sending of the last -- not completely filled -- data block.  This
+may fail the same way as any ``write()`` may fail.  Therefore, an error
+returned by ``close()`` likely indicates that the file was not completely
+transferred.
+Use From Shell
+It is possible to use the RTEMS shell through test ``media01`` of
+libbsd to exercise the TFTP filesystem.  This text assumes that libbsd
+has already been setup, configured, compiled and installed as described
+in the ``README.rst`` of the ``rtems-libbsd`` GIT repository.
+How the test ``media01.exe`` can be executed is described in
+section *Qemu and Networking* of that file.
+A TFTP server must be setup and run.  The instructions to setup an TAP
+device and an ``atftp`` server found above in section `External TFTP
+Server Example for OpenSUSE`_ could be followed for this purpose.
+It may be useful to create a sample file for later download in the
+directory served by the TFTP server.  For ``atftp`` "root" could create
+a file with these instructions:
+  # echo "Hello World!" >/srv/tftpboot/hello.txt
+  # chown tftp.tftp /srv/tftpboot/hello.txt
+Start the ``media01`` test in one terminal --- as "normal" user:
+  $ qemu-system-arm -serial null -serial mon:stdio -nographic \
+    -M xilinx-zynq-a9 -m 256M \
+    -nic tap,model=cadence_gem,ifname=qtap,script=no,downscript=no \
+    -kernel build/arm-rtems6-xilinx_zynq_a9_qemu-default/media01.exe
+Wait till a line like the following is printed in the terminal:
+  info: cgem0: using IPv4LL address 169.254.191.13
+Next use the displayed IP address to open a telnet connection in a second terminal:
+  $ telnet 169.254.191.13
+At the telnet prompt, enter this command to list the filesystems
+available for mounting:
+  TLNT [/] # mount -L
+  File systems: / dosfs tftpfs
+``tftpfs`` should be among them.  Create a directory and mount the TFTP
+filesystem:
+  TLNT [/] # mkdir /tftp
+  TLNT [/] # mount -t tftpfs -o verbose "" /tftp
+  mounted  -> /tftp
+Now, files can be sent to and read from the TFTP server using the usual
+shell commands:
+  TLNT [/] # cp /etc/dhcpcd.duid /tftp/169.254.1.1:dhcpcd.duid
+  TFTPFS: /169.254.1.1:dhcpcd.duid
+  TLNT [/] # cat /tftp/169.254.1.1:hello.txt
+  TFTPFS: /169.254.1.1:hello.txt
+  Hello World!
+The terminal session can be terminated with key combination "CTRL-]"
+followed by a ``quit`` command; the
+QEMU simulation with "CTRL-a x" and ``tail -f`` with "CTRL-c".
+TFTP Client API
+The TFTP filesystem has a TFTP client which is responsible to handle all
+network traffic.  It permits the use of TFTP without filesystem.
+Essentially, one saves the mounting of the filesystem.  Otherwise the
+usage is similar to the one of the filesystem.  The equivalent of the
+``open()``, ``read()``, ``write()``, and ``close()`` functions are:
+.. code-block:: c
+  int tftp_open(
+    const char *hostname,
+    const char *path,
+    bool is_for_reading,
+    const tftp_net_config *config,
+    void **tftp_handle
+  ssize_t tftp_read( void *tftp_handle, void *buffer, size_t count );
+  ssize_t tftp_write( void *tftp_handle, const void *buffer, size_t count );
+  int tftp_close( void *tftp_handle );
+``tftp_open()`` accepts as input a data structure of type
+``tftp_net_config``.  It can be used to specify certain values governing
+the file transfer such as the already described options.  Data of
+``tftp_net_config`` type can be initialized using function
+.. code-block:: c
+  void tftp_initialize_net_config( tftp_net_config *config );
+The full description can be found in the file ``cpukit/include/rtems/tftp.h``.
+The function ``rtems_tftpfs_initialize()`` found there is only for RTEMS
+internal use by the ``mount()`` function.
+Software Design
+The original source code contained only the files
+``cpukit/include/rtems/tftp.h`` and ``cpukit/libfs/src/ftpfs/tftpDriver.c``.
+There was no test suite nor any documentation.
+When the code was extended to support options (RFC 2347 and others),
+the code in ``tftpDriver.c`` was split.  The new file ``tftpfs.c`` is
+responsible to handle all filesystem related issues while ``tftpDriver.c``
+provides the network related functions.  In effect ``tftpDriver.c`` is
+a TFTP client library which can be used independently of the filesystem.
+``tftpfs.c`` calls the functions of ``tftpDriver.c`` to do the actual
+TFTP file transfer.
+At this occasion a test suite and this documentation in the *RTEMS
+Filesystem Design Guide* was added.
+Test Suite
+The TFTP filesystem comes with an extensive test suite.
+``libtftpfs`` source code is situated in the RTEMS repository.  For
+testing it, either ``libbsd`` or RTEMS legacy networking would have been
+required.  This implies that the tests for ``libtftpfs`` would have
+needed to be placed in the ``libbsd`` repository --- a different one
+than the ``libtftpfs`` source code.
+Yet, ``libtftpfs`` uses only a handful of networking functions.  The
+test suite provides fake implementations of those functions.  These fake
+functions permit to simulate the exchange of UDP packages
+with the ``libtftpfs`` code and thus permits testing the TFTP filesystem
+without the need of a full network stack.
+Consequently, the test suite is placed in the RTEMS repository together
+with the TFTP filesystem source code.  Neither ``libbsd`` nor RTEMS
+legacy networking is required to run the tests.
+The test suite can be executed using the ``rtems-test`` tool:
+  $ cd <path-to-rtems-git-worktree>
+  $ rtems-test --log-mode=all --rtems-bsp=xilinx_zynq_a9_qemu \
+    build/arm/xilinx_zynq_a9_qemu/testsuites/fstests/tftpfs.exe
2.35.3
