Does libbsd really require POSIX enabled now?
Joel Sherrill
joel at rtems.org
Thu Jun 9 13:44:31 UTC 2022
Hi
I'm starting a new thread because Frank's documentation thread is long
enough already. From that thread:
> I also question why you say RTEMS_POSIX_API needs to be True. That
> does not enable much anymore. I only know of signals and the Sporadic
> Scheduler.
Because when I build libbsd without RTEMS_POSIX_API, I get this error:
RTEMS kernel POSIX support is disabled; configure RTEMS with --enable-posix
(complete log in /home/EB/frank_k/src/rtems-libbsd/build/config.log)
The TFTP FS and test suite do compile and work without RTEMS_POSIX_API
set true.
Historically, it may have been true that the POSIX API had to be enabled
but I don't think it has to be. If that can be confirmed, we need to drop
that requirement.
Are there any features besides signals and sporadic scheduling that are
enabled anymore?
Thanks.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220609/847e7b23/attachment-0001.htm>
