[libbsd 2/9] wpa: Do not use signals
Sebastian Huber
Fri Jun 10 06:08:28 UTC 2022
freebsd/contrib/wpa/src/utils/eloop.c | 16 ++++++++++++++++
1 file changed, 16 insertions(+)
diff --git a/freebsd/contrib/wpa/src/utils/eloop.c b/freebsd/contrib/wpa/src/utils/eloop.c
index 41de0f79..b26de5a0 100644
--- a/freebsd/contrib/wpa/src/utils/eloop.c
+++ b/freebsd/contrib/wpa/src/utils/eloop.c
@@ -955,6 +955,7 @@ int eloop_replenish_timeout(unsigned int req_secs, unsigned int req_usecs,
+#ifndef __rtems__
#ifndef CONFIG_NATIVE_WINDOWS
static void eloop_handle_alarm(int sig)
@@ -966,8 +967,10 @@ static void eloop_handle_alarm(int sig)
exit(1);
#endif /* CONFIG_NATIVE_WINDOWS */
+#endif /* __rtems__ */
+#ifndef __rtems__
static void eloop_handle_signal(int sig)
int i;
@@ -990,6 +993,7 @@ static void eloop_handle_signal(int sig)
static void eloop_process_pending_signals(void)
@@ -1001,9 +1005,11 @@ static void eloop_process_pending_signals(void)
eloop.signaled = 0;
if (eloop.pending_terminate) {
+#ifndef __rtems__
alarm(0);
eloop.pending_terminate = 0;
@@ -1017,6 +1023,7 @@ static void eloop_process_pending_signals(void)
+#ifndef __rtems__
int eloop_register_signal(int sig, eloop_signal_handler handler,
void *user_data)
@@ -1037,26 +1044,35 @@ int eloop_register_signal(int sig, eloop_signal_handler handler,
return 0;
int eloop_register_signal_terminate(eloop_signal_handler handler,
void *user_data)
+#ifndef __rtems__
int ret = eloop_register_signal(SIGINT, handler, user_data);
if (ret == 0)
ret = eloop_register_signal(SIGTERM, handler, user_data);
return ret;
+#else /* __rtems__ */
+ return 0;
int eloop_register_signal_reconfig(eloop_signal_handler handler,
void *user_data)
+#ifndef __rtems__
#ifdef CONFIG_NATIVE_WINDOWS
return 0;
#else /* CONFIG_NATIVE_WINDOWS */
return eloop_register_signal(SIGHUP, handler, user_data);
+ return 0;
2.35.3
