[libbsd 9/9] build: Do not require RTEMS_POSIX_API
Sebastian Huber
Fri Jun 10 06:08:35 UTC 2022
wscript | 4 ----
1 file changed, 4 deletions(-)
diff --git a/wscript b/wscript
index bfdcc91c..7b8f4d31 100644
--- a/wscript
+++ b/wscript
@@ -170,10 +170,6 @@ def options(opt):
def bsp_configure(conf, arch_bsp):
conf.check(header_name="dlfcn.h", features="c")
conf.check(header_name="rtems/pci.h", features="c", mandatory=False)
- if not rtems.check_posix(conf):
- conf.fatal(
- "RTEMS kernel POSIX support is disabled; configure RTEMS with --enable-posix"
if rtems.check_networking(conf):
conf.fatal(
"RTEMS kernel contains the old network support;" \
2.35.3
