[libbsd 6/9] ping6: Do not use signals
Sebastian Huber
Fri Jun 10 06:08:32 UTC 2022
freebsd/sbin/ping6/ping6.c | 16 ++++++++++++++++
1 file changed, 16 insertions(+)
diff --git a/freebsd/sbin/ping6/ping6.c b/freebsd/sbin/ping6/ping6.c
index 96bd60e3..67ad46eb 100644
--- a/freebsd/sbin/ping6/ping6.c
+++ b/freebsd/sbin/ping6/ping6.c
@@ -287,7 +287,9 @@ static void fill(char *, char *);
static int get_hoplim(struct msghdr *);
static int get_pathmtu(struct msghdr *);
static struct in6_pktinfo *get_rcvpktinfo(struct msghdr *);
+#ifndef __rtems__
static void onsignal(int);
+#endif /* __rtems__ */
static void onint(int);
static size_t pingerlen(void);
static int pinger(void);
@@ -347,7 +349,9 @@ main(int argc, char *argv[])
struct timespec last, intvl;
struct sockaddr_in6 from, *sin6;
struct addrinfo hints, *res;
+#ifndef __rtems__
struct sigaction si_sa;
int cc, i;
int almost_done, ch, hold, packlen, preload, optval, error;
int nig_oldmcprefix = -1;
@@ -374,7 +378,9 @@ main(int argc, char *argv[])
char *policy_out = NULL;
#endif
double t;
+#ifndef __rtems__
u_long alarmtimeout;
size_t rthlen;
#ifdef IPV6_USE_MIN_MTU
int mflag = 0;
@@ -400,7 +406,9 @@ main(int argc, char *argv[])
intvl.tv_sec = interval / 1000;
intvl.tv_nsec = interval % 1000 * 1000000;
+#ifndef __rtems__
alarmtimeout = preload = 0;
datap = &outpack[ICMP6ECHOLEN + ICMP6ECHOTMLEN];
capdns = capdns_setup();
#ifndef IPSEC
@@ -628,6 +636,7 @@ main(int argc, char *argv[])
options |= F_WAITTIME;
waittime = (int)t;
break;
+#ifndef __rtems__
case 'X':
alarmtimeout = strtoul(optarg, &e, 0);
if ((alarmtimeout < 1) || (alarmtimeout == ULONG_MAX))
@@ -638,6 +647,7 @@ main(int argc, char *argv[])
optarg, MAXALARM);
alarm((int)alarmtimeout);
break;
#ifdef IPSEC
#ifdef IPSEC_POLICY_IPSEC
case 'P':
@@ -1174,6 +1184,7 @@ main(int argc, char *argv[])
clock_gettime(CLOCK_MONOTONIC, &last);
+#ifndef __rtems__
sigemptyset(&si_sa.sa_mask);
si_sa.sa_flags = 0;
si_sa.sa_handler = onsignal;
@@ -1189,6 +1200,7 @@ main(int argc, char *argv[])
if (sigaction(SIGALRM, &si_sa, 0) == -1)
err(EX_OSERR, "sigaction SIGALRM");
if (options & F_FLOOD) {
intvl.tv_sec = 0;
intvl.tv_nsec = 10000000;
@@ -1310,11 +1322,13 @@ main(int argc, char *argv[])
+#ifndef __rtems__
si_sa.sa_flags = 0;
si_sa.sa_handler = SIG_IGN;
sigaction(SIGINT, &si_sa, 0);
sigaction(SIGALRM, &si_sa, 0);
summary();
if(packet != NULL)
@@ -1323,6 +1337,7 @@ main(int argc, char *argv[])
exit(nreceived == 0 ? 2 : 0);
+#ifndef __rtems__
static void
onsignal(int sig)
@@ -1339,6 +1354,7 @@ onsignal(int sig)
#endif
* pinger --
2.35.3
