[libbsd 7/9] wlanstats: Do not use signals
Sebastian Huber
Fri Jun 10 06:08:33 UTC 2022
freebsd/tools/tools/net80211/wlanstats/main.c | 22 +++++++------------
.../wlanstats/rtems-bsd-wlanstats-main-data.h | 2 --
2 files changed, 8 insertions(+), 16 deletions(-)
diff --git a/freebsd/tools/tools/net80211/wlanstats/main.c b/freebsd/tools/tools/net80211/wlanstats/main.c
index 3a6fd204..ef2caf56 100644
--- a/freebsd/tools/tools/net80211/wlanstats/main.c
+++ b/freebsd/tools/tools/net80211/wlanstats/main.c
@@ -43,6 +43,7 @@
#ifdef __rtems__
#define __need_getopt_newlib
#include <getopt.h>
+#include <string.h>
#include <machine/rtems-bsd-program.h>
#include <machine/rtems-bsd-commands.h>
#endif /* __rtems__ */
@@ -96,6 +97,7 @@ getfmt(const char *tag)
return tag;
+#ifndef __rtems__
static int signalled;
static void
@@ -103,6 +105,7 @@ catchalarm(int signo __unused)
signalled = 1;
+#endif /* __rtems__ */
#if 0
static void
@@ -262,6 +265,7 @@ main(int argc, char *argv[])
wf->setstamac(wf, mac);
if (argc > 0) {
+#ifndef __rtems__
u_long interval = strtoul(argv[0], NULL, 0);
int line, omask;
@@ -283,24 +287,10 @@ main(int argc, char *argv[])
wf->print_total(wf, stdout);
fflush(stdout);
-#ifndef __rtems__
omask = sigblock(sigmask(SIGALRM));
if (!signalled)
sigpause(0);
sigsetmask(omask);
-#else /* __rtems__ */
- sigset_t oldmask, desired, empty;
- sigemptyset(&empty);
- sigemptyset(&desired);
- sigaddset(&desired, SIGALRM);
- sigprocmask(SIG_BLOCK, &desired, &oldmask);
- while (!signalled)
- sigsuspend(&desired);
- sigprocmask(SIG_SETMASK, &oldmask, NULL);
-#endif /* __rtems__ */
signalled = 0;
alarm(interval);
line++;
@@ -346,6 +336,10 @@ main(int argc, char *argv[])
} while (len >= sizeof(struct ieee80211req_sta_info));
#endif
+#else /* __rtems__ */
+ (void)mode;
+ printf("wlanstats: not implemented\n");
} else {
wf->collect_tot(wf);
wf->print_verbose(wf, stdout);
diff --git a/freebsd/tools/tools/net80211/wlanstats/rtems-bsd-wlanstats-main-data.h b/freebsd/tools/tools/net80211/wlanstats/rtems-bsd-wlanstats-main-data.h
index f88c5834..afb145be 100644
--- a/freebsd/tools/tools/net80211/wlanstats/rtems-bsd-wlanstats-main-data.h
+++ b/freebsd/tools/tools/net80211/wlanstats/rtems-bsd-wlanstats-main-data.h
@@ -1,5 +1,3 @@
/* generated by userspace-header-gen.py */
#include <rtems/linkersets.h>
#include "rtems-bsd-wlanstats-data.h"
-/* main.c */
-RTEMS_LINKER_RWSET_CONTENT(bsd_prog_wlanstats, static int signalled);
2.35.3
