AW: AW: AW: AW: [PATCH] kern_tc.c: Update pps_event() for uniprocessor configurations
Sebastian Huber
Fri Jun 10 07:11:37 UTC 2022
On 10.06.22 09:09, Gabriel.Moyano at dlr.de wrote:
>> On 08.06.22 09:54,Gabriel.Moyano at dlr.de wrote:
>>>>>>>> I don't know why there is this "if" in the code. I will ask on a FreeBSD mailing list.
>>>>>>> I think it is for the case that th_generation has changed in
>>>>>>> between saving the th and th_counter. If this happens pps->capgen
>>>>>>> is set to
>>>>>>> 0 and later pps_event() returns earlier. Since for uniprocessor
>>>>>>> th_generation equal to 0 is not used, I guess we can removed this
>>>>>>> if for those configurations
>>>>>> I asked on a FreeBSD mailing list:
>>>>>> https://lists.freebsd.org/archives/freebsd-hackers/2022-June/001165
>>>>>> .h
>>>>>> tml
>>>>> Thanks for asking.
>>>>> I'll prepare and send a new patch removing the "if" for uniprocessor configurations just in case.
>>>> Please wait with a new patch for a response from FreeBSD.
>>> What is your suggestion here? Should we check the generation only once? Or should we leave the code as is and just remove the
>> "if" in pps_capture() for uniprocessor configurations since th_generation equal to zero is not used?
>> We should first leave the code as is. I don't know when I have time to send patches to FreeBSD.
> I would like it to be considered to remove the parts where th_generation is checked to be equal to zero just for uniprocessor configurations.
> The reason is that porting back these changes to RTEMS 5, the test sppps01 fails because th_generation starts with value zero. Not sure why in RTEMS 6 th_generation starts with one but since in uniprocessor configuration th_generation equal zero is not used, I think it makes sense to not consider that case.
Yes, please fix this. What I meant is that we should not change the
FreeBSD code in general.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
