[PATCH] kern_tc.c: Update pps_event() for uniprocessor configurations
Gabriel Moyano
gabriel.moyano at dlr.de
Fri Jun 10 07:20:58 UTC 2022
Since pps->capgen is not used in uniprocessor configurations, there is no need to verified if it is equal to zero
Update #2349
cpukit/score/src/kern_tc.c | 6 ++++++
1 file changed, 6 insertions(+)
diff --git a/cpukit/score/src/kern_tc.c b/cpukit/score/src/kern_tc.c
index 92739d8edd..78d7fa1e3f 100644
--- a/cpukit/score/src/kern_tc.c
+++ b/cpukit/score/src/kern_tc.c
@@ -2138,9 +2138,11 @@ pps_capture(struct pps_state *pps)
pps->capffth = fftimehands;
#endif
pps->capcount = th->th_counter->tc_get_timecount(th->th_counter);
+#if defined(RTEMS_SMP)
atomic_thread_fence_acq();
if (pps->capgen != th->th_generation)
pps->capgen = 0;
+#endif
void
@@ -2165,7 +2167,11 @@ pps_event(struct pps_state *pps, int event)
if ((event & pps->ppsparam.mode) == 0)
return;
/* If the timecounter was wound up underneath us, bail out. */
if (pps->capgen == 0 || pps->capgen !=
+#else
+ if (pps->capgen !=
+#endif
atomic_load_acq_int(&pps->capth->th_generation))
return;
2.25.1
