[PATCH 06/13] jffs2: Remove jffs2_gc_fetch_page and jffs2_gc_release_page
Sebastian Huber
Fri Jun 10 08:20:58 UTC 2022
Merge these two helpers into the only callers to get rid of some
amazingly bad calling conventions.
Suggested-by: Al Viro <viro at zeniv.linux.org.uk>
Signed-off-by: Christoph Hellwig <hch at lst.de>
Signed-off-by: Richard Weinberger <richard at nod.at>
cpukit/libfs/src/jffs2/src/fs-rtems.c | 24 ------------------
cpukit/libfs/src/jffs2/src/gc.c | 35 +++++++++++++++++++++------
cpukit/libfs/src/jffs2/src/os-rtems.h | 3 ---
3 files changed, 27 insertions(+), 35 deletions(-)
diff --git a/cpukit/libfs/src/jffs2/src/fs-rtems.c b/cpukit/libfs/src/jffs2/src/fs-rtems.c
index 8bc3d85cc3..b863c74547 100644
--- a/cpukit/libfs/src/jffs2/src/fs-rtems.c
+++ b/cpukit/libfs/src/jffs2/src/fs-rtems.c
@@ -1316,30 +1316,6 @@ int rtems_jffs2_initialize(
-unsigned char *jffs2_gc_fetch_page(struct jffs2_sb_info *c,
- struct jffs2_inode_info *f,
- unsigned long offset,
- unsigned long *priv)
- int ret;
- struct super_block *sb = OFNI_BS_2SFFJ(c);
- unsigned char *gc_buffer = &sb->s_gc_buffer[0];
- ret = jffs2_read_inode_range(c, f, gc_buffer,
- offset & ~(PAGE_CACHE_SIZE-1), PAGE_CACHE_SIZE);
- if (ret)
- return ERR_PTR(ret);
- return gc_buffer;
-void jffs2_gc_release_page(struct jffs2_sb_info *c,
- unsigned char *ptr,
- /* Do nothing */
static struct _inode *new_inode(struct super_block *sb)
diff --git a/cpukit/libfs/src/jffs2/src/gc.c b/cpukit/libfs/src/jffs2/src/gc.c
index f557075ab8..04ec073d2b 100644
--- a/cpukit/libfs/src/jffs2/src/gc.c
+++ b/cpukit/libfs/src/jffs2/src/gc.c
@@ -1173,12 +1173,17 @@ static int jffs2_garbage_collect_dnode(struct jffs2_sb_info *c, struct jffs2_era
struct jffs2_inode_info *f, struct jffs2_full_dnode *fn,
uint32_t start, uint32_t end)
+#ifndef __rtems__
+ struct inode *inode = OFNI_EDONI_2SFFJ(f);
+#endif /* __rtems__ */
struct jffs2_full_dnode *new_fn;
struct jffs2_raw_inode ri;
uint32_t alloclen, offset, orig_end, orig_start;
int ret = 0;
unsigned char *comprbuf = NULL, *writebuf;
- unsigned long pg;
+#ifndef __rtems__
+ struct page *page;
unsigned char *pg_ptr;
memset(&ri, 0, sizeof(ri));
@@ -1333,15 +1338,26 @@ static int jffs2_garbage_collect_dnode(struct jffs2_sb_info *c, struct jffs2_era
* end up here trying to GC the *same* page that jffs2_write_begin() is
* trying to write out, read_cache_page() will not deadlock. */
mutex_unlock(&f->sem);
- pg_ptr = jffs2_gc_fetch_page(c, f, start, &pg);
- mutex_lock(&f->sem);
- if (IS_ERR(pg_ptr)) {
+#ifndef __rtems__
+ page = read_cache_page(inode->i_mapping, start >> PAGE_SHIFT,
+ jffs2_do_readpage_unlock, inode);
+ if (IS_ERR(page)) {
pr_warn("read_cache_page() returned error: %ld\n",
- PTR_ERR(pg_ptr));
- return PTR_ERR(pg_ptr);
+ PTR_ERR(page));
+ mutex_lock(&f->sem);
+ return PTR_ERR(page);
+ pg_ptr = kmap(page);
+#else /* __rtems__ */
+ pg_ptr = &OFNI_BS_2SFFJ(c)->s_gc_buffer[0];
+ ret = jffs2_read_inode_range(c, f, pg_ptr,
+ start & ~(PAGE_CACHE_SIZE-1), PAGE_CACHE_SIZE);
+ if (ret)
+ return ret;
offset = start;
while(offset < orig_end) {
uint32_t datalen;
@@ -1404,6 +1420,9 @@ static int jffs2_garbage_collect_dnode(struct jffs2_sb_info *c, struct jffs2_era
- jffs2_gc_release_page(c, pg_ptr, &pg);
+#ifndef __rtems__
+ kunmap(page);
+ put_page(page);
return ret;
diff --git a/cpukit/libfs/src/jffs2/src/os-rtems.h b/cpukit/libfs/src/jffs2/src/os-rtems.h
index 0bec517691..d9e4330371 100644
--- a/cpukit/libfs/src/jffs2/src/os-rtems.h
+++ b/cpukit/libfs/src/jffs2/src/os-rtems.h
@@ -136,9 +136,6 @@ struct _inode *jffs2_iget(struct super_block *sb, cyg_uint32 ino);
void jffs2_iput(struct _inode * i);
void jffs2_gc_release_inode(struct jffs2_sb_info *c, struct jffs2_inode_info *f);
struct jffs2_inode_info *jffs2_gc_fetch_inode(struct jffs2_sb_info *c, int inum, int nlink);
-unsigned char *jffs2_gc_fetch_page(struct jffs2_sb_info *c, struct jffs2_inode_info *f,
- unsigned long offset, unsigned long *priv);
-void jffs2_gc_release_page(struct jffs2_sb_info *c, unsigned char *pg, unsigned long *priv);
/* Avoid polluting RTEMS namespace with names not starting in jffs2_ */
#define os_to_jffs2_mode(x) jffs2_from_os_mode(x)
2.35.3
