[PATCH 07/13] jffs2: Fix memory leak in jffs2_scan_eraseblock() error path
Fri Jun 10 08:20:59 UTC 2022
In jffs2_scan_eraseblock(), 'sumptr' is allocated through kmalloc() if
'sumlen' is larger than 'buf_size'. However, it is not deallocated in the
following execution if jffs2_fill_scan_buf() fails, leading to a memory
leak bug. To fix this issue, free 'sumptr' before returning the error.
Signed-off-by: Wenwen Wang <wenwen at cs.uga.edu>
Signed-off-by: Richard Weinberger <richard at nod.at>
 cpukit/libfs/src/jffs2/src/scan.c | 5 ++++-
 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/cpukit/libfs/src/jffs2/src/scan.c b/cpukit/libfs/src/jffs2/src/scan.c
index 177a0cdd3f..d5441448b0 100644
--- a/cpukit/libfs/src/jffs2/src/scan.c
+++ b/cpukit/libfs/src/jffs2/src/scan.c
@@ -530,8 +530,11 @@ static int jffs2_scan_eraseblock (struct jffs2_sb_info *c, struct jffs2_eraseblo
 					err = jffs2_fill_scan_buf(c, sumptr,
 								  jeb->offset + c->sector_size - sumlen,
 								  sumlen - buf_len);
-					if (err)
+					if (err) {
+						if (sumlen > buf_size)
+							kfree(sumptr);
 						return err;
2.35.3
