[PATCH 09/13] jffs2: Replace zero-length array with flexible-array
Sebastian Huber
Fri Jun 10 08:21:01 UTC 2022
From: "Gustavo A. R. Silva" <gustavoars at kernel.org>
There is a regular need in the kernel to provide a way to declare having a
dynamically sized set of trailing elements in a structure. Kernel code should
always use “flexible array members”[1] for these cases. The older style of
one-element or zero-length arrays should no longer be used[2].
[1] https://en.wikipedia.org/wiki/Flexible_array_member
[2] https://github.com/KSPP/linux/issues/21
Signed-off-by: Gustavo A. R. Silva <gustavoars at kernel.org>
cpukit/libfs/src/jffs2/src/nodelist.h | 2 +-
cpukit/libfs/src/jffs2/src/summary.h | 4 ++--
2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/cpukit/libfs/src/jffs2/src/nodelist.h b/cpukit/libfs/src/jffs2/src/nodelist.h
index 143f60dbcb..4eee0ac8ff 100644
--- a/cpukit/libfs/src/jffs2/src/nodelist.h
+++ b/cpukit/libfs/src/jffs2/src/nodelist.h
@@ -259,7 +259,7 @@ struct jffs2_full_dirent
uint32_t ino; /* == zero for unlink */
unsigned int nhash;
unsigned char type;
- unsigned char name[0];
+ unsigned char name[];
diff --git a/cpukit/libfs/src/jffs2/src/summary.h b/cpukit/libfs/src/jffs2/src/summary.h
index 60207a2ae9..e4131cb1f1 100644
--- a/cpukit/libfs/src/jffs2/src/summary.h
+++ b/cpukit/libfs/src/jffs2/src/summary.h
@@ -61,7 +61,7 @@ struct jffs2_sum_dirent_flash
jint32_t ino; /* == zero for unlink */
uint8_t nsize; /* dirent name size */
uint8_t type; /* dirent type */
- uint8_t name[0]; /* dirent name */
+ uint8_t name[]; /* dirent name */
} __attribute__((packed));
struct jffs2_sum_xattr_flash
@@ -117,7 +117,7 @@ struct jffs2_sum_dirent_mem
struct jffs2_sum_xattr_mem
2.35.3
