[PATCH 08/13] Revert "jffs2: Fix possible null-pointer dereferences in jffs2_add_frag_to_fragtree()"
Sebastian Huber
Fri Jun 10 08:21:00 UTC 2022
This reverts commit f2538f999345405f7d2e1194c0c8efa4e11f7b3a. The patch
stopped JFFS2 from being able to mount an existing filesystem with the
following errors:
jffs2: error: (77) jffs2_build_inode_fragtree: Add node to tree failed -22
jffs2: error: (77) jffs2_do_read_inode_internal: Failed to build final fragtree for inode #5377: error -22
Fixes: f2538f999345 ("jffs2: Fix possible null-pointer dereferences...")
Cc: stable at vger.kernel.org
Suggested-by: Hou Tao <houtao1 at huawei.com>
Signed-off-by: Joel Stanley <joel at jms.id.au>
Signed-off-by: Richard Weinberger <richard at nod.at>
cpukit/libfs/src/jffs2/src/nodelist.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/cpukit/libfs/src/jffs2/src/nodelist.c b/cpukit/libfs/src/jffs2/src/nodelist.c
index 86dd8e60d1..ee44024c92 100644
--- a/cpukit/libfs/src/jffs2/src/nodelist.c
+++ b/cpukit/libfs/src/jffs2/src/nodelist.c
@@ -228,7 +228,7 @@ static int jffs2_add_frag_to_fragtree(struct jffs2_sb_info *c, struct rb_root *r
lastend = this->ofs + this->size;
} else {
dbg_fragtree2("lookup gave no frag\n");
- return -EINVAL;
+ lastend = 0;
/* See if we ran off the end of the fragtree */
2.35.3
