[PATCH 4/5] bsps/stm32h7: import stm32h747i-disco QSPI memory high-level driver
Karel Gardas
karel at functional.vision
Fri Jun 10 12:49:29 UTC 2022
Sponsored-By: Precidata
.../stm32h747i_discovery_conf.h | 119 ++
.../stm32h747i_discovery_errno.h | 106 ++
.../stm32h747i_discovery_qspi.c | 1100 +++++++++++++++++
.../stm32h747i_discovery_qspi.h | 286 +++++
4 files changed, 1611 insertions(+)
create mode 100644 bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h747i_discovery_conf.h
create mode 100644 bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h747i_discovery_errno.h
create mode 100644 bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h747i_discovery_qspi.c
create mode 100644 bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h747i_discovery_qspi.h
diff --git a/bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h747i_discovery_conf.h b/bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h747i_discovery_conf.h
new file mode 100644
index 0000000000..8cacaddb7e
--- /dev/null
+++ b/bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h747i_discovery_conf.h
@@ -0,0 +1,119 @@
+/* SPDX-License-Identifier: BSD-3-Clause */
+ * @file stm32h747i_discovery_conf_template.h
+ * @author MCD Application Team
+ * @brief STM32H747I_DISCO board configuration file.
+ * @attention
+ * Copyright (c) 2018 STMicroelectronics.
+ * All rights reserved.
+ * This software is licensed under terms that can be found in the LICENSE file
+ * in the root directory of this software component.
+ * If no LICENSE file comes with this software, it is provided AS-IS.
+ * RTEMS committer clarification comment on license above:
+ * This file comes from STM32CubeH7 project and is located here:
+ * https://github.com/STMicroelectronics/STM32CubeH7/blob/master/Drivers/BSP/STM32H747I-DISCO/stm32h747i_discovery_conf_template.h
+ * The file root directory is:
+ * https://github.com/STMicroelectronics/STM32CubeH7/tree/master/Drivers/BSP/STM32H747I-DISCO
+ * This directory contains LICENSE.md file with a following license text:
+ * Copyright 2019 STMicroelectronics.
+ * Redistribution and use in source and binary forms, with or without modification,
+ * are permitted provided that the following conditions are met:
+ * 1. Redistributions of source code must retain the above copyright notice, this
+ * list of conditions and the following disclaimer.
+ * 2. Redistributions in binary form must reproduce the above copyright notice,
+ * this list of conditions and the following disclaimer in the documentation and/or
+ * other materials provided with the distribution.
+ * 3. Neither the name of the copyright holder nor the names of its contributors
+ * may be used to endorse or promote products derived from this software without
+ * specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
+ * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+ * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR
+ * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
+ * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
+ * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
+ * ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+ * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
+ * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+/* Define to prevent recursive inclusion -------------------------------------*/
+#ifndef STM32H747I_DISCO_CONF_H
+#define STM32H747I_DISCO_CONF_H
+#ifdef __cplusplus
+ extern "C" {
+#endif
+/* Includes ------------------------------------------------------------------*/
+#include "stm32h7xx_hal.h"
+/* COM define */
+#define USE_COM_LOG 0U
+#define USE_BSP_COM_FEATURE 0U
+/* LCD controllers defines */
+#define USE_LCD_CTRL_OTM8009A 1U
+#define USE_LCD_CTRL_ADV7533 1U
+#define LCD_LAYER_0_ADDRESS 0xC0000000U
+#define LCD_LAYER_1_ADDRESS 0xC0200000U
+#define USE_DMA2D_TO_FILL_RGB_RECT 0U
+/* Camera sensors defines */
+#define USE_CAMERA_SENSOR_OV5640 1U
+#define USE_CAMERA_SENSOR_OV9655 1U
+/* SD interface defines */
+#define USE_SD_BUS_WIDE_4B 1U
+/* Audio codecs defines */
+#define USE_AUDIO_CODEC_WM8994 1U
+/* TS supported features defines */
+#define USE_TS_GESTURE 1U
+#define USE_TS_MULTI_TOUCH 1U
+/* Default TS touch number */
+#define TS_TOUCH_NBR 2U
+/* IRQ priorities */
+#define BSP_SDRAM_IT_PRIORITY 15U
+#define BSP_CAMERA_IT_PRIORITY 15U
+#define BSP_BUTTON_WAKEUP_IT_PRIORITY 15U
+#define BSP_AUDIO_OUT_IT_PRIORITY 14U
+#define BSP_AUDIO_IN_IT_PRIORITY 15U
+#define BSP_SD_IT_PRIORITY 14U
+#define BSP_SD_RX_IT_PRIORITY 14U
+#define BSP_SD_TX_IT_PRIORITY 15U
+#define BSP_TS_IT_PRIORITY 15U
+#define BSP_JOY1_SEL_IT_PRIORITY 15U
+#define BSP_JOY1_DOWN_IT_PRIORITY 15U
+#define BSP_JOY1_LEFT_IT_PRIORITY 15U
+#define BSP_JOY1_RIGHT_IT_PRIORITY 15U
+#define BSP_JOY1_UP_IT_PRIORITY 15U
+#ifdef __cplusplus
+#endif
+#endif /* STM32H747I_DISCO_CONF_H */
diff --git a/bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h747i_discovery_errno.h b/bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h747i_discovery_errno.h
index 0000000000..269036d170
--- /dev/null
+++ b/bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h747i_discovery_errno.h
@@ -0,0 +1,106 @@
+ * @file STM32H747I_discovery_errno.h
+ * @brief Error Code.
+ * @attention
+ * https://github.com/STMicroelectronics/STM32CubeH7/blob/master/Drivers/BSP/STM32H747I-DISCO/stm32h747i_discovery_errno.h
+#ifndef STM32H747I_DISCO_ERRNO_H
+#define STM32H747I_DISCO_ERRNO_H
+#ifdef __cplusplus
+ extern "C" {
+#endif
+/* Common Error codes */
+#define BSP_ERROR_NONE 0
+#define BSP_ERROR_NO_INIT -1
+#define BSP_ERROR_WRONG_PARAM -2
+#define BSP_ERROR_BUSY -3
+#define BSP_ERROR_PERIPH_FAILURE -4
+#define BSP_ERROR_COMPONENT_FAILURE -5
+#define BSP_ERROR_UNKNOWN_FAILURE -6
+#define BSP_ERROR_UNKNOWN_COMPONENT -7
+#define BSP_ERROR_BUS_FAILURE -8
+#define BSP_ERROR_CLOCK_FAILURE -9
+#define BSP_ERROR_MSP_FAILURE -10
+#define BSP_ERROR_FEATURE_NOT_SUPPORTED -11
+/* BSP OSPI error codes */
+#define BSP_ERROR_QSPI_ASSIGN_FAILURE -24
+#define BSP_ERROR_QSPI_SETUP_FAILURE -25
+#define BSP_ERROR_QSPI_MMP_LOCK_FAILURE -26
+#define BSP_ERROR_QSPI_MMP_UNLOCK_FAILURE -27
+/* BSP TS error code */
+#define BSP_ERROR_TS_TOUCH_NOT_DETECTED -30
+/* BSP BUS error codes */
+#define BSP_ERROR_BUS_TRANSACTION_FAILURE -100
+#define BSP_ERROR_BUS_ARBITRATION_LOSS -101
+#define BSP_ERROR_BUS_ACKNOWLEDGE_FAILURE -102
+#define BSP_ERROR_BUS_PROTOCOL_FAILURE -103
+#define BSP_ERROR_BUS_MODE_FAULT -104
+#define BSP_ERROR_BUS_FRAME_ERROR -105
+#define BSP_ERROR_BUS_CRC_ERROR -106
+#define BSP_ERROR_BUS_DMA_FAILURE -107
+#ifdef __cplusplus
+#endif
+#endif /* STM32H747I_DISCO_ERRNO_H */
diff --git a/bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h747i_discovery_qspi.c b/bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h747i_discovery_qspi.c
index 0000000000..6c53cb28bb
--- /dev/null
+++ b/bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h747i_discovery_qspi.c
@@ -0,0 +1,1100 @@
+ * @file stm32h747i_discovery_qspi.c
+ * @brief This file includes a standard driver for the MT25TL01G QSPI
+ * memory mounted on STM32H747I-DISCO board.
+ @verbatim
+ How To use this driver:
+ - This driver is used to drive the MT25TL01G QSPI external
+ memory mounted on STM32H747I-DISCO board.
+ - This driver need a specific component driver (MT25TL01G) to be included with.
+ Driver description:
+ - Initialization steps:
+ + Initialize the QPSI external memory using the BSP_QSPI_Init() function. This
+ function includes the MSP layer hardware resources initialization and the
+ QSPI interface with the external memory.
+ STR and DTR transfer rates are supported.
+ SPI, SPI 2-IO, SPI-4IO and QPI modes are supported
+ - QSPI memory operations
+ + QSPI memory can be accessed with read/write operations once it is
+ initialized.
+ Read/write operation can be performed with AHB access using the functions
+ BSP_QSPI_Read()/BSP_QSPI_Write().
+ + The function BSP_QSPI_GetInfo() returns the configuration of the QSPI memory.
+ (see the QSPI memory data sheet)
+ + Perform erase block operation using the function BSP_QSPI_EraseBlock() and by
+ specifying the block address. You can perform an erase operation of the whole
+ chip by calling the function BSP_QSPI_EraseChip().
+ + The function BSP_QSPI_GetStatus() returns the current status of the QSPI memory.
+ + The function BSP_QSPI_EnableMemoryMappedMode enables the QSPI memory mapped mode
+ + The function BSP_QSPI_DisableMemoryMappedMode disables the QSPI memory mapped mode
+ + The function BSP_QSPI_ConfigFlash() allow to configure the QSPI mode and transfer rate
+ Note:
+ Regarding the "Instance" parameter, needed for all functions, it is used to select
+ an QSPI instance. On the STM32H747I_DISCO board, there's one instance. Then, this
+ parameter should be 0.
+ @endverbatim
+ * @attention
+ * https://github.com/STMicroelectronics/STM32CubeH7/blob/master/Drivers/BSP/STM32H747I-DISCO/stm32h747i_discovery_qspi.c
+#include "stm32h747i_discovery_qspi.h"
+/** @addtogroup BSP
+/** @addtogroup STM32H747I_DISCO
+/** @defgroup STM32H747I_DISCO_QSPI QSPI
+/* Private variables ---------------------------------------------------------*/
+/** @defgroup STM32H747I_DISCO_QSPI_Exported_Variables Exported Variables
+QSPI_HandleTypeDef hqspi;
+BSP_QSPI_Ctx_t QSPI_Ctx[QSPI_INSTANCES_NUMBER];
+/* Private functions ---------------------------------------------------------*/
+/** @defgroup STM32H747I_DISCO_QSPI_Private_Functions Private Functions
+static void QSPI_MspInit(QSPI_HandleTypeDef *hQspi);
+static void QSPI_MspDeInit(QSPI_HandleTypeDef *hSspi);
+static int32_t QSPI_ResetMemory(uint32_t Instance);
+static int32_t QSPI_DummyCyclesCfg(uint32_t Instance);
+/** @defgroup STM32H747I_DISCO_QSPI_Exported_Functions Exported Functions
+ * @brief Initializes the QSPI interface.
+ * Instance management :
+ * Instance can running at Indirect or MMP mode.
+ * Every indirect instance can switch between.
+ * Once MMP instance active then Instance switch function disabled.
+ * Only 1 MMP instance can run.
+ * Instance switch function enabled after MMP instance exit to Indirect mode.
+ * MT25TL01G action :
+ * QE(Quad Enable, Non-volatile) bit of Status Register
+ * QE = 0; WP# & RESET# pin active
+ * Accept 1-1-1, 1-1-2, 1-2-2 commands
+ * QE = 1; WP# become SIO2 pin, RESET# become SIO3 pin
+ * Accept 1-1-1, 1-1-2, 1-2-2, 1-1-4, 1-4-4 commands
+ * Enter QPI mode by issue EQIO(0x35) command from 1-1-1 mode
+ * Accept 4-4-4 commands
+ * Exit QPI mode by issue RSTQIO(0xF5) command from 4-4-4 mode
+ * Accept commands, dependent QE bit status
+ * Memory Read commands support STR(Single Transfer Rate) & DTR(Double Transfer Rate) mode
+ * Force QE = 1, Enter 4-Byte address mode
+ * Configure Dummy cycle & ODS(Out Driver Strength)
+ * STR/DTR effect read commands only
+ * @param Instance QSPI Instance
+ * @param Init QSPI Init structure
+ * @retval BSP status
+int32_t BSP_QSPI_Init(uint32_t Instance, BSP_QSPI_Init_t *Init)
+ int32_t ret = BSP_ERROR_NONE;
+ BSP_QSPI_Info_t pInfo;
+ MX_QSPI_Init_t qspi_init;
+ /* Table to handle clock prescalers:
+ 1: For STR mode to reach max 108Mhz
+ 3: For DTR mode to reach max 54Mhz
+ static const uint32_t PrescalerTab[2] = {1, 3};
+ /* Check if the instance is supported */
+ if(Instance >= QSPI_INSTANCES_NUMBER)
+ ret = BSP_ERROR_WRONG_PARAM;
+ else
+ /* Check if instance is already initialized */
+ if(QSPI_Ctx[Instance].IsInitialized == QSPI_ACCESS_NONE)
+#if (USE_HAL_QSPI_REGISTER_CALLBACKS == 1)
+ /* Register the QSPI MSP Callbacks */
+ if(QSPI_Ctx[Instance].IsMspCallbacksValid == 0UL)
+ if(BSP_QSPI_RegisterDefaultMspCallbacks(Instance) != BSP_ERROR_NONE)
+ ret = BSP_ERROR_PERIPH_FAILURE;
+#else
+ /* Msp QSPI initialization */
+ QSPI_MspInit(&hqspi);
+#endif /* USE_HAL_QSPI_REGISTER_CALLBACKS */
+ if(ret == BSP_ERROR_NONE)
+ /* STM32 QSPI interface initialization */
+ (void)MT25TL01G_GetFlashInfo(&pInfo);
+ qspi_init.ClockPrescaler = PrescalerTab[Init->TransferRate];
+ qspi_init.DualFlashMode = QSPI_DUALFLASH_ENABLE;
+ qspi_init.FlashSize = (uint32_t)POSITION_VAL((uint32_t)pInfo.FlashSize) - 1U;
+ qspi_init.SampleShifting = (Init->TransferRate == BSP_QSPI_STR_TRANSFER) ? QSPI_SAMPLE_SHIFTING_HALFCYCLE : QSPI_SAMPLE_SHIFTING_NONE;
+ if(MX_QSPI_Init(&hqspi, &qspi_init) != HAL_OK)
+ }/* QSPI memory reset */
+ else if(QSPI_ResetMemory(Instance) != BSP_ERROR_NONE)
+ ret = BSP_ERROR_COMPONENT_FAILURE;
+ }/* Force Flash enter 4 Byte address mode */
+ else if(MT25TL01G_AutoPollingMemReady(&hqspi, QSPI_Ctx[Instance].InterfaceMode) != MT25TL01G_OK)
+ else if(MT25TL01G_Enter4BytesAddressMode(&hqspi, QSPI_Ctx[Instance].InterfaceMode) != MT25TL01G_OK)
+ }/* Configuration of the dummy cycles on QSPI memory side */
+ else if(QSPI_DummyCyclesCfg(Instance) != BSP_ERROR_NONE)
+ else
+ /* Configure Flash to desired mode */
+ if(BSP_QSPI_ConfigFlash(Instance, Init->InterfaceMode, Init->TransferRate) != BSP_ERROR_NONE)
+ /* Return BSP status */
+ return ret;
+ * @brief De-Initializes the QSPI interface.
+int32_t BSP_QSPI_DeInit(uint32_t Instance)
+ else
+ if(QSPI_Ctx[Instance].IsInitialized == QSPI_ACCESS_MMP)
+ if(BSP_QSPI_DisableMemoryMappedMode(Instance) != BSP_ERROR_NONE)
+ /* Set default QSPI_Ctx values */
+ QSPI_Ctx[Instance].IsInitialized = QSPI_ACCESS_NONE;
+ QSPI_Ctx[Instance].InterfaceMode = BSP_QSPI_SPI_MODE;
+ QSPI_Ctx[Instance].TransferRate = BSP_QSPI_STR_TRANSFER;
+ QSPI_Ctx[Instance].DualFlashMode = QSPI_DUALFLASH_ENABLE;
+#if (USE_HAL_QSPI_REGISTER_CALLBACKS == 0)
+ QSPI_MspDeInit(&hqspi);
+#endif /* (USE_HAL_QSPI_REGISTER_CALLBACKS == 0) */
+ /* Call the DeInit function to reset the driver */
+ if (HAL_QSPI_DeInit(&hqspi) != HAL_OK)
+ return ret;
+ * @param hQspi QSPI handle
+ * @param Config QSPI configuration structure
+__weak HAL_StatusTypeDef MX_QSPI_Init(QSPI_HandleTypeDef *hQspi, MX_QSPI_Init_t *Config)
+ /* QSPI initialization */
+ /* QSPI freq = SYSCLK /(1 + ClockPrescaler) Mhz */
+ hQspi->Instance = QUADSPI;
+ hQspi->Init.ClockPrescaler = Config->ClockPrescaler;
+ hQspi->Init.FifoThreshold = 1;
+ hQspi->Init.SampleShifting = Config->SampleShifting;
+ hQspi->Init.FlashSize = Config->FlashSize;
+ hQspi->Init.ChipSelectHighTime = QSPI_CS_HIGH_TIME_4_CYCLE; /* Min 50ns for nonRead */
+ hQspi->Init.ClockMode = QSPI_CLOCK_MODE_0;
+ hQspi->Init.FlashID = QSPI_FLASH_ID_1;
+ hQspi->Init.DualFlash = Config->DualFlashMode;
+ return HAL_QSPI_Init(hQspi);
+ * @brief Default BSP QSPI Msp Callbacks
+int32_t BSP_QSPI_RegisterDefaultMspCallbacks (uint32_t Instance)
+ else
+ /* Register MspInit/MspDeInit Callbacks */
+ if(HAL_QSPI_RegisterCallback(&hqspi, HAL_QSPI_MSPINIT_CB_ID, QSPI_MspInit) != HAL_OK)
+ else if(HAL_QSPI_RegisterCallback(&hqspi, HAL_QSPI_MSPDEINIT_CB_ID, QSPI_MspDeInit) != HAL_OK)
+ else
+ QSPI_Ctx[Instance].IsMspCallbacksValid = 1U;
+ return ret;
+ * @brief BSP QSPI Msp Callback registering
+ * @param CallBacks pointer to MspInit/MspDeInit callbacks functions
+int32_t BSP_QSPI_RegisterMspCallbacks (uint32_t Instance, BSP_QSPI_Cb_t *CallBacks)
+ else
+ if(HAL_QSPI_RegisterCallback(&hqspi, HAL_QSPI_MSPINIT_CB_ID, CallBacks->pMspInitCb) != HAL_OK)
+ else if(HAL_QSPI_RegisterCallback(&hqspi, HAL_QSPI_MSPDEINIT_CB_ID, CallBacks->pMspDeInitCb) != HAL_OK)
+ else
+ return ret;
+#endif /* (USE_HAL_QSPI_REGISTER_CALLBACKS == 1) */
+ * @brief Reads an amount of data from the QSPI memory.
+ * @param Instance QSPI instance
+ * @param pData Pointer to data to be read
+ * @param ReadAddr Read start address
+ * @param Size Size of data to read
+int32_t BSP_QSPI_Read(uint32_t Instance, uint8_t *pData, uint32_t ReadAddr, uint32_t Size)
+ else
+ if(QSPI_Ctx[Instance].TransferRate == BSP_QSPI_STR_TRANSFER)
+ if(MT25TL01G_ReadSTR(&hqspi, QSPI_Ctx[Instance].InterfaceMode, pData, ReadAddr, Size) != MT25TL01G_OK)
+ else
+ if(MT25TL01G_ReadDTR(&hqspi, QSPI_Ctx[Instance].InterfaceMode, pData, ReadAddr, Size) != MT25TL01G_OK)
+ return ret;
+ * @brief Writes an amount of data to the QSPI memory.
+ * @param pData Pointer to data to be written
+ * @param WriteAddr Write start address
+ * @param Size Size of data to write
+int32_t BSP_QSPI_Write(uint32_t Instance, uint8_t *pData, uint32_t WriteAddr, uint32_t Size)
+ uint32_t end_addr, current_size, current_addr;
+ uint8_t *write_data;
+ else
+ /* Calculation of the size between the write address and the end of the page */
+ current_size = MT25TL01G_PAGE_SIZE - (WriteAddr % MT25TL01G_PAGE_SIZE);
+ /* Check if the size of the data is less than the remaining place in the page */
+ if (current_size > Size)
+ current_size = Size;
+ /* Initialize the address variables */
+ current_addr = WriteAddr;
+ end_addr = WriteAddr + Size;
+ write_data = pData;
+ /* Perform the write page by page */
+ do
+ /* Check if Flash busy ? */
+ if(MT25TL01G_AutoPollingMemReady(&hqspi, QSPI_Ctx[Instance].InterfaceMode) != MT25TL01G_OK)
+ }/* Enable write operations */
+ else if(MT25TL01G_WriteEnable(&hqspi, QSPI_Ctx[Instance].InterfaceMode) != MT25TL01G_OK)
+ }/* Issue page program command */
+ else if(MT25TL01G_PageProgram(&hqspi, QSPI_Ctx[Instance].InterfaceMode, write_data, current_addr, current_size) != MT25TL01G_OK)
+ }/* Configure automatic polling mode to wait for end of program */
+ else if (MT25TL01G_AutoPollingMemReady(&hqspi, QSPI_Ctx[Instance].InterfaceMode) != MT25TL01G_OK)
+ else
+ /* Update the address and size variables for next page programming */
+ current_addr += current_size;
+ write_data += current_size;
+ current_size = ((current_addr + MT25TL01G_PAGE_SIZE) > end_addr) ? (end_addr - current_addr) : MT25TL01G_PAGE_SIZE;
+ } while ((current_addr < end_addr) && (ret == BSP_ERROR_NONE));
+ return ret;
+ * @brief Erases the specified block of the QSPI memory.
+ * MT25TL01G support 4K, 32K, 64K size block erase commands for each Die.
+ * i.e 8K, 64K, 128K at BSP level (see BSP_QSPI_Erase_t type definition)
+ * @param BlockAddress Block address to erase
+ * @param BlockSize Erase Block size
+int32_t BSP_QSPI_EraseBlock(uint32_t Instance, uint32_t BlockAddress, BSP_QSPI_Erase_t BlockSize)
+ else
+ /* Check Flash busy ? */
+ else
+ /* Issue Block Erase command */
+ if(MT25TL01G_BlockErase(&hqspi, QSPI_Ctx[Instance].InterfaceMode, BlockAddress, (MT25TL01G_Erase_t)BlockSize) != MT25TL01G_OK)
+ return ret;
+ * @brief Erases the entire QSPI memory.
+int32_t BSP_QSPI_EraseChip(uint32_t Instance)
+ else
+ else if (MT25TL01G_WriteEnable(&hqspi, QSPI_Ctx[Instance].InterfaceMode) != MT25TL01G_OK)
+ else
+ /* Issue Chip erase command */
+ if(MT25TL01G_ChipErase(&hqspi, QSPI_Ctx[Instance].InterfaceMode) != MT25TL01G_OK)
+ return ret;
+ * @brief Reads current status of the QSPI memory.
+ * If WIP != 0 then return busy.
+ * @retval QSPI memory status: whether busy or not
+int32_t BSP_QSPI_GetStatus(uint32_t Instance)
+ uint8_t reg;
+ else
+ if(MT25TL01G_ReadStatusRegister(&hqspi, QSPI_Ctx[Instance].InterfaceMode, ®) != MT25TL01G_OK)
+ else
+ /* Check the value of the register */
+ if ((reg & MT25TL01G_SR_WIP) != 0U)
+ ret = BSP_ERROR_BUSY;
+ return ret;
+ * @brief Return the configuration of the QSPI memory.
+ * @param pInfo pointer on the configuration structure
+int32_t BSP_QSPI_GetInfo(uint32_t Instance, BSP_QSPI_Info_t *pInfo)
+ else
+ (void)MT25TL01G_GetFlashInfo(pInfo);
+ return ret;
+ * @brief Configure the QSPI in memory-mapped mode
+ * Only 1 Instance can running MMP mode. And it will lock system at this mode.
+int32_t BSP_QSPI_EnableMemoryMappedMode(uint32_t Instance)
+ else
+ if(MT25TL01G_EnableMemoryMappedModeSTR(&hqspi, QSPI_Ctx[Instance].InterfaceMode) != MT25TL01G_OK)
+ else /* Update QSPI context if all operations are well done */
+ QSPI_Ctx[Instance].IsInitialized = QSPI_ACCESS_MMP;
+ else
+ if(MT25TL01G_EnableMemoryMappedModeDTR(&hqspi, QSPI_Ctx[Instance].InterfaceMode) != MT25TL01G_OK)
+ return ret;
+ * @brief Exit form memory-mapped mode
+int32_t BSP_QSPI_DisableMemoryMappedMode(uint32_t Instance)
+ uint8_t Dummy;
+ else
+ if(QSPI_Ctx[Instance].IsInitialized != QSPI_ACCESS_MMP)
+ ret = BSP_ERROR_QSPI_MMP_UNLOCK_FAILURE;
+ }/* Abort MMP back to indirect mode */
+ else if(HAL_QSPI_Abort(&hqspi) != HAL_OK)
+ else
+ /* Force QSPI interface Sampling Shift to half cycle */
+ hqspi.Init.SampleShifting = QSPI_SAMPLE_SHIFTING_HALFCYCLE;
+ if(HAL_QSPI_Init(&hqspi)!= HAL_OK)
+ /* Dummy read for exit from Performance Enhance mode */
+ else if(MT25TL01G_ReadSTR(&hqspi, QSPI_Ctx[Instance].InterfaceMode, &Dummy, 0, 1) != MT25TL01G_OK)
+ QSPI_Ctx[Instance].IsInitialized = QSPI_ACCESS_INDIRECT;
+ return ret;
+ * @brief Get flash ID, 3 Byte
+ * Manufacturer ID, Memory type, Memory density
+ * @param Id QSPI Identifier
+int32_t BSP_QSPI_ReadID(uint32_t Instance, uint8_t *Id)
+ else
+ if(MT25TL01G_ReadID(&hqspi, QSPI_Ctx[Instance].InterfaceMode, Id) != MT25TL01G_OK)
+ return ret;
+ * @brief Set Flash to desired Interface mode. And this instance becomes current instance.
+ * If current instance running at MMP mode then this function isn't work.
+ * Indirect -> Indirect
+ * @param Mode QSPI mode
+ * @param Rate QSPI transfer rate
+int32_t BSP_QSPI_ConfigFlash(uint32_t Instance, BSP_QSPI_Interface_t Mode, BSP_QSPI_Transfer_t Rate)
+ else
+ /* Check if MMP mode locked ************************************************/
+ ret = BSP_ERROR_QSPI_MMP_LOCK_FAILURE;
+ else
+ /* Setup MCU transfer rate setting ***************************************************/
+ hqspi.Init.SampleShifting = (Rate == BSP_QSPI_STR_TRANSFER) ? QSPI_SAMPLE_SHIFTING_HALFCYCLE : QSPI_SAMPLE_SHIFTING_NONE;
+ else
+ /* Setup Flash interface ***************************************************/
+ switch(QSPI_Ctx[Instance].InterfaceMode)
+ case MT25TL01G_QPI_MODE : /* 4-4-4 commands */
+ if(Mode != MT25TL01G_QPI_MODE)
+ if(MT25TL01G_ExitQPIMode(&hqspi) != MT25TL01G_OK)
+ break;
+ case BSP_QSPI_SPI_MODE : /* 1-1-1 commands, Power on H/W default setting */
+ case BSP_QSPI_SPI_2IO_MODE : /* 1-2-2 read commands */
+ case BSP_QSPI_SPI_4IO_MODE : /* 1-4-4 read commands */
+ default :
+ if(Mode == MT25TL01G_QPI_MODE)
+ if(MT25TL01G_EnterQPIMode(&hqspi) != MT25TL01G_OK)
+ break;
+ /* Update QSPI context if all operations are well done */
+ /* Update current status parameter *****************************************/
+ QSPI_Ctx[Instance].InterfaceMode = Mode;
+ QSPI_Ctx[Instance].TransferRate = Rate;
+ return ret;
+ * @brief QSPI MSP Initialization
+ * @param hQspi : QSPI handle
+ * This function configures the hardware resources used in this example:
+ * - Peripheral's clock enable
+ * - Peripheral's GPIO Configuration
+ * - NVIC configuration for QSPI interrupt
+ * @retval None
+ GPIO_InitTypeDef gpio_init_structure;
+ /*##-1- Enable peripherals and GPIO Clocks #################################*/
+ /* Enable the QuadSPI memory interface clock */
+ QSPI_CLK_ENABLE();
+ /* Reset the QuadSPI memory interface */
+ QSPI_FORCE_RESET();
+ QSPI_RELEASE_RESET();
+ /* Enable GPIO clocks */
+ QSPI_CLK_GPIO_CLK_ENABLE();
+ QSPI_BK1_CS_GPIO_CLK_ENABLE();
+ QSPI_BK1_D0_GPIO_CLK_ENABLE();
+ QSPI_BK1_D1_GPIO_CLK_ENABLE();
+ QSPI_BK1_D2_GPIO_CLK_ENABLE();
+ QSPI_BK1_D3_GPIO_CLK_ENABLE();
+ QSPI_BK2_CS_GPIO_CLK_ENABLE();
+ QSPI_BK2_D0_GPIO_CLK_ENABLE();
+ QSPI_BK2_D1_GPIO_CLK_ENABLE();
+ QSPI_BK2_D2_GPIO_CLK_ENABLE();
+ QSPI_BK2_D3_GPIO_CLK_ENABLE();
+ /*##-2- Configure peripheral GPIO ##########################################*/
+ /* QSPI CLK GPIO pin configuration */
+ gpio_init_structure.Pin = QSPI_CLK_PIN;
+ gpio_init_structure.Mode = GPIO_MODE_AF_PP;
+ gpio_init_structure.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
+ gpio_init_structure.Pull = GPIO_NOPULL;
+ gpio_init_structure.Alternate = GPIO_AF9_QUADSPI;
+ HAL_GPIO_Init(QSPI_CLK_GPIO_PORT, &gpio_init_structure);
+ /* QSPI CS GPIO pin configuration */
+ gpio_init_structure.Pin = QSPI_BK1_CS_PIN;
+ gpio_init_structure.Pull = GPIO_PULLUP;
+ gpio_init_structure.Alternate = GPIO_AF10_QUADSPI;
+ HAL_GPIO_Init(QSPI_BK1_CS_GPIO_PORT, &gpio_init_structure);
+ /* QSPI D0 GPIO pin configuration */
+ gpio_init_structure.Pin = QSPI_BK1_D0_PIN;
+ HAL_GPIO_Init(QSPI_BK1_D0_GPIO_PORT, &gpio_init_structure);
+ gpio_init_structure.Pin = QSPI_BK2_D0_PIN;
+ HAL_GPIO_Init(QSPI_BK2_D0_GPIO_PORT, &gpio_init_structure);
+ /* QSPI D1 GPIO pin configuration */
+ gpio_init_structure.Pin = QSPI_BK1_D1_PIN;
+ HAL_GPIO_Init(QSPI_BK1_D1_GPIO_PORT, &gpio_init_structure);
+ gpio_init_structure.Pin = QSPI_BK2_D1_PIN;
+ HAL_GPIO_Init(QSPI_BK2_D1_GPIO_PORT, &gpio_init_structure);
+ /* QSPI D2 GPIO pin configuration */
+ gpio_init_structure.Pin = QSPI_BK1_D2_PIN;
+ HAL_GPIO_Init(QSPI_BK1_D2_GPIO_PORT, &gpio_init_structure);
+ gpio_init_structure.Pin = QSPI_BK2_D2_PIN;
+ HAL_GPIO_Init(QSPI_BK2_D2_GPIO_PORT, &gpio_init_structure);
+ /* QSPI D3 GPIO pin configuration */
+ gpio_init_structure.Pin = QSPI_BK1_D3_PIN;
+ HAL_GPIO_Init(QSPI_BK1_D3_GPIO_PORT, &gpio_init_structure);
+ gpio_init_structure.Pin = QSPI_BK2_D3_PIN;
+ HAL_GPIO_Init(QSPI_BK2_D3_GPIO_PORT, &gpio_init_structure);
+ /*##-3- Configure the NVIC for QSPI #########################################*/
+ /* NVIC configuration for QSPI interrupt */
+ HAL_NVIC_SetPriority(QUADSPI_IRQn, 0x0F, 0);
+ HAL_NVIC_EnableIRQ(QUADSPI_IRQn);
+ * @brief QSPI MSP De-Initialization
+ * This function frees the hardware resources used in this example:
+ * - Disable the Peripheral's clock
+ * - Revert GPIO and NVIC configuration to their default state
+ * @retval None
+static void QSPI_MspDeInit(QSPI_HandleTypeDef *hQspi)
+ /* Prevent unused argument(s) compilation warning */
+ UNUSED(hQspi);
+ /*##-2- Disable peripherals and GPIO Clocks ################################*/
+ /* De-Configure QSPI pins */
+ HAL_GPIO_DeInit(QSPI_CLK_GPIO_PORT, QSPI_CLK_PIN);
+ HAL_GPIO_DeInit(QSPI_BK1_CS_GPIO_PORT, QSPI_BK1_CS_PIN);
+ HAL_GPIO_DeInit(QSPI_BK1_D0_GPIO_PORT, QSPI_BK1_D0_PIN);
+ HAL_GPIO_DeInit(QSPI_BK1_D1_GPIO_PORT, QSPI_BK1_D1_PIN);
+ HAL_GPIO_DeInit(QSPI_BK1_D2_GPIO_PORT, QSPI_BK1_D2_PIN);
+ HAL_GPIO_DeInit(QSPI_BK1_D3_GPIO_PORT, QSPI_BK1_D3_PIN);
+ HAL_GPIO_DeInit(QSPI_BK2_CS_GPIO_PORT, QSPI_BK2_CS_PIN);
+ HAL_GPIO_DeInit(QSPI_BK2_D0_GPIO_PORT, QSPI_BK2_D0_PIN);
+ HAL_GPIO_DeInit(QSPI_BK2_D1_GPIO_PORT, QSPI_BK2_D1_PIN);
+ HAL_GPIO_DeInit(QSPI_BK2_D2_GPIO_PORT, QSPI_BK2_D2_PIN);
+ HAL_GPIO_DeInit(QSPI_BK2_D3_GPIO_PORT, QSPI_BK2_D3_PIN);
+ /*##-3- Reset peripherals ##################################################*/
+ /* Disable the QuadSPI memory interface clock */
+ QSPI_CLK_DISABLE();
+ * @brief This function reset the QSPI Flash memory.
+ * Fore QPI+SPI reset to avoid system come from unknown status.
+ * Flash accept 1-1-1, 1-1-2, 1-2-2 commands after reset.
+ /* Send RESET ENABLE command in QPI mode (QUAD I/Os, 4-4-4) */
+ if(MT25TL01G_ResetEnable(&hqspi, MT25TL01G_QPI_MODE) != MT25TL01G_OK)
+ ret =BSP_ERROR_COMPONENT_FAILURE;
+ }/* Send RESET memory command in QPI mode (QUAD I/Os, 4-4-4) */
+ else if(MT25TL01G_ResetMemory(&hqspi, MT25TL01G_QPI_MODE) != MT25TL01G_OK)
+ }/* Wait Flash ready */
+ }/* Send RESET ENABLE command in SPI mode (1-1-1) */
+ else if(MT25TL01G_ResetEnable(&hqspi, BSP_QSPI_SPI_MODE) != MT25TL01G_OK)
+ }/* Send RESET memory command in SPI mode (1-1-1) */
+ else if(MT25TL01G_ResetMemory(&hqspi, BSP_QSPI_SPI_MODE) != MT25TL01G_OK)
+ else
+ QSPI_Ctx[Instance].IsInitialized = QSPI_ACCESS_INDIRECT; /* After reset S/W setting to indirect access */
+ QSPI_Ctx[Instance].InterfaceMode = BSP_QSPI_SPI_MODE; /* After reset H/W back to SPI mode by default */
+ QSPI_Ctx[Instance].TransferRate = BSP_QSPI_STR_TRANSFER; /* After reset S/W setting to STR mode */
+ return ret;
+ * @brief This function configure the dummy cycles on memory side.
+ * Dummy cycle bit locate in Configuration Register[7:6]
+ int32_t ret= BSP_ERROR_NONE;
+ QSPI_CommandTypeDef s_command;
+ uint16_t reg=0;
+ /* Initialize the read volatile configuration register command */
+ s_command.InstructionMode = QSPI_INSTRUCTION_4_LINES;
+ s_command.Instruction = MT25TL01G_READ_VOL_CFG_REG_CMD;
+ s_command.AddressMode = QSPI_ADDRESS_NONE;
+ s_command.AlternateByteMode = QSPI_ALTERNATE_BYTES_NONE;
+ s_command.DataMode = QSPI_DATA_4_LINES;
+ s_command.DummyCycles = 0;
+ s_command.NbData = 2;
+ s_command.DdrMode = QSPI_DDR_MODE_DISABLE;
+ s_command.DdrHoldHalfCycle = QSPI_DDR_HHC_ANALOG_DELAY;
+ s_command.SIOOMode = QSPI_SIOO_INST_EVERY_CMD;
+ /* Configure the command */
+ if (HAL_QSPI_Command(&hqspi, &s_command, HAL_QPSI_TIMEOUT_DEFAULT_VALUE) != HAL_OK)
+ return BSP_ERROR_COMPONENT_FAILURE;
+ /* Reception of the data */
+ if (HAL_QSPI_Receive(&hqspi, (uint8_t *)(®), HAL_QPSI_TIMEOUT_DEFAULT_VALUE) != HAL_OK)
+ /* Enable write operations */
+ if (MT25TL01G_WriteEnable(&hqspi, QSPI_Ctx[Instance].InterfaceMode) != MT25TL01G_OK)
+ /* Update volatile configuration register (with new dummy cycles) */
+ s_command.Instruction = MT25TL01G_WRITE_VOL_CFG_REG_CMD;
+ MODIFY_REG(reg, 0xF0F0, ((MT25TL01G_DUMMY_CYCLES_READ_QUAD << 4) |
+ (MT25TL01G_DUMMY_CYCLES_READ_QUAD << 12)));
+ /* Configure the write volatile configuration register command */
+ /* Transmission of the data */
+ if (HAL_QSPI_Transmit(&hqspi, (uint8_t *)(®), HAL_QPSI_TIMEOUT_DEFAULT_VALUE) != HAL_OK)
+ return ret;
diff --git a/bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h747i_discovery_qspi.h b/bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h747i_discovery_qspi.h
index 0000000000..4fff086012
--- /dev/null
+++ b/bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h747i_discovery_qspi.h
@@ -0,0 +1,286 @@
+ * @file stm32h747i_discovery_qspi.h
+ * @brief This file contains the common defines and functions prototypes for
+ * the stm32h747i_discovery_qspi.c driver.
+ * @attention
+ * https://github.com/STMicroelectronics/STM32CubeH7/blob/master/Drivers/BSP/STM32H747I-DISCO/stm32h747i_discovery_qspi.h
+#ifndef STM32H747I_DISCO_QSPI_H
+#define STM32H747I_DISCO_QSPI_H
+#ifdef __cplusplus
+ extern "C" {
+#endif
+#include "stm32h747i_discovery_conf.h"
+#include "stm32h747i_discovery_errno.h"
+#include "../Components/mt25tl01g/mt25tl01g.h"
+/** @addtogroup STM32H747I_DISCO_QSPI
+/* Exported types ------------------------------------------------------------*/
+/** @defgroup STM32H747I_DISCO_QSPI_Exported_Types Exported Types
+#define BSP_QSPI_Info_t MT25TL01G_Info_t
+#define BSP_QSPI_Interface_t MT25TL01G_Interface_t
+#define BSP_QSPI_Transfer_t MT25TL01G_Transfer_t
+#define BSP_QSPI_DualFlash_t MT25TL01G_DualFlash_t
+#define BSP_QSPI_ODS_t MT25TL01G_ODS_t
+typedef enum
+ BSP_QSPI_ERASE_8K = MT25TL01G_ERASE_4K , /*!< 8K size Sector erase = 2 x 4K as Dual flash mode is used for this board */
+ BSP_QSPI_ERASE_64K = MT25TL01G_ERASE_32K , /*!< 64K size Sector erase = 2 x 32K as Dual flash mode is used for this board */
+ BSP_QSPI_ERASE_128K = MT25TL01G_ERASE_64K , /*!< 128K size Sector erase = 2 x 64K as Dual mode is used for this board */
+ BSP_QSPI_ERASE_CHIP = MT25TL01G_ERASE_CHIP /*!< Whole chip erase */
+} BSP_QSPI_Erase_t;
+typedef enum
+ QSPI_ACCESS_NONE = 0, /*!< Instance not initialized, */
+ QSPI_ACCESS_INDIRECT, /*!< Instance use indirect mode access */
+ QSPI_ACCESS_MMP /*!< Instance use Memory Mapped Mode read */
+} BSP_QSPI_Access_t;
+typedef struct
+ BSP_QSPI_Access_t IsInitialized; /*!< Instance access Flash method */
+ BSP_QSPI_Interface_t InterfaceMode; /*!< Flash Interface mode of Instance */
+ BSP_QSPI_Transfer_t TransferRate; /*!< Flash Transfer mode of Instance */
+ uint32_t DualFlashMode; /*!< Flash dual mode */
+ uint32_t IsMspCallbacksValid;
+} BSP_QSPI_Ctx_t;
+typedef struct
+ BSP_QSPI_Interface_t InterfaceMode; /*!< Current Flash Interface mode */
+ BSP_QSPI_Transfer_t TransferRate; /*!< Current Flash Transfer mode */
+ BSP_QSPI_DualFlash_t DualFlashMode; /*!< Dual Flash mode */
+} BSP_QSPI_Init_t;
+typedef struct
+ uint32_t FlashSize;
+ uint32_t ClockPrescaler;
+ uint32_t SampleShifting;
+}MX_QSPI_Init_t;
+typedef struct
+ void(*pMspInitCb)(pQSPI_CallbackTypeDef);
+ void(*pMspDeInitCb)(pQSPI_CallbackTypeDef);
+}BSP_QSPI_Cb_t;
+/* Exported constants --------------------------------------------------------*/
+/** @defgroup STM32H747I_DISCO_QSPI_Exported_Constants Exported Constants
+/* QSPI instances number */
+#define QSPI_INSTANCES_NUMBER 1U
+/* Definition for QSPI modes */
+#define BSP_QSPI_SPI_MODE (BSP_QSPI_Interface_t)MT25TL01G_SPI_MODE /* 1 Cmd Line, 1 Address Line and 1 Data Line */
+#define BSP_QSPI_SPI_1I2O_MODE (BSP_QSPI_Interface_t)MT25TL01G_SPI_1I2O_MODE /* 1 Cmd Line, 1 Address Line and 2 Data Lines */
+#define BSP_QSPI_SPI_2IO_MODE (BSP_QSPI_Interface_t)MT25TL01G_SPI_2IO_MODE /* 1 Cmd Line, 2 Address Lines and 2 Data Lines */
+#define BSP_QSPI_SPI_1I4O_MODE (BSP_QSPI_Interface_t)MT25TL01G_SPI_1I4O_MODE /* 1 Cmd Line, 1 Address Line and 4 Data Lines */
+#define BSP_QSPI_SPI_4IO_MODE (BSP_QSPI_Interface_t)MT25TL01G_SPI_4IO_MODE /* 1 Cmd Line, 4 Address Lines and 4 Data Lines */
+#define BSP_QSPI_DPI_MODE (BSP_QSPI_Interface_t)MT25TL01G_DPI_MODE /* 2 Cmd Lines, 2 Address Lines and 2 Data Lines */
+#define BSP_QSPI_QPI_MODE (BSP_QSPI_Interface_t)MT25TL01G_QPI_MODE /* 4 Cmd Lines, 4 Address Lines and 4 Data Lines */
+/* Definition for QSPI transfer rates */
+#define BSP_QSPI_STR_TRANSFER (BSP_QSPI_Transfer_t)MT25TL01G_STR_TRANSFER /* Single Transfer Rate */
+#define BSP_QSPI_DTR_TRANSFER (BSP_QSPI_Transfer_t)MT25TL01G_DTR_TRANSFER /* Double Transfer Rate */
+/* Definition for QSPI dual flash mode */
+#define BSP_QSPI_DUALFLASH_DISABLE (BSP_QSPI_DualFlash_t)MT25TL01G_DUALFLASH_DISABLE /* Dual flash mode enabled */
+/* Definition for QSPI Flash ID */
+#define BSP_QSPI_FLASH_ID QSPI_FLASH_ID_1
+/* QSPI block sizes for dual flash */
+#define BSP_QSPI_BLOCK_8K MT25TL01G_SECTOR_4K
+#define BSP_QSPI_BLOCK_64K MT25TL01G_BLOCK_32K
+#define BSP_QSPI_BLOCK_128K MT25TL01G_BLOCK_64K
+/* Definition for QSPI clock resources */
+#define QSPI_CLK_ENABLE() __HAL_RCC_QSPI_CLK_ENABLE()
+#define QSPI_CLK_DISABLE() __HAL_RCC_QSPI_CLK_DISABLE()
+#define QSPI_CLK_GPIO_CLK_ENABLE() __HAL_RCC_GPIOB_CLK_ENABLE()
+#define QSPI_BK1_CS_GPIO_CLK_ENABLE() __HAL_RCC_GPIOG_CLK_ENABLE()
+#define QSPI_BK1_D0_GPIO_CLK_ENABLE() __HAL_RCC_GPIOD_CLK_ENABLE()
+#define QSPI_BK1_D1_GPIO_CLK_ENABLE() __HAL_RCC_GPIOF_CLK_ENABLE()
+#define QSPI_BK1_D2_GPIO_CLK_ENABLE() __HAL_RCC_GPIOF_CLK_ENABLE()
+#define QSPI_BK1_D3_GPIO_CLK_ENABLE() __HAL_RCC_GPIOF_CLK_ENABLE()
+#define QSPI_BK2_CS_GPIO_CLK_ENABLE() __HAL_RCC_GPIOG_CLK_ENABLE()
+#define QSPI_BK2_D0_GPIO_CLK_ENABLE() __HAL_RCC_GPIOH_CLK_ENABLE()
+#define QSPI_BK2_D1_GPIO_CLK_ENABLE() __HAL_RCC_GPIOH_CLK_ENABLE()
+#define QSPI_BK2_D2_GPIO_CLK_ENABLE() __HAL_RCC_GPIOG_CLK_ENABLE()
+#define QSPI_BK2_D3_GPIO_CLK_ENABLE() __HAL_RCC_GPIOG_CLK_ENABLE()
+#define QSPI_FORCE_RESET() __HAL_RCC_QSPI_FORCE_RESET()
+#define QSPI_RELEASE_RESET() __HAL_RCC_QSPI_RELEASE_RESET()
+/* Definition for QSPI Pins */
+#define QSPI_CLK_PIN GPIO_PIN_2
+#define QSPI_CLK_GPIO_PORT GPIOB
+/* Bank 1 */
+#define QSPI_BK1_CS_PIN GPIO_PIN_6
+#define QSPI_BK1_CS_GPIO_PORT GPIOG
+#define QSPI_BK1_D0_PIN GPIO_PIN_11
+#define QSPI_BK1_D0_GPIO_PORT GPIOD
+#define QSPI_BK1_D1_PIN GPIO_PIN_9
+#define QSPI_BK1_D1_GPIO_PORT GPIOF
+#define QSPI_BK1_D2_PIN GPIO_PIN_7
+#define QSPI_BK1_D2_GPIO_PORT GPIOF
+#define QSPI_BK1_D3_PIN GPIO_PIN_6
+#define QSPI_BK1_D3_GPIO_PORT GPIOF
+/* Bank 2 */
+#define QSPI_BK2_CS_PIN GPIO_PIN_6
+#define QSPI_BK2_CS_GPIO_PORT GPIOG
+#define QSPI_BK2_D0_PIN GPIO_PIN_2
+#define QSPI_BK2_D0_GPIO_PORT GPIOH
+#define QSPI_BK2_D1_PIN GPIO_PIN_3
+#define QSPI_BK2_D1_GPIO_PORT GPIOH
+#define QSPI_BK2_D2_PIN GPIO_PIN_9
+#define QSPI_BK2_D2_GPIO_PORT GPIOG
+#define QSPI_BK2_D3_PIN GPIO_PIN_14
+#define QSPI_BK2_D3_GPIO_PORT GPIOG
+/* MT25TL01G Micron memory */
+/* Size of the flash */
+#define QSPI_FLASH_SIZE 26 /* Address bus width to access whole memory space */
+#define QSPI_PAGE_SIZE 256
+/* QSPI Base Address */
+#define QSPI_BASE_ADDRESS 0x90000000
+/** @addtogroup STM32H747I_DISCO_QSPI_Exported_Variables
+extern QSPI_HandleTypeDef hqspi;
+extern BSP_QSPI_Ctx_t QSPI_Ctx[];
+/* Exported functions --------------------------------------------------------*/
+/** @addtogroup STM32H747I_DISCO_QSPI_Exported_Functions
+int32_t BSP_QSPI_Init(uint32_t Instance, BSP_QSPI_Init_t *Init);
+int32_t BSP_QSPI_DeInit(uint32_t Instance);
+int32_t BSP_QSPI_RegisterMspCallbacks (uint32_t Instance, BSP_QSPI_Cb_t *CallBacks);
+int32_t BSP_QSPI_RegisterDefaultMspCallbacks (uint32_t Instance);
+int32_t BSP_QSPI_Read(uint32_t Instance, uint8_t *pData, uint32_t ReadAddr, uint32_t Size);
+int32_t BSP_QSPI_Write(uint32_t Instance, uint8_t *pData, uint32_t WriteAddr, uint32_t Size);
+int32_t BSP_QSPI_EraseBlock(uint32_t Instance, uint32_t BlockAddress, BSP_QSPI_Erase_t BlockSize);
+int32_t BSP_QSPI_EraseChip(uint32_t Instance);
+int32_t BSP_QSPI_GetStatus(uint32_t Instance);
+int32_t BSP_QSPI_GetInfo(uint32_t Instance, BSP_QSPI_Info_t *pInfo);
+int32_t BSP_QSPI_EnableMemoryMappedMode(uint32_t Instance);
+int32_t BSP_QSPI_DisableMemoryMappedMode(uint32_t Instance);
+int32_t BSP_QSPI_ReadID(uint32_t Instance, uint8_t *Id);
+int32_t BSP_QSPI_ConfigFlash(uint32_t Instance, BSP_QSPI_Interface_t Mode, BSP_QSPI_Transfer_t Rate);
+/* These functions can be modified in case the current settings
+ need to be changed for specific application needs */
+HAL_StatusTypeDef MX_QSPI_Init(QSPI_HandleTypeDef *hQspi, MX_QSPI_Init_t *Config);
+#ifdef __cplusplus
+#endif
+#endif /*STM32H747I_DISCO_QSPI_H */
2.25.1
