[PATCH 3/5] bsps/stm32h7: allow config and usage of QSPI memory on stm32h757i-eval BSP
Karel Gardas
karel at functional.vision
Fri Jun 17 14:42:11 UTC 2022
On 6/15/22 17:00, Gedare Bloom wrote:
> On Fri, Jun 10, 2022 at 6:49 AM Karel Gardas <karel at functional.vision> wrote:
>> The QSPI memory is initialized and used only when the BSP configure file
>> sets QSPI memory size to non-zero value. Currently QSPI is run in memory
>> mapped mode which allows future RTEMS binary linkage and upload into QSPI
>> memory.
>> Sponsored-By: Precidata
>> .../stm/stm32h757i-eval/stm32h7-bspstarthooks.c | 17 +++++++++++++++++
>> bsps/arm/stm32h7/include/bsp.h | 1 +
>> .../bsps/arm/stm32h7/bspstm32h757i-eval.yml | 5 ++++-
>> spec/build/bsps/arm/stm32h7/optmemquadspisz.yml | 1 +
>> 4 files changed, 23 insertions(+), 1 deletion(-)
>> diff --git a/bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h7-bspstarthooks.c b/bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h7-bspstarthooks.c
>> index 8d34e357ee..9916b740ce 100644
>> --- a/bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h7-bspstarthooks.c
>> +++ b/bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h7-bspstarthooks.c
>> @@ -36,6 +36,22 @@
>> #include <string.h>
>> +#if defined(STM32H7_MEMORY_QUADSPI_SIZE) && STM32H7_MEMORY_QUADSPI_SIZE > 0
>> +#include <stm32h747i_eval_qspi.h>
>> +BSP_QSPI_Init_t QSPinit;
> Do you need this variable to be in the global namespace? Can it be a
> static variable here?
I've just resent patch version just for 757i-eval to make review simpler
where I've switch to static variable here. It has its own pros/cons:
+ not populating global namespace
+ not require explicit initialization
- require to be used after BSS is initialized
So it's really a question what is prefefrred way here.
Thanks,
Karel
