[PATCH 13/13] jffs2: Update baseline version to Linux v5.9
Joel Sherrill
joel at rtems.org
Fri Jun 10 13:25:18 UTC 2022
If I read the patch set correctly, there is a one line change to os-rtems.h
which looks fine and the rest is updating to the latest version.
If so, then push it.
--joel
On Fri, Jun 10, 2022 at 3:21 AM Sebastian Huber <
> cpukit/libfs/src/jffs2/VERSION | 4 ++--
> 1 file changed, 2 insertions(+), 2 deletions(-)
> diff --git a/cpukit/libfs/src/jffs2/VERSION
> b/cpukit/libfs/src/jffs2/VERSION
> index 7d9c9f41b2..b13bed5750 100644
> --- a/cpukit/libfs/src/jffs2/VERSION
> +++ b/cpukit/libfs/src/jffs2/VERSION
> @@ -1,9 +1,9 @@
> -This directory contains a port of the JFFS2 file system from Linux v4.17.
> +This directory contains a port of the JFFS2 file system from Linux v5.9.
> To update to a newer Linux version use this command in a Git clone of
> Linux to
> generate the relevant patches:
> - git format-patch v4.17..v9.99 --
> + git format-patch v5.9..v9.99 --
> include/uapi/linux/jffs2.h \
> fs/jffs2/LICENCE \
> fs/jffs2/acl.h \
> 2.35.3
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220610/46c972ae/attachment.htm>
