[PATCH 13/13] jffs2: Update baseline version to Linux v5.9
Chris Johns
chrisj at rtems.org
Sat Jun 11 01:57:36 UTC 2022
On 10/6/22 11:25 pm, Joel Sherrill wrote:
> If I read the patch set correctly, there is a one line change to os-rtems.h
> which looks fine and the rest is updating to the latest version.
Yes it seems so.
> If so, then push it.
OK from me and thanks for picking up this task.
I will take a look at the heap fragmentation under large block writes as a
background task. I have opened https://devel.rtems.org/ticket/4664 to track this
issue.
Thanks
