[PATCH 0/8] Relicense clean up sweep on testsuites
Joel Sherrill
joel at rtems.org
Fri Jun 10 15:52:53 UTC 2022
Hi
I am making another pass on testsuites and (soon) cpukit to relicense
the files which have only a single copyright statement and attribution
to OAR, embedded brains, Chris Johns, or Gedare Bloom. The script
doing this picks up some files missed by the previous passes
Hopefully this is not controversial.
--joel
Joel Sherrill (8):
smptests/*/*.py: Change license to BSD-2
samples/*/*.doc: Change license to BSD-2
psxtmtests/*/*.doc: Change license to BSD-2
smptests/*/*.doc: Change license to BSD-2
sptests/*/*.doc: Change license to BSD-2
samples/iostream/init.cc: Change license to BSD-2
sptests/spglobalcon01/init.cc: Change license to BSD-2
testsuites/mptests/mp01/mp01-node1.doc | 25 ++++++++++++++++---
testsuites/mptests/mp01/mp01-node2.doc | 25 ++++++++++++++++---
testsuites/mptests/mp03/mp03-node1.doc | 25 ++++++++++++++++---
testsuites/mptests/mp03/mp03-node2.doc | 25 ++++++++++++++++---
testsuites/mptests/mp04/mp04-node1.doc | 25 ++++++++++++++++---
testsuites/mptests/mp04/mp04-node2.doc | 25 ++++++++++++++++---
testsuites/mptests/mp05/mp05-node1.doc | 25 ++++++++++++++++---
testsuites/mptests/mp05/mp05-node2.doc | 25 ++++++++++++++++---
testsuites/mptests/mp06/mp06-node1.doc | 25 ++++++++++++++++---
testsuites/mptests/mp06/mp06-node2.doc | 25 ++++++++++++++++---
testsuites/mptests/mp07/mp07-node1.doc | 25 ++++++++++++++++---
testsuites/mptests/mp07/mp07-node2.doc | 25 ++++++++++++++++---
testsuites/mptests/mp08/mp08-node1.doc | 25 ++++++++++++++++---
testsuites/mptests/mp08/mp08-node2.doc | 25 ++++++++++++++++---
testsuites/mptests/mp09/mp09-node1.doc | 25 ++++++++++++++++---
testsuites/mptests/mp09/mp09-node2.doc | 25 ++++++++++++++++---
testsuites/mptests/mp10/mp10-node1.doc | 25 ++++++++++++++++---
testsuites/mptests/mp10/mp10-node2.doc | 25 ++++++++++++++++---
testsuites/mptests/mp11/mp11-node1.doc | 25 ++++++++++++++++---
testsuites/mptests/mp11/mp11-node2.doc | 25 ++++++++++++++++---
testsuites/mptests/mp12/mp12-node1.doc | 25 ++++++++++++++++---
testsuites/mptests/mp12/mp12-node2.doc | 25 ++++++++++++++++---
testsuites/mptests/mp13/mp13-node1.doc | 25 ++++++++++++++++---
testsuites/mptests/mp13/mp13-node2.doc | 25 ++++++++++++++++---
testsuites/mptests/mp14/mp14-node1.doc | 25 ++++++++++++++++---
testsuites/mptests/mp14/mp14-node2.doc | 25 ++++++++++++++++---
.../psxtmbarrier01/psxtmbarrier01.doc | 25 ++++++++++++++++---
.../psxtmbarrier02/psxtmbarrier02.doc | 25 ++++++++++++++++---
.../psxtmbarrier03/psxtmbarrier03.doc | 25 ++++++++++++++++---
.../psxtmbarrier04/psxtmbarrier04.doc | 25 ++++++++++++++++---
.../psxtmclocknanosleep01.doc | 25 ++++++++++++++++---
.../psxtmclocknanosleep02.doc | 25 ++++++++++++++++---
.../psxtmclocknanosleep03.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmcond02/psxtmcond02.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmcond03/psxtmcond03.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmcond04/psxtmcond04.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmcond05/psxtmcond05.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmcond06/psxtmcond06.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmcond07/psxtmcond07.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmcond08/psxtmcond08.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmcond09/psxtmcond09.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmkey01/psxtmkey01.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmkey02/psxtmkey02.doc | 25 ++++++++++++++++---
testsuites/psxtmtests/psxtmmq01/psxtmmq01.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmmutex01/psxtmmutex01.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmmutex02/psxtmmutex02.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmmutex03/psxtmmutex03.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmmutex04/psxtmmutex04.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmmutex05/psxtmmutex05.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmmutex06/psxtmmutex06.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmmutex07/psxtmmutex07.doc | 25 ++++++++++++++++---
.../psxtmnanosleep01/psxtmnanosleep01.doc | 25 ++++++++++++++++---
.../psxtmnanosleep02/psxtmnanosleep02.doc | 25 ++++++++++++++++---
.../psxtmrwlock01/psxtmrwlock01.doc | 25 ++++++++++++++++---
.../psxtmrwlock02/psxtmrwlock02.doc | 25 ++++++++++++++++---
.../psxtmrwlock03/psxtmrwlock03.doc | 25 ++++++++++++++++---
.../psxtmrwlock04/psxtmrwlock04.doc | 25 ++++++++++++++++---
.../psxtmrwlock05/psxtmrwlock05.doc | 25 ++++++++++++++++---
.../psxtmrwlock06/psxtmrwlock06.doc | 25 ++++++++++++++++---
.../psxtmrwlock07/psxtmrwlock07.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmsem01/psxtmsem01.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmsem02/psxtmsem02.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmsem03/psxtmsem03.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmsem04/psxtmsem04.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmsem05/psxtmsem05.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmsleep01/psxtmsleep01.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmsleep02/psxtmsleep02.doc | 25 ++++++++++++++++---
.../psxtmthread01/psxtmthread01.doc | 25 ++++++++++++++++---
.../psxtmthread03/psxtmthread03.doc | 25 ++++++++++++++++---
.../psxtmthread04/psxtmthread04.doc | 25 ++++++++++++++++---
.../psxtmthread05/psxtmthread05.doc | 25 ++++++++++++++++---
testsuites/samples/base_mp/base_mp-node1.doc | 25 ++++++++++++++++---
testsuites/samples/base_mp/base_mp-node2.doc | 25 ++++++++++++++++---
testsuites/samples/base_sp/base_sp.doc | 25 ++++++++++++++++---
testsuites/samples/capture/capture.doc | 25 ++++++++++++++++---
testsuites/samples/fileio/fileio.doc | 25 ++++++++++++++++---
testsuites/samples/hello/hello.doc | 25 ++++++++++++++++---
testsuites/samples/iostream/init.cc | 25 ++++++++++++++++---
testsuites/samples/iostream/iostream.doc | 25 ++++++++++++++++---
testsuites/samples/minimum/minimum.doc | 25 ++++++++++++++++---
testsuites/samples/nsecs/nsecs.doc | 25 ++++++++++++++++---
testsuites/samples/paranoia/paranoia.doc | 25 ++++++++++++++++---
testsuites/samples/ticker/ticker.doc | 25 ++++++++++++++++---
testsuites/samples/unlimited/unlimited.doc | 2 ++
testsuites/smptests/smp01/smp01.doc | 25 ++++++++++++++++---
testsuites/smptests/smp02/smp02.doc | 25 ++++++++++++++++---
testsuites/smptests/smp03/smp03.doc | 25 ++++++++++++++++---
testsuites/smptests/smp05/smp05.doc | 25 ++++++++++++++++---
testsuites/smptests/smp07/smp07.doc | 25 ++++++++++++++++---
testsuites/smptests/smp08/smp08.doc | 25 ++++++++++++++++---
testsuites/smptests/smp09/smp09.doc | 25 ++++++++++++++++---
.../smptests/smpaffinity01/smpaffinity01.doc | 25 ++++++++++++++++---
.../smptests/smplock01/smplock01fair.py | 25 ++++++++++++++++---
.../smptests/smplock01/smplock01perf.py | 25 ++++++++++++++++---
.../smptests/smpopenmp01/smpopenmp01.py | 25 ++++++++++++++++---
.../smppsxaffinity01/smppsxaffinity01.doc | 25 ++++++++++++++++---
.../smppsxaffinity02/smppsxaffinity02.doc | 25 ++++++++++++++++---
testsuites/sptests/spglobalcon01/init.cc | 25 ++++++++++++++++---
testsuites/sptests/spheapprot/spheapprot.doc | 23 ++++++++++++++---
.../sptimecounter02/sptimecounter02.py | 25 ++++++++++++++++---
100 files changed, 2178 insertions(+), 297 deletions(-)
2.24.4
