[PATCH 1/8] smptests/*/*.py: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Jun 10 15:52:54 UTC 2022
Manually adjusted location of SPDX annotation so #! remains first line.
Updates #3053.
.../smptests/smplock01/smplock01fair.py | 25 ++++++++++++++++---
.../smptests/smplock01/smplock01perf.py | 25 ++++++++++++++++---
.../smptests/smpopenmp01/smpopenmp01.py | 25 ++++++++++++++++---
.../sptimecounter02/sptimecounter02.py | 25 ++++++++++++++++---
4 files changed, 88 insertions(+), 12 deletions(-)
diff --git a/testsuites/smptests/smplock01/smplock01fair.py b/testsuites/smptests/smplock01/smplock01fair.py
index 378dfd8028..c5d99c6cbe 100755
--- a/testsuites/smptests/smplock01/smplock01fair.py
+++ b/testsuites/smptests/smplock01/smplock01fair.py
@@ -1,11 +1,30 @@
#!/usr/bin/env python
+# SPDX-License-Identifier: BSD-2-Clause
# Copyright (c) 2016 embedded brains GmbH. All rights reserved.
-# The license and distribution terms for this file may be
-# found in the file LICENSE in this distribution or at
-# http://www.rtems.org/license/LICENSE.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions
+# are met:
+# 1. Redistributions of source code must retain the above copyright
+# notice, this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright
+# notice, this list of conditions and the following disclaimer in the
+# documentation and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
import re
diff --git a/testsuites/smptests/smplock01/smplock01perf.py b/testsuites/smptests/smplock01/smplock01perf.py
index 43816814f8..c50ef7047f 100755
--- a/testsuites/smptests/smplock01/smplock01perf.py
+++ b/testsuites/smptests/smplock01/smplock01perf.py
@@ -1,11 +1,30 @@
+# are met:
import re
diff --git a/testsuites/smptests/smpopenmp01/smpopenmp01.py b/testsuites/smptests/smpopenmp01/smpopenmp01.py
index 139aedd4af..7a9b39973a 100644
--- a/testsuites/smptests/smpopenmp01/smpopenmp01.py
+++ b/testsuites/smptests/smpopenmp01/smpopenmp01.py
@@ -1,11 +1,30 @@
# Copyright (c) 2017 embedded brains GmbH. All rights reserved.
+# are met:
import re
diff --git a/testsuites/sptests/sptimecounter02/sptimecounter02.py b/testsuites/sptests/sptimecounter02/sptimecounter02.py
index 925b3f1d6c..c0cf42bfa0 100755
--- a/testsuites/sptests/sptimecounter02/sptimecounter02.py
+++ b/testsuites/sptests/sptimecounter02/sptimecounter02.py
@@ -1,11 +1,30 @@
+# are met:
import re
2.24.4
