[PATCH 8/8] sptests/spglobalcon01/init.cc: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Jun 10 15:53:01 UTC 2022
Updates #3053.
testsuites/sptests/spglobalcon01/init.cc | 25 +++++++++++++++++++++---
1 file changed, 22 insertions(+), 3 deletions(-)
diff --git a/testsuites/sptests/spglobalcon01/init.cc b/testsuites/sptests/spglobalcon01/init.cc
index 54f2774170..661b828ddc 100644
--- a/testsuites/sptests/spglobalcon01/init.cc
+++ b/testsuites/sptests/spglobalcon01/init.cc
@@ -1,9 +1,28 @@
* Copyright (c) 2014 embedded brains GmbH. All rights reserved.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#ifdef HAVE_CONFIG_H
2.24.4
