[PATCH 7/8] samples/iostream/init.cc: Change license to BSD-2
Fri Jun 10 15:53:00 UTC 2022
Updates #3053.
 testsuites/samples/iostream/init.cc | 25 ++++++++++++++++++++++---
 1 file changed, 22 insertions(+), 3 deletions(-)
diff --git a/testsuites/samples/iostream/init.cc b/testsuites/samples/iostream/init.cc
index d80d4df9eb..22d973019b 100644
--- a/testsuites/samples/iostream/init.cc
+++ b/testsuites/samples/iostream/init.cc
@@ -1,3 +1,5 @@
 /*  Init
  *  This routine is the initialization task for this test program.
@@ -13,9 +15,26 @@
  *  COPYRIGHT (c) 1989-2008.
  *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
 #define CONFIGURE_INIT
2.24.4
