[PATCH] bsp/aarch64: Fix array warning
Mon Jun 13 16:48:07 UTC 2022
On Mon, Jun 13, 2022 at 11:41 AM Kinsey Moore <kinsey.moore at oarcorp.com>
wrote:
> On 6/12/2022 01:30, Chris Johns wrote:
> > On 12/6/22 12:59 am, Joel Sherrill wrote:
> >> Should this use that obscure pointer macro Sebastian suggests sometimes?
> > I looked into that and could not get it to work. This works. If you
> would like
> > to try please do?
> I've been testing for a little while with this exact patch as suggested
> by the warning with no issues. Looks good.
OK. Push it.
I thought there was a macro to use when comparing different pointer types.
But I can't find it and I'm not having luck building gcc 12 tools so far.
--joel
> Kinsey
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220613/b642afe5/attachment.htm>
