[PATCH rtems] bsps/atsam: Fix type of options (part 2)
Christian Mauderer
christian.mauderer at embedded-brains.de
Mon Jun 13 07:17:45 UTC 2022
The patch "bsps/atsam: Fix type of options" missed to adapt some parts
of the yml. With that a custom value works well. But if no value is set,
configure doesn't fall back to the default value but instead just causes
an error. This patch fixes that.
spec/build/bsps/arm/atsam/optconidx.yml | 3 ++-
spec/build/bsps/arm/atsam/optcontype.yml | 3 ++-
2 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/spec/build/bsps/arm/atsam/optconidx.yml b/spec/build/bsps/arm/atsam/optconidx.yml
index 1c0723c594..d58d75e4aa 100644
--- a/spec/build/bsps/arm/atsam/optconidx.yml
+++ b/spec/build/bsps/arm/atsam/optconidx.yml
@@ -1,7 +1,7 @@
SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
actions:
- get-integer: null
-- define-condition: null
+- define: null
build-type: option
copyrights:
- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
@@ -10,6 +10,7 @@ default-by-variant: []
description: |
device index for /dev/console (default 1, e.g. USART1)
enabled-by: true
+format: '{}'
links: []
type: build
diff --git a/spec/build/bsps/arm/atsam/optcontype.yml b/spec/build/bsps/arm/atsam/optcontype.yml
index fd0daa8999..6846fed5f2 100644
--- a/spec/build/bsps/arm/atsam/optcontype.yml
+++ b/spec/build/bsps/arm/atsam/optcontype.yml
@@ -1,7 +1,7 @@
actions:
- get-integer: null
+- define: null
build-type: option
copyrights:
description: |
device type for /dev/console, use 0 for USART and 1 for UART (default USART)
enabled-by: true
+format: '{}'
links: []
type: build
2.35.3
