[PATCH 3/3] aarch64/gicv3: Remove accesses to secure registers
chrisj at rtems.org
chrisj at rtems.org
Tue Jun 14 01:39:32 UTC 2022
bsps/include/dev/irq/arm-gicv3.h | 18 +++++++++++++++---
1 file changed, 15 insertions(+), 3 deletions(-)
diff --git a/bsps/include/dev/irq/arm-gicv3.h b/bsps/include/dev/irq/arm-gicv3.h
index 0d3ef9a1c1..a79368ebdf 100644
--- a/bsps/include/dev/irq/arm-gicv3.h
+++ b/bsps/include/dev/irq/arm-gicv3.h
@@ -300,12 +300,25 @@ static void gicv3_init_dist(volatile gic_dist *dist)
+ * A better way to access these registers than special opcodes
+#define isb() __asm __volatile("isb" : : : "memory")
+#define WRITE_SPECIALREG(reg, _val) \
+ __asm __volatile("msr " __STRING(reg) ", %0" : : "r"((uint64_t)_val))
+#define gic_icc_write(reg, val) \
+do { \
+ WRITE_SPECIALREG(icc_ ##reg ##_el1, val); \
+ isb(); \
+} while (0)
static void gicv3_init_cpu_interface(uint32_t cpu_index)
uint32_t sre_value = 0x7;
WRITE_SR(ICC_SRE, sre_value);
WRITE_SR(ICC_PMR, GIC_CPUIF_ICCPMR_PRIORITY(0xff));
- WRITE_SR(ICC_BPR0, GIC_CPUIF_ICCBPR_BINARY_POINT(0x0));
volatile gic_redist *redist = gicv3_get_redist(cpu_index);
uint32_t waker = redist->icrwaker;
@@ -322,8 +335,7 @@ static void gicv3_init_cpu_interface(uint32_t cpu_index)
/* Enable interrupt groups 0 and 1 */
- WRITE_SR(ICC_IGRPEN0, 0x1);
- WRITE_SR(ICC_IGRPEN1, 0x1);
+ gic_icc_write(IGRPEN1, 1);
WRITE_SR(ICC_CTLR, 0x0);
2.19.1
