[PATCH rtems] bsps/atsam: Fix type of options (part 2)
Christian MAUDERER christian.mauderer at embedded-brains.de
Tue Jun 14 06:16:18 UTC 2022
Thanks. I pushed it.
Am 13.06.22 um 19:37 schrieb Joel Sherrill:
> Fixes build issues I reported. Please push.
> --joel
> On Mon, Jun 13, 2022 at 2:18 AM Christian Mauderer
> <christian.mauderer at embedded-brains.de
> <mailto:christian.mauderer at embedded-brains.de>> wrote:
>     The patch "bsps/atsam: Fix type of options" missed to adapt some parts
>     of the yml. With that a custom value works well. But if no value is set,
>     configure doesn't fall back to the default value but instead just causes
>     an error. This patch fixes that.
>       spec/build/bsps/arm/atsam/optconidx.yml  | 3 ++-
>       spec/build/bsps/arm/atsam/optcontype.yml | 3 ++-
>       2 files changed, 4 insertions(+), 2 deletions(-)
>     diff --git a/spec/build/bsps/arm/atsam/optconidx.yml
>     b/spec/build/bsps/arm/atsam/optconidx.yml
>     index 1c0723c594..d58d75e4aa 100644
>     --- a/spec/build/bsps/arm/atsam/optconidx.yml
>     +++ b/spec/build/bsps/arm/atsam/optconidx.yml
>     @@ -1,7 +1,7 @@
>       SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
>       actions:
>       - get-integer: null
>     -- define-condition: null
>     +- define: null
>       build-type: option
>       copyrights:
>       - Copyright (C) 2020 embedded brains GmbH
>     (http://www.embedded-brains.de <http://www.embedded-brains.de>)
>     @@ -10,6 +10,7 @@ default-by-variant: []
>       description: |
>         device index for /dev/console (default 1, e.g. USART1)
>       enabled-by: true
>     +format: '{}'
>       links: []
>       type: build
>     diff --git a/spec/build/bsps/arm/atsam/optcontype.yml
>     b/spec/build/bsps/arm/atsam/optcontype.yml
>     index fd0daa8999..6846fed5f2 100644
>     --- a/spec/build/bsps/arm/atsam/optcontype.yml
>     +++ b/spec/build/bsps/arm/atsam/optcontype.yml
>     @@ -1,7 +1,7 @@
>       actions:
>       - get-integer: null
>     +- define: null
>       build-type: option
>       copyrights:
>       description: |
>         device type for /dev/console, use 0 for USART and 1 for UART
>     (default USART)
>       enabled-by: true
>     +format: '{}'
>       links: []
>       type: build
>     2.35.3
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
email:  christian.mauderer at embedded-brains.de
phone:  +49-89-18 94 741 - 18
mobile: +49-176-152 206 08
Registernummer: HRB 157899
