[PATCH rtems] bsps/atsam: Fix type of options (part 2)
Joel Sherrill
joel at rtems.org
Mon Jun 13 17:37:25 UTC 2022
Fixes build issues I reported. Please push.
--joel
On Mon, Jun 13, 2022 at 2:18 AM Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> The patch "bsps/atsam: Fix type of options" missed to adapt some parts
> of the yml. With that a custom value works well. But if no value is set,
> configure doesn't fall back to the default value but instead just causes
> an error. This patch fixes that.
> spec/build/bsps/arm/atsam/optconidx.yml | 3 ++-
> spec/build/bsps/arm/atsam/optcontype.yml | 3 ++-
> 2 files changed, 4 insertions(+), 2 deletions(-)
> diff --git a/spec/build/bsps/arm/atsam/optconidx.yml
> b/spec/build/bsps/arm/atsam/optconidx.yml
> index 1c0723c594..d58d75e4aa 100644
> --- a/spec/build/bsps/arm/atsam/optconidx.yml
> +++ b/spec/build/bsps/arm/atsam/optconidx.yml
> @@ -1,7 +1,7 @@
> SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> actions:
> - get-integer: null
> -- define-condition: null
> +- define: null
> build-type: option
> copyrights:
> - Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
> @@ -10,6 +10,7 @@ default-by-variant: []
> description: |
> device index for /dev/console (default 1, e.g. USART1)
> enabled-by: true
> +format: '{}'
> links: []
> type: build
> diff --git a/spec/build/bsps/arm/atsam/optcontype.yml
> b/spec/build/bsps/arm/atsam/optcontype.yml
> index fd0daa8999..6846fed5f2 100644
> --- a/spec/build/bsps/arm/atsam/optcontype.yml
> +++ b/spec/build/bsps/arm/atsam/optcontype.yml
> @@ -1,7 +1,7 @@
> actions:
> - get-integer: null
> +- define: null
> build-type: option
> copyrights:
> description: |
> device type for /dev/console, use 0 for USART and 1 for UART (default
> USART)
> enabled-by: true
> +format: '{}'
> links: []
> type: build
> 2.35.3
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220613/3e959f7d/attachment-0001.htm>
