[PATCH 3/3] aarch64/gicv3: Remove accesses to secure registers
    Gedare Bloom
    gedare at rtems.org
    Wed Jun 15 14:51:55 UTC 2022
On Tue, Jun 14, 2022 at 6:56 PM Chris Johns <chrisj at rtems.org> wrote:
> On 14/6/2022 11:44 pm, Gedare Bloom wrote:
> > On Mon, Jun 13, 2022 at 7:39 PM <chrisj at rtems.org> wrote:
> >> From: Chris Johns <chrisj at rtems.org>
> >>  bsps/include/dev/irq/arm-gicv3.h | 18 +++++++++++++++---
> >>  1 file changed, 15 insertions(+), 3 deletions(-)
> >> diff --git a/bsps/include/dev/irq/arm-gicv3.h b/bsps/include/dev/irq/arm-gicv3.h
> >> index 0d3ef9a1c1..a79368ebdf 100644
> >> --- a/bsps/include/dev/irq/arm-gicv3.h
> >> +++ b/bsps/include/dev/irq/arm-gicv3.h
> >> @@ -300,12 +300,25 @@ static void gicv3_init_dist(volatile gic_dist *dist)
> >> + * A better way to access these registers than special opcodes
> >> +#define isb() __asm __volatile("isb" : : : "memory")
> >> +#define  WRITE_SPECIALREG(reg, _val)                                    \
> >> +  __asm __volatile("msr  " __STRING(reg) ", %0" : : "r"((uint64_t)_val))
> >> +#define  gic_icc_write(reg, val)            \
> >> +do {                                        \
> >> +  WRITE_SPECIALREG(icc_ ##reg ##_el1, val); \
> >> +  isb();                                    \
> >> +} while (0)
> >>  static void gicv3_init_cpu_interface(uint32_t cpu_index)
> >>    uint32_t sre_value = 0x7;
> >>    WRITE_SR(ICC_SRE, sre_value);
> >>    WRITE_SR(ICC_PMR, GIC_CPUIF_ICCPMR_PRIORITY(0xff));
> >> -  WRITE_SR(ICC_BPR0, GIC_CPUIF_ICCBPR_BINARY_POINT(0x0));
> > This appears unrelated?
> The binary pointer effects the secure interrupts and so cannot be touched on
> EL1. It traps into EL3. It makes sense to me it is protected. There is no code
> in Petalinux or FreeBSD writing to this register.
> >>    volatile gic_redist *redist = gicv3_get_redist(cpu_index);
> >>    uint32_t waker = redist->icrwaker;
> >> @@ -322,8 +335,7 @@ static void gicv3_init_cpu_interface(uint32_t cpu_index)
> >>    /* Enable interrupt groups 0 and 1 */
> >> -  WRITE_SR(ICC_IGRPEN0, 0x1);
> >> -  WRITE_SR(ICC_IGRPEN1, 0x1);
> >> +  gic_icc_write(IGRPEN1, 1);
> > Removed the write to IGRPEN0?
> The write I replaced is touching a secure register and so traps into EL3 when
> your TF-A has enabled a secure mode.
> The enable is replaced with a write to the EL1 accessible register. This is how
> FreeBSD does it so I copied that method rather than the binary opcode approach
> which I found complicated.
> You need a suitably configured TF-A to run on aarch64. I would be questioning
> any TF-A that lets this code run without these changes. The Xilinx 2020.2
> vck-190 build of TF-A lets our code run without this patch however 2021.2 had
> tightened things. Xilinx and I looked into the history of their TF-A source and
> how they build it and came to the conclusion the change in the secure mode has
> come from ARM and their TF-A code.
OK, thanks for the explanation. This looks ok to me.
> Chris
